Mounting boat hook holder
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu Sep 03, 2009 11:30 am    Post subject: Mounting boat hook holder Reply with quote
So I bought a "rubber" boat hook holder at Fisheries yesterday and was wondering if I could/should use 5200 to attach it to my cabin and avoid the intrusion of a screw.
Doryman
M/V Lori Ann
Anacortes, WA
Ron Cowan
City/Region: Athens
State or Province: AL
C-Dory Year: 1985
C-Dory Model: 22 Classic
Vessel Name: Elk-Tenn
Photos: Elk-Tenn
PostPosted: Thu Sep 03, 2009 4:12 pm    Post subject: Reply with quote
No experience with 5200 but have heard that 5200 is one product that is "too good "to use. If ever you might want to move it forget it with 5200. Have you thought about 4200?
Ron
Ready to go with the '85 22' Classic
PostPosted: Thu Sep 03, 2009 4:59 pm    Post subject: Reply with quote
Hey Warren, we just put our telescoping hook on the inboard side of the cabin top handrail... Why the need for a mount?
mwilson
City/Region: missoula
State or Province: MT
Vessel Name: STORMY
PostPosted: Thu Sep 03, 2009 5:05 pm    Post subject: boat hook Reply with quote
I put mine on the grab rail behind the open door fits perfect and always handy. michael
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Thu Sep 03, 2009 5:11 pm    Post subject: Re: boat hook Reply with quote
this is also where we put ours.......But
If the two surfaces you plan on bonding are relatively flat than quick-set 520 would do the job fine, just don’t change your mind as to the location after it sets up. Only problem with regular 520 is it takes like 6 days to fully cure, that’s why I suggest the fast set.
J-B weld epoxy is also a good product and comes in slow or 5 min fast set…I’d go with the slow set.
In the center of the bonding surfaces you could use hot glue, this holds whatever your bonding tell it sets up…..think I picked up this technique from another brat somewhere here.
Boatless for now but looking
Valkyrie
City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
PostPosted: Thu Sep 03, 2009 7:12 pm    Post subject: Reply with quote
We've mounted two boat hooks under the coaming pockets, one on each side of the cockpit. I drilled holes for the mounts, "wetted them out" with West Systems epoxy and screwed them in place. Works great!
Nick
"Valkyrie"
PostPosted: Thu Sep 03, 2009 7:35 pm    Post subject: Reply with quote
I screwed rubber boat hook holders up under the deck on the Cockpit. With rubber, I wonder about both 5200 and epoxies?
Wayne McCown
City/Region: Rochester
State or Province: NY
Vessel Name: Little Mac
Photos: Little Mac
PostPosted: Thu Sep 03, 2009 10:16 pm    Post subject: Reply with quote
Like Captain's Choice, I have a pair of telescoping boat hooks that I simply lay on the inside of the grabrails on the top of the cabin. No hooks are needed. They can be easily accessed, and yet are out-of-the-way (taking up no room in the cockpit).
Sea Angel
Photos: Sea Angel
PostPosted: Thu Sep 03, 2009 10:32 pm    Post subject: Reply with quote
Sea Angel has a telescoping hook inside the cabin by the left door jam
where it is imediately available, inside from "borrowers", and out of the
way. I used metal SS clips screwed into the head bulkhead to secure
it in place.
There is a pix under my upgrades folder.
Art
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Fri Sep 04, 2009 7:26 pm    Post subject: Reply with quote
There is a down side to mounting the boat hook on the cabin top hand rail. I was trying to dock at a fuel dock for fuel. While walking around the side of the boat I missed a hand hold due to an oar stored in the same location. The girl at the dock was fairly impressed with my fully clothed swimming ability. Fortunately she had the bow line and kept the boat from drifting away. She asked if I had been boating long. Then my wife arrived and asked us both why I was all wet. As far as I know, there were no other known witnesses.
Doryman
Photos: Lori Ann
PostPosted: Fri Sep 04, 2009 7:48 pm    Post subject: Reply with quote
Because we can't reach the cabin top conveniently when the canvas is up.
Not sure how you attach a flat surface (boat hook mount) on a round surface (grab rail)?
I like that idea. Have to see if my boat hook is short enough to fit in the pocket.
I assume you mean the same as Nick on Valkyrie?
Valkyrie
Photos: Valkyrie
PostPosted: Fri Sep 04, 2009 9:19 pm    Post subject: Reply with quote
Warren,
FYI: We mounted ours not in the pockets, but UNDER the pockets. If you go this route I would like to offer two suggestions. One: mount the holders as near the hull as possible to prevent someone stepping on the molded step from dislodging the boat hook. I have never done this, but Marcia does with some regularity. Don't ask me how! Two: both of our boat hooks telescope and fit just fine in that location. However, mount the holders about a third of the way back from the cabin and forward of the aft end of the cockpit. I mounted one of the holders too near the cabin and that prevents the handle end of the boat hook from fitting in the holder. The handle end must be put aft. Not a big deal, but a nuisance.
Hope that this helps,
Nick
"Valkyrie"
rjmcnabb
City/Region: Pender Island (Southern Gulf Islands)
Vessel Name: Luna
PostPosted: Sat Sep 05, 2009 3:51 pm    Post subject: Reply with quote
I'm with Michael on Stormy. I hang a boat hook on each of the grab rails on the cabin back. If you adjust the telescoping handle so it just scrapes the cockpit floor, it won't swing around in rough water. Inserting the hook from the outboard side of the grab rail makes it the most stable, and on the port side you can remove it without messing with the open door. The boathook's hook hangs low in the grab rail, so it does not interfere with grabbing the rail.
Rod
Rod & Jane; Victoria 18 sloop (Vickie) - gone; Islander 26 Bahama sloop (Callisto) - gone; WW Potter 19 sloop (Spring) - gone; Com-Pac 16 sloop (Bummer II) - gone; Nimble 24 yawl (Chatelaine) - gone; Nimble Vagabond cruiser (Loligo) - gone; C-Dory 22 Cruiser (NoddyBleu) - gone; Com-Pac 19 sloop ('Winkle) - gone; San Juan 24 sloop (Loligo^2) - gone; C-Dory 16 cruiser (Luna); Catalina Capri 18 sloop (Later)
Sea Angel
Photos: Sea Angel
PostPosted: Sat Sep 05, 2009 9:19 pm    Post subject: Reply with quote
http://www.c-brats.com/modules.php?set_albumName=album539&id=DSCN2995&op=modload&name=gallery&file=index&include=view_photo.php
I hope this is the way to show where Sea Angel's boat hook is mounted. I
see it works as a link, now to figure out to have included. The above was
just a copy an paste before I started the reply... I could not come out of
the reply once I started typing and go back in.
Ol' guy still learning. Rolling Eyes
Art
Dreamer
Photos: Dreamer
PostPosted: Sat Sep 05, 2009 9:45 pm    Post subject: Reply with quote
Warren,
Right next to the door hinges, mounted vertically, doesn't get in the way of anything! Beckson clips, four screws, done deal.
Dreamer- Sold 25 Feb. 2013
Page generation time: 0.0456s (PHP: 75% - SQL: 25%) - SQL queries: 32 - GZIP disabled - Debug on
