Portable Stoves - What do you use?
Goto page 1, 2, 3, 4, 5  Next
Post new topic   Reply to topic    The C-Brats Forum Index -> The Galley
Sarge
City/Region: Edmonds
Vessel Name: Sea Badger
Photos: Gigi
PostPosted: Sat Aug 08, 2009 10:11 am    Post subject: Portable Stoves - What do you use? Reply with quote
Hello,
I searched long and hard to find what kind of portable stoves C-Brats use on their boats. Yes, there is some information already on the site, but it is scattered around in a hundred email threads. I hope with this email thread we can 'organize' it a little better for future reference.
Quick background:
We have a Wallas stove and we like it, but as mentioned in an earlier email, it can take 20 minutes to make a can of Dinty Moore stew because of the heat up time, cool down time, etc. Plus, if you boat in an area that is warm it can increase the temperature of the cabin.
We recently bought a Kuuma Stow and Go gas barbecue grill that we have mounted to the stern of the boat and we have used it to cook, but it is inefficient when it comes to boiling water for pasta, especially if you are only using half of the grill. (It does work wonderfully as a barbecue!)
So, we'd like to get a portable stove to use outside the cabin. This portable stove would also share duties when we go camping.
Since I said I'd like to have this organized for more than just my use, I thought that I'd ask people what they use and why and set up a simple format for replies.
If you would, when you reply please do so in this format?
Make/model:
Fuel type: (propane, butane, etc.)
Number of burners:
Guesstimate of cost:
What you like about the stove:
Improvements, if any, you would make:
Would you recommend it to others?:
Any information you think others would find useful:
Thanks in advance,
-Sarge
2001 2150 Bayliner, sold
2007 CD25, sold
2007 Harbercraft Kingfisher 2850, sold
2011 Stabicraft 2250SC, sold
2011 Eastern 18cc
Blog: http://theseabadger.wordpress.com
View user's profile Send private message Visit poster's website AIM Address
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sat Aug 08, 2009 10:23 am    Post subject: Reply with quote
Neat Link Sarge !
Good idea !.
I agree with the wallas, plus, it takes the long heat and cool cycle..but, it is a great gizmo for the boat.
I have a 2,000 watt inverter, so my cooking habits may be a bit different, as those who carry a gen set. I like the electric stuff.
Crock Pots, George Foreman type portable grills that I can use either in the cabin, or set out back in the cockpit depending on meals and weather. I also use the microwave to re-heat some things previously cooked at home and have in zip lock baggies in the cooler.. Just heat-n-eat.
For the non-electrical side of the house, I have that folding red coleman two burner gizmo that works on the 1 pound LP bottles. It does a good job too, but, I like to have it on the dock or camp site. Just not real happy with moving flames on the boat... You never know when someone will pull back in that private cove with you to.....as we know....see that neat boat.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
20dauntless
Photos: Retriever
PostPosted: Sat Aug 08, 2009 10:50 am    Post subject: Reply with quote
I have an MSR Reactor that I use backpacking. I haven't really used it on the boat but I'm sure it would work fine.
Make/model: MSR Reactor
Fuel type: (propane, butane, etc.) MSR IsoPro (Not really sure what this is, this is just the brand name)
Number of burners: 1
Guesstimate of cost: $120
What you like about the stove: Insanely fast for boiling water. Boils a liter in 90 seconds or so, very fuel efficient, not effected by temperature, wind, or altitude, or other environmental factors.
Improvements, if any, you would make: Lower heat settings available for heating, larger model for non backpacking applications.
Would you recommend it to others?: Yes, for the right purpose.
Any information you think others would find useful: This stove works great for boiling water quickly, making pasta, and that sort of thing. You can't really use it for cooking much else. It's just too hot. Also only useable for 2-3 people generally because of the limited size of its integrated pot.
We also have several other stoves. The MSR Pocket Rocket works well for a lot of things, but unless you really need the tiny size of it a big Coleman propane model would probably work best.
Fishhawk
City/Region: Bon Secour
State or Province: AL
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sat Aug 08, 2009 11:24 am    Post subject: Reply with quote
Sarge,
Agreed on the Wallas, great unit but slow and too hot in the summer. We use a single burner propane stove with a small disposable cylinder for morning coffee, boiling water and such.
I wish I could tell you the make and model, it's pretty old. I used to use it to heat a portable ice fishing shanty.
If you are concerned about the open flame, you may want to look at the newer catalytic propane heaters. Most can be used for cooking and are very common here in MN for ice fishing heaters.
We also use a smaller Coleman propane BBQ. Same cylinders.
Good luck,
Capt Dan
"We intend to alleviate global warming's effects of raising ocean water levels by removing enough fish to counteract it all! "
snal
City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
PostPosted: Sat Aug 08, 2009 11:38 am    Post subject: Reply with quote
We use a Brinkman, SS, 2 burner, uses the small screw-on gas bottles.
We place it on a shelf at the stern, which is part of out cockpit roof frame, the shelf has a cutting board next to the stove.
Brinkman
Propane
2 burner
$39 at Walmart
Love the stove!
Piezo still works after 2 years!
Flame adjustment is touchy...hard to find a mid-way point between simmer and wide open.
The grate is NOT SS...but I duplicated it using 1/4" SS rod.
Yes I would recommend it.
Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II"
flrockytop
Photos: C-LOVER
PostPosted: Sat Aug 08, 2009 11:46 am    Post subject: Reply with quote
You can't beat the ol COBB grill for cooking a meal while on the move. On my Texas trip. I set it in the cockpit on top of the cooler. Loaded it with 10 pieces of charcoal and got it going. Is does take about 20 min for the coals to get right to start cooking but then you can toss a 4lb roast in there go about you business and forget about it for four hours til its done. With the cobb it is easy to move around while cooking.
Some more info here
http://www.c-brats.com/viewtopic.php?p=112424&highlight=#112424
2007 22 Cruiser
Track Me HERE
NA4RR
Roger Rockwell
Pensacola, Fl
tomherrick
Guest
PostPosted: Sat Aug 08, 2009 1:14 pm    Post subject: Reply with quote
After reading a post from Greg on the old RedFox Web site, I bought a cheap, very lightly used, induction cooktop about a year ago on ebay for about $75. I haven't used it on the boat yet but used it in the kitchen and made sure it works on the inverter I have for the boat.
I had a 2-burner, cast iron, propane cooktop I got from Cabela's but like others here the idea of open flame in the cabin - not to mention all the extra moisture from the propane - turned me off.
The induction cooktop was a new concept to me. I still don't know the physics behind it, but basically it causes ferrous (iron) molecules in the pan to get hot. The cooktop itself doesn't put out heat or get hot; just a little warm after cooking by conduction transfer from the pan but I can usually touch the top when I'm done with it. I like that because I can just slip it into a storage sleeve and put it away with no cool-down period.
Induction cooktops only work with pots and pans that have ferrous material in them. Stainless steel won't work unless the stainless is one of the varieties that has a fair amount of iron in it. I know 18/10 cookware doesn't work but have read that 18/8 stainless works just fine. I've only used cast iron, which seems to have a suitable amount of ferrous material. I've read that if a magnet sticks to the pan it'll work just fine.
One last thing. On my induction cooktop, the pot or pan will get hot RIGHT NOW. Forget about warming it up, it's hot to the temperature I've set on the cooktop when I push the ON button. If you remember how slow it was cooking on electric coils and how fast a gas cooktop would heat up a pan, this is the next leap.
The picture below is of a model similar to the one I have.
PostPosted: Sat Aug 08, 2009 1:22 pm    Post subject: Reply with quote
I've got a both a single burner Coleman (that runs on either Coleman fuel or unleaded gas) and a propane double burner very similiar to the one pictured above.
I use the double in our '66 VW camper bus and the single burner was in my hurricane kit back in Hawai'i. Both are quick and effecient. The single is so small it doesn't take up much more space than a large coffee mug and the fact that you can run unleaded in it made it extremely useful in an emergency. I've put the single on the boat for a just in case scenario.
PostPosted: Sat Aug 08, 2009 1:28 pm    Post subject: Reply with quote
Patty here. We LOVE our Coleman "Fold n' Go" two burner propane (small bottles) stove. We have not worried about the open flame aspect. It folds in half into a very convenient case with side pockets for the fuel and regulator. It costs about $70, we got ours at REI. For all the reasons already mentioned, it boils water quickly without heating up the s-l-o-w Wallas.
SGIDave
City/Region: St. George Island
Photos: SeaDation
PostPosted: Sat Aug 08, 2009 1:39 pm    Post subject: Reply with quote
Hello Tomherrick,
What size/wattage inverter is required to power your induction cooker? And what size battery bank?
That looks very interesting. Thanks for sharing.
/david
jhwilson
City/Region: Mitchell County
Vessel Name: Placid C
Photos: Placid C
PostPosted: Sat Aug 08, 2009 1:54 pm    Post subject: Reply with quote
I am not so much concerned about a flame inside the cabin as I am a flame next to pressurized fuel in the cabin. Our CD-22 came with no stove which was a positive to us. We use a Cook Mate 3100 non-presurized alcohol stove. It stows under the counter when not in use and with stick on rubber feet it stays put on the counter when in use. Cook Mate is supposedly a company made of ex-Origo employees whose objective was to "build a better mouse trap". I've used the Origo and this is at least as good and may look better.
Of course these alcohol stoves are slow and put out a lot of condensation but there are always tradeoffs.
Make/model: Cook Mate 3100
Fuel type: (propane, butane, etc.) Alcohol (non-pressurized)
Number of burners: 2 (Model 1600 comes with one)
Guesstimate of cost: $200
What you like about the stove: Safety, stowability
Improvements, if any, you would make: Faster and less condensation
Any information you think others would find useful: We may take one of a number of backpacking stoves for unique occasions and/or some electrical appliances.
Harper
Pat and Harper, Mitchell County, NC
tomherrick
Guest
PostPosted: Sat Aug 08, 2009 2:15 pm    Post subject: Reply with quote
David,
I have a 1,500 Watt inverter and the cooktop draws a maximum of 1,200 Watts. My house battery bank consists of two Trojan T105 6-Volt batteries that are rated at 225 Ah. I figure I can use about half or 112.5 Ah at the maximum before having to recharge. My projected non-conservative - leave the lights on and turn the stereo up - calculations for power consumption come in around 55 Ah per day. The T-105s seemed like a good matchup.
I don't remember the specific battery usage numbers I used for the induction cooktop, but I'd imagine using it twice a day for maybe a total of 30 minutes which I think would pan out around 5 Ah. That doesn't take into account any inverter inefficiency though.
Tom
volsman
City/Region: Gulf Breeze
Vessel Name: Adventure
Photos: Adventure
PostPosted: Sat Aug 08, 2009 2:34 pm    Post subject: Cooking on C-dory Reply with quote
We use a toaster oven with a 2000i Honda. The Honda will carry about 1300 watts so you may have to stop something to cook but it only takes a few minutes. Also, griddles,coffee pots, electric pans and microwaves work great, pressure cookers can be used. There is a fully electric one on Amazon. It all depends on how much cooking you want to do. We do not cook much mostly heat and serve.
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Sat Aug 08, 2009 3:57 pm    Post subject: Reply with quote
We use the one burner butane camp stove by Kenyon and a bunch of different manufacturers. Available at most hardware stores or camp stores. It takes the small disposable butane cartridges and ignites by piezo and is really hot. George Laughing
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Sat Aug 08, 2009 4:36 pm    Post subject: Reply with quote
I've got a Magna 2 Kettle grill that uses the one pound propane bottles and to tell the thru other than boiling water which it does well it's useless. It burns so hot that to me it's dangerous to cook meat on. Even though it has a thermostat you can't turn it down low enough. For grilling I really like the Cobb Grill. I thought it might be inconvenient using charcoal but what I do is put 10 bricketts and two lighter sticks in a vacuum bags and seal them up without vacuum and it works great. This prevents them from getting wet or messy and when your ready just cut open the bag and dump in the grill. As Roger said I use mine on top of the cooler also and it doesn't really get that hot on the outside although the top gets hot.
marvin
Post new topic   Reply to topic    The C-Brats Forum Index -> The Galley All times are GMT - 5 Hours
Page 1 of 5
Page generation time: 0.0724s (PHP: 70% - SQL: 30%) - SQL queries: 26 - GZIP disabled - Debug on
