My Transom Repair Project on my 1983 27
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Thu Aug 06, 2009 3:57 pm    Post subject: My Transom Repair Project on my 1983 27 Reply with quote
I finally got some time this summer to work on the boat. Since I already have the engine out, I decided to pull the Transom Shield off (yes this is an I/O) to reseal it and check the transom for rot. Once I removed the transom I found the balsa core was rotted around the bottom two mounting bolts. Digging it out with a small rasp I also found that it had rotted where the swim deck was installed and where the transducer was installed. So, now comes the hard part.
I took a circular saw and cut the inner transom to a depth just less than the outer fiberglass skin. Then took a Sawzall and cut the sole so I would have room to work on the transom and the ability to place the new wood on the transom once I get it down to the outer glass layer. Below is a picture of where I am today.
I still have a lot of Balsa and Plywood to remove. Removing the rotted wood was easy. Removing the good stuff is a bear! The cut out section is roughly 18" high by 4' long. The raised section above the cut out is where they put balsa core.
The interesting part is that the boat has an outer layer of glass, then a layer of end grain balsa another layer of glass then another layer of either exterior ply or end grain balsa and finally a layer of glass.
When I go to put it back together I will have a double thickness of 3/4" Marine Ply (Man is this stuff expensive!) and then a couple of layers of heavy glass/epoxy. I'm not yet sure how I will do the sole. I would really like to replace the whole sole all the way up to the cabin, but I don't know that my glassing skills are up to the task. The sole is done in end grain balsa and when I cut off the section I found a couple of spots with rot. 1 was right next to the rotted transom but the other wasn't. I'm not sure where the water came from for it.
Gary Johnson
KB7NFG
SGIDave
City/Region: St. George Island
Photos: SeaDation
PostPosted: Thu Aug 06, 2009 8:10 pm    Post subject: Reply with quote
Hello Gary,
That is an interesting project...regarding power, will you be refitting with outboard/s on a bracket or staying with the I/O?
just curious,
/david
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Thu Aug 06, 2009 8:25 pm    Post subject: Reply with quote
David,
I'll be going with an I/O and a 4.3l V6. Originally it had a Volvo Penta AQ175 with a Penta 280 outdrive. The AQ175 is a Chev 231cid V6. Since I couldn't find an exact replacement block I decided to go the inexpensive way and ordered up a 4.3L long block from Chevrolet. My outdrive is in fairly good shape but I broke the Y-Pipe for the exhaust and so I'll likely get a used 290 (I'll rebuild it if needed) to put back in with hydraulic Tilt/Trim.
I looked at putting an outboard on it but just can't see spending $15k+ on a new motor! I've got about $1500 in the V6 and if I get the 290, I'll be in that another $1500 or so. Much easier on the pocket book!
snal
City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
PostPosted: Thu Aug 06, 2009 8:40 pm    Post subject: Reply with quote
Man I wish you "project guys" lived near me...I'd love to get some experience by helping.
Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II"
Jazzmanic
Photos: C-Dancer
PostPosted: Thu Aug 06, 2009 11:05 pm    Post subject: Reply with quote
Gary,
It's great to see you moving forward on the project. I look forward to tracking your progess and hope to see you on the water in the near future.
Peter & Caryn
Email: pjamero@gmail.com
tomherrick
Guest
PostPosted: Fri Aug 07, 2009 8:15 am    Post subject: Reply with quote
Gary,
Interesting about the double-cored glass sandwich. Is that only on the transom or does it include the hull; and if it's done on the hull, is it just for the engine mount or does it extend further?
Nice boat...
Tom
PostPosted: Fri Aug 07, 2009 8:40 am    Post subject: Reply with quote
Gary charges $80/hr for the work, $100/hr if you watch, and $200/hr if you help!
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Fri Aug 07, 2009 2:22 pm    Post subject: Reply with quote
Tom,
Just in this section of the Transom. If you look at the picture, you will see where the section above the cutout is raised slightly. This section is Glass/Balsa Endgrain/ Glass. It looks like they added the second raised section (the part I am replacing) after the fact.
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Fri Aug 07, 2009 2:24 pm    Post subject: Reply with quote
Man I wish Pat! I used to have a similar sign on my Toolbox when I was working as a Mechanic. Except I had 1 more line.
$500/hr if you worked on it and I have to fix it Smile
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Fri Aug 07, 2009 2:26 pm    Post subject: Reply with quote
Hmmmm? Methinks it might be cheaper to wait until you have a bad day on the project...and just buy it from you Laughing
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Fri Aug 07, 2009 3:00 pm    Post subject: Reply with quote
If I don't get this thing done soon. You just might get the project for a really low cost. SHMBO is putting serious pressure on me to get it fixed Sad
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Fri Aug 07, 2009 4:49 pm    Post subject: Reply with quote
Sounds like our "SWMBO's" are related...or at least received the same formal training Very Happy
Jazzmanic
Photos: C-Dancer
PostPosted: Fri Aug 07, 2009 7:23 pm    Post subject: Reply with quote
Sorry guys, clue me in. What does SHMBO or SWMBO stand for. If it's not appropriate for family viewing, PM me. Sad
Peter
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Fri Aug 07, 2009 7:26 pm    Post subject: Reply with quote
Peter
She Who Must Be Obeyed
Jazzmanic
Photos: C-Dancer
PostPosted: Fri Aug 07, 2009 7:33 pm    Post subject: Reply with quote
Thanks Snal! Laughing
Page generation time: 0.0655s (PHP: 69% - SQL: 31%) - SQL queries: 31 - GZIP disabled - Debug on
