white light wiring; both running AND anchor?
PostPosted: Mon Aug 03, 2009 6:38 pm    Post subject: white light wiring; both running AND anchor? Reply with quote
I have an interesting layout. I have the stock, factory Perko anchor light on the front of the cabin top. I also have another 360 degree white light on the top of my radar arch that is wired as the running light. I'd like to make the radar arch light both my running and anchor light, thus eliminating the Perko one on the front of the roof. Possible? If so, how?
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon Aug 03, 2009 6:46 pm    Post subject: Anchor/Running light Reply with quote
Mark,
There is a diode that is between the anchor light switch and the running light switch that keeps power from going to your running lights when the anchor light switch is thrown. My suspicion is that on the running light switch you have wiring for port, starboard and white lights. All you should need to do to get the light on the arch to function as your anchor and running light is to move its wire to the anchor light switch.
Personally, I would leave the wire for the Perko in place, too. That way you could use either light.
The CDory owners manual has a schematic that shows how things are wired.
Steve
(oh, and Hauula boys rule... Smile)
cbull
City/Region: charleston
State or Province: SC
Vessel Name: knot yankee
Photos: Knot Yankee
PostPosted: Mon Aug 03, 2009 7:39 pm    Post subject: Reply with quote
To the best of my limited knowledge the anchor light should not be on under way. should someone think you are moored and not paying close attention there could be a problem.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Aug 03, 2009 8:02 pm    Post subject: Reply with quote
The anchor light acts as the all around white light (which is a combnation of steaming and stern lights) when under way.
We're really getting into the rules and regs today! Wink
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Mon Aug 03, 2009 9:53 pm    Post subject: Reply with quote
Mark, the socket just behind the eyebrow up front and the socket on the arch should be wired the same . You can use one or the other. I always use the one on the arch and have the forward socket capped off. You should be able to put the all around light/anchor light in the arch and control them with the switches on your panel. This is how mine is wired.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
PostPosted: Mon Aug 03, 2009 10:26 pm    Post subject: Reply with quote
That's what I'm aiming to replicate, David. Just one light for both needs and I can cap off the front socket. They are wired seperately. Ask Matt. I'll take a look at wiring diagrams and actual wires once I have some time. Electrical is NOT my forte', even when I work on my cars. I find it frustrating; I think I lack the patience. Confused Thumbs Down
I began thinking about this today. I was in Fisheries Supply and was looking at replacing the bulb with an LED unit, only to realize I had to get this solved before I make a purchase.
PostPosted: Mon Aug 03, 2009 10:28 pm    Post subject: Re: Anchor/Running light Reply with quote
I JUST noticed this..... Laughing Laughing Laughing
Wandering Sagebrush
PostPosted: Mon Aug 03, 2009 11:00 pm    Post subject: Re: Anchor/Running light Reply with quote
I lived up on Kaipaupau Loop back in the early '70s. I wish I could still live there part of the year.
PostPosted: Mon Aug 03, 2009 11:33 pm    Post subject: Reply with quote
Most of the C Dories have a double throw switch. One way, there is power to the foreward red and green running lights, and the all around white light (allowable rather than separate stern and steaming lights in small craft). The other position of the switch, gives power only to the all around white light (anchor position). It is the same light. You can trace out the wiring and see where they go--but as noted they should be the same.
PostPosted: Mon Aug 03, 2009 11:39 pm    Post subject: Re: Anchor/Running light Reply with quote
You and me both. Crying or Very sad
flrockytop
Photos: C-LOVER
PostPosted: Tue Aug 04, 2009 10:04 am    Post subject: Reply with quote
Most of the C Dories have a double throw switch. .
I think that for at least the last couple of years C-Dory has gone with the two sperate switch setup with the diode.
2007 22 Cruiser
Track Me HERE
NA4RR
Roger Rockwell
Pensacola, Fl
PostPosted: Tue Aug 04, 2009 11:49 am    Post subject: Reply with quote
I think all I'll need to do is run the third wire from the front light to the rear light.
Wandering Sagebrush
PostPosted: Tue Aug 04, 2009 12:24 pm    Post subject: Wiring Reply with quote
Mark,
I sent you a PM with a before and after picture of what the wiring should look like. My cell is included if you want to talk.
Steve
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Tue Aug 04, 2009 1:09 pm    Post subject: Reply with quote
Strange my 07 22 has seperate switches for the navigation light and anchor light with the diode.
marvin
PostPosted: Tue Aug 04, 2009 1:20 pm    Post subject: Re: Wiring Reply with quote
Mark,
Steve
Thanks. Steve.
Page generation time: 0.0824s (PHP: 50% - SQL: 50%) - SQL queries: 28 - GZIP disabled - Debug on
