Rub Rail Source
tomherrick
Guest
PostPosted: Sun Jul 26, 2009 10:59 am    Post subject: Rub Rail Source Reply with quote
I'm trying to locate a source for the aluminum rub rail to match the original. After many hours on the Web, the closest I've found is by Taco Marine, but it has a bit of a 'tail' on one inside edge. The inside edges on the original are the same size.
I'd rather not replace the entire lot if I can avoid it. It appears that the current boats use the same rub rail as my old Classic.
Anyone know where I might look for the proper rub rail?
Tom Herrick
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Jul 26, 2009 3:11 pm    Post subject: Reply with quote
Tom,
That is exactly what is on my 2005 ProAngler but I do not know of a source for more of it. The rivets holding it on all broke off so mine is bolted like yours now.
When you find the rubber part please post for others to see.
Jack in Alaska on HIGH TIDE II
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
tomherrick
Guest
PostPosted: Sun Jul 26, 2009 4:51 pm    Post subject: Reply with quote
Thanks, Jack. As soon as I find it I'll post it here unless someone else can point me toward it first.
I hope to have a 26-footer one of these days soon myself, but, out of a 22-footer. That's why I need the rub rail.
Tom Herrick
Page generation time: 0.025s (PHP: 58% - SQL: 42%) - SQL queries: 14 - GZIP disabled - Debug on
