snal
Joined: 13 Aug 2006 Posts: 524 City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
Posted: Fri Jul 24, 2009 10:04 pm Post subject: Fuel flow problem |
Sorry...this is on my pontoon boat.
Engine starts fine, slight erratic idle, idles out fine in gear at 1000-1200rpm with erratic symptoms gone. Throttle up quickly or slowly and it will not throttle past 15-1800rpm. If I put it in neutral...it revs fine! Same in forward or reverse.
At first, the bulb was sucked semi-flat (new bulb...old line)...switched tank flow to reserve (has 3/4 full tank) and the bulb would get full, but not hard. Installed complete new fuel lines, quick connect, and bulb, Nothing changed!
Screen at engine is clean, no other filters. Bulb seems to build pressure, then move fuel...rather than firm up. No line leaks, no leaks at engine, no leaks anywhere.
Thoughts? _________________ Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II" |
Chris Bulovsky
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
Posted: Sat Jul 25, 2009 12:24 am Post subject: |
Open the vent on the tank, point the arrow on the bulb up when squeezing. This will help the one way valves seat. If that doesn't work plug in a totally other fuel supply.( Your buddy's boat tank.) This would tell you if its a fuel supply issue or a motor issue. Also check the engine fuel line connection I know Yamaha's are very fussy and like the factory ones the after markets seldom work for me.
Good Luck
Chris |
Papillon
Joined: 31 Mar 2005 Posts: 949 City/Region: DeBary, Fl. *On the St. John's River*
Vessel Name: Papillon
Photos: Papillon
Posted: Sat Jul 25, 2009 1:11 am Post subject: |
After doing as Chris has instructed ...if you determine it is a fuel delivery problem, then check one additional place...fuel pickup tube (Screen Filter on the end).
Good Luck _________________ Mike Taylor
330-936-1030
Catch 22
Vessel Name: Catch 22
Photos: Catch 22
Posted: Sat Jul 25, 2009 1:12 am Post subject: |
yeah,it sounds like it is not venting fast enough (fuel is leaving the tank faster than air can get in), creating a pull against the flow of fuel _________________ Kevin Richards - Catch 22 |
snal
C-Dory Year: 1994
Photos: Thelma Lou
Posted: Sat Jul 25, 2009 10:01 am Post subject: |
Thanks guys...checked the vent this morning, no restriction found. I'm heading down now to spray some carb cleaner while at idle...checking for air leaks.
Lots of volunteered portable fuel tanks here at the campground, so I'll try that as well. |
snal
C-Dory Year: 1994
Photos: Thelma Lou
Posted: Sat Jul 25, 2009 1:37 pm Post subject: |
Spraying carb cleaner didn't indicate any air leaks, spoke to a local mechanic that instructed me on how to check the engine temp sensor that could prevent the engine from revving higher than 2k rpm...checked out fine.
It's a beautiful day...so all volunteered fuel tanks are currently being used. |
Fun Patrol
Vessel Name: Fun Patrol
Photos: Fun Patrol
Posted: Sat Jul 25, 2009 2:03 pm Post subject: |
If it's sucking the bulb flat you have a clogged screen on the tank pickup.
..Roy |
snal
C-Dory Year: 1994
Photos: Thelma Lou
Posted: Sat Jul 25, 2009 2:49 pm Post subject: |
Fun Patrol wrote: | If it's sucking the bulb flat you have a clogged screen on the tank pickup.
..Roy |
Could be...but I have 2 independent pick-ups in the tank...one main..one reserve...and I switched between them. Still, both could be clogged. The 2 independent pick-up lines share the same switching valve, and I did check the valve. Can't check the separate lines by hooking to them individually because the hoses are larger diameter than the line to the engine.
I've tried 3 different bulbs, so apparently it's not the check valves in the bulbs.
The bulb got sucked flat once during my testing, hasn't occurred again, but the bulb(s) still pump full of fuel...but don't get "firm" like they should. This may indicate at least one stuck float (1995 88hp SPL V4) |
