Cockpit floor cracks
PhilR
City/Region: Albany
State or Province: NY
C-Dory Model: 19 Angler
PostPosted: Tue Jun 30, 2009 3:16 pm    Post subject: Cockpit floor cracks Reply with quote
There are two cracks in the gray cockpit floor covering in my 2008 19' Angler, as if the covering is peeling up. They don't go down into the fiberglass...you can slip a knife blade on the flat under the flooring. They are approx. 12 to 18" long. Any suggestions?
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Jun 30, 2009 3:51 pm    Post subject: Reply with quote
I had a similar problem and the factory sent me some paint but they told me I had to buy the hardener, they can't send it through the postal system apparently. Easier just to go to West Marine and buy some stuff and fix it yourself.
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Tue Jun 30, 2009 4:11 pm    Post subject: Reply with quote
The "hardener" is simply MEK. You can get a pint at Home Despot for cheap, even though you'll likely use only a drop or two. For me, West Marine is a 40 mile round trip. Home Depot - 2 mile round trip. Just don't exceed the proportions recommended. Less in this case is better.
Don
lloyds
PostPosted: Tue Jun 30, 2009 5:08 pm    Post subject: Reply with quote
Good to know, thanks. It's about time I take care of this little chore. In my case the paint didn't adhere well to the sides of the cockpit.
Dreamer
Photos: Dreamer
PostPosted: Tue Jun 30, 2009 5:15 pm    Post subject: Reply with quote
Guys,
MEK is a solvent, not a hardner! The hardner is MEKP, Methyl ethyl ketone peroxide. Good luck with the repair.
Dreamer- Sold 25 Feb. 2013
Sneaks
Vessel Name: C-Brat
Oops, I just realized you're talking two part paint. I know MEKP works with gel coat and fiberglass as a good hardener because I've used it when it was recommended by a local surf board builder. I don't know from personal experience that it's equally effective with two part paint. Best you try it out before committing.
Sorry. I hate to give out hearsay solutions. Confused
Don
lloyds
PostPosted: Tue Jun 30, 2009 5:30 pm    Post subject: Reply with quote
Even better to know. thanks.
BaseCampAnne
City/Region: San Diego/Anacortes
Vessel Name: SEA COASTER
Photos: SEA COASTER
PostPosted: Tue Jun 30, 2009 10:40 pm    Post subject: Good to know...thanks Reply with quote
I also had the gray paint cracking soon after getting my boat. I didn't realize others have had the same problem.
Thanks for the info.
Anne Cox
Page generation time: 0.0738s (PHP: 43% - SQL: 57%) - SQL queries: 21 - GZIP disabled - Debug on
