Stowable generator bracket
snal
City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
PostPosted: Mon Jun 22, 2009 2:32 pm    Post subject: Stowable generator bracket Reply with quote
Fabricated this from stainless angle, flat bar, and perforated stainless sheet. Clips onto the gunnel underneath the lazaret lid (either side) and the lid still latches.
Folds flat to 18" x 20" x 1.5"
Generator shown is a Honda EX700 which is the same physical sie as the EU1000i.
Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II"
PostPosted: Mon Jun 22, 2009 3:24 pm    Post subject: Reply with quote
That puts the generator fairly close to the water line so I presume the intended use is for while at a very calm and very protected anchorage or while on the trailer. Correct?
I also assume that hanging it over the side was done to keep the exhaust low and out of the cockpit. I like the idea, but I am a bit worried about a small wake or similar exposing the generator to water.
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Mon Jun 22, 2009 3:50 pm    Post subject: Stowable generator bracket Reply with quote
Snal,
I'm loving it! Of course some would shorten the drop down for bumpier water. Boating in some areas might require the addition of a lock of some sorts. Great idea, great pictures. Thanks for sharing!
D.D.
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Mon Jun 22, 2009 3:55 pm    Post subject: Reply with quote
Correct...but like you say, it may be too low. We'll be trying it out on the Cumberland river next week.
It currently sits 11" above the waterline, and I probably should fashion some type of box to raise the unit up a bit just in case.
I can easily raise the shelf 6 more inches if need be.
Valkyrie
City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
PostPosted: Mon Jun 22, 2009 4:22 pm    Post subject: Reply with quote
Very nice, Larry! Just I would expect from the guy who fabricated the ingenious rack system that you have on your boat. Marcia and I enjoyed visiting with you and Jo at the NC CBGT last year.
Nick
"Valkyrie"
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Tue Jun 23, 2009 7:32 am    Post subject: Reply with quote
Thanks Nick! We enjoyed visiting with you and Marcia as well!
The rack/enclosure is working well, but as usual, I am finding that I would make a few small design changes if I ever do it again
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Tue Jun 23, 2009 9:51 am    Post subject: Reply with quote
nice job, larry,
now, will it accommodate a honda 2000? when you work out the kinks, how much will this puppy retail for, including delivery to ohio?
pat
YACD
City/Region: Middle River, Chesapeake Bay
State or Province: MD
Photos: F. Silvestris
PostPosted: Tue Jun 23, 2009 10:06 am    Post subject: Reply with quote
Thumbs Up Thanks for this nice idea!
A (not so?) small possibility for the next iteration: perhaps the vertical frame could be shaped like a parallelogram aimed sternwise. That would move the generator exhaust further from the cabin. Suspension of the platform might be tricky.
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Tue Jun 23, 2009 10:40 am    Post subject: Reply with quote
I'd be happy to fab up a few for the members here, but I have no desire turn this into a business venture Laughing
The shelf measures 19.375 x 10.75 (inside the angle frame and support arms) and the EU2000 measures 20.1 x 11.4...it would likely fit since the footprint is slightly smaller.
Mine uses hand made hardware (support arms and gunnel brackets), which is expensive to make, so I'll be looking around for something generic and less expensive.
Mine is a "first-try" and it usually takes me 3 tries to get it perfect, so some changes would be made to improve the design...likely going to aluminum rather than stainless.
I think a vertical parallelogram would work fine if I could come up with a way to allow it to fold flat for storage, and also use similar shelf support arms....hmmmm.
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Tue Jun 23, 2009 6:29 pm    Post subject: Mikey likey Reply with quote
Yeah - Same question, when you get the kinks out I'd like to find out what you'd charge for another. I would think you could bring it up another six inches or so just by cutting the drop down in half so the support arm comes straight off the side. Again, great job!
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Tue Jun 23, 2009 11:17 pm    Post subject: Reply with quote
I like the idea as well. The mount frees up interior space and the geny is out of sight from the cockpit. Keeping it down low would help block some noise. How about a box to protect the geny from a splash? Another idea for the exhaust: It looks like you could clamp on a 3" extention to the current outlet larger diameter. Then clamp on a downpipe when the geny is in position. You might even run it below the waterline like an outboard. Not sure how much bubbles or heat from backpressure might be generated. Some experimentation would tell. But it would get the fumes down low. Solid pipe or flex pipe would work.
It looks like you could easily make two more arms to hold the mount out parallel to the water and then it would make a nice rack to hold any $25 charcoal or gas portable grill. No need to buy those expensive stainless jobs! I like things that are multi-useful.
Chris
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Jun 24, 2009 12:14 am    Post subject: Reply with quote
One other thought -- wonderful design, but screams, "steal me!" So I think some sort of locking mechanism for both genset and bracket would be in order...
Doryman
M/V Lori Ann
Anacortes, WA
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Wed Jun 24, 2009 7:01 am    Post subject: Reply with quote
Chris, the current design will double as a step. I tested it with my (155#) weight yesterday Laughing The 1x1 angle may distort over time with this use.
Warren, I plan to use a bicycle cable lock thru the aft cleat, the bracket's perforated shelf, and the handle of the generator.
All of this great feedback has me thinking that I should post pics of design "drawings" from now on Thumbs Up
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Wed Jun 24, 2009 3:23 pm    Post subject: Reply with quote
Currently fabricating a second design sized for the EU2000i. It will hold the generator 5" higher and still fold flat. Redesigned clips for easier mounting in the same spot. Still stainless.
Valkyrie
Photos: Valkyrie
PostPosted: Wed Jun 24, 2009 5:44 pm    Post subject: Reply with quote
SOLD!!
Nick
"Valkyrie"
Page generation time: 0.0549s (PHP: 52% - SQL: 48%) - SQL queries: 28 - GZIP disabled - Debug on
