Trailer access
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Thu Oct 21, 2004 12:22 pm    Post subject: Trailer access Reply with quote
I need to work on my tandem trailer bunks. Water is too far to drop the boat off. I was thinkin: If I jack one side of the trailer up as in changing a tire, block up the hull of the boat, remove the tires on one side for ground clearance, then lower the jack under the trailer. That should provide access to one side/bunks at a time. Sound too risky? Anybody try this?
Chris
KenMcC
State or Province: NM
Photos: Vivien C
PostPosted: Thu Oct 21, 2004 10:48 pm    Post subject: Reply with quote
Hi, Chris,
Two years ago I had to replace several of the roller arms on my EZ Loader for my 22' Cruiser.
I just took the screw jack from my truck, with stable blocks under it, and took a carpeted 4" X 6" block of wood to use between the hull and the jack. (The hull bottom is incredibly tough, and can handle it nicely).
I cranked the boat up several inches, and blocked the hull up for safety.
Replaced the roller arms, and did the reverse. Worked fine.
The way I did it didn't require messing with the wheels. (Once I loosen the lug nuts on my wheels, it then requires multiple checks {and occasional re-tightenings} for multiple miles, to be assured that they remain tight. Even when torqued @ 95 foot pounds, I need to re-tighten at least three times before the nuts truly get "seated".
Ken
C-WEED
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Sun Oct 24, 2004 9:53 pm    Post subject: Reply with quote
Ken:
Used a 2x6"x4' plank I had laying around. It worked just like another bunk. I got the bunks adjusted and am awaiting the trailer side guides to show up. Then I should be able to launch and retrieve singlehanded without any hassles.
C-Bill
City/Region: Carson City
State or Province: NV
C-Dory Year: 1991
Vessel Name: CharkBait
Photos: CharkBait
PostPosted: Sun Oct 24, 2004 11:56 pm    Post subject: Reply with quote
C-Weed,
I have the side boards on my trailer and I initially thought it would be the one man retrieve answer also. Find some old water-proof chest waders and keep em handy for launching & retrieving your boat. Wink
Bill
C-WEED
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Mon Oct 25, 2004 10:34 am    Post subject: Reply with quote
C-BILL:
I'll keep my fingers crossed for two reasons. One, I hope the side guides work and two, the lashing I'll get from the wife if they don't. Embarassed
C-Bill
C-Dory Year: 1991
Photos: CharkBait
PostPosted: Mon Oct 25, 2004 11:29 pm    Post subject: Reply with quote
C-Weed,
I understand. Rolling Eyes A lot will depend on the wind direction. I'm still trying to invent something just for loading 22ft CD Cruisers. That should make me rich enough to afford Radar (after paying for gas Wink ).
Bill
PostPosted: Tue Oct 26, 2004 1:33 am    Post subject: Reply with quote
just an idea. I see and hear a lot of people struggling with the loading and unloading of their boats. first, i have never owned a boat over 20 ft but have owned and operated a lot of boats, of different types, under 20 ft in the last 30 years and ian only 39. most people just put to much of the trailer in the water. i was taught at a young age to always drive the boat on to the trailer. wind and current do not matter at all if the boat is slide "on to the trailer" instead of "over the trailer" why would anyone try and hold a boat in position over, some times 3 ft over, a fully submerged trailer. my wife backs the trailer half way in and i drive the boat on to the trailer. the front of my boat will be resting on the bunks when my bow is a ft or so from the wench and front roller. then a little gas will slide the boat up the last foot and the back of the boat will be firmly resting on the trailer. a quick snap of the wench cable and the wife will pull the boat out of the water centered on the trailer every time . I do not even have side rails on my trailer. Its just a matter of practice and team work. I recommend walkie talkies in the boat and truck while loading. much better then screaming. this method is quicker and easier then the way i see most ppeople do it. it can be done wrong, and often is. do not try and power up the last 10 feet of trailer , this is both bad for your boat and the launch
PostPosted: Tue Oct 26, 2004 2:15 am    Post subject: Reply with quote
I have to disagree just a little here. For one thing, once the ThunderJets hit the north Oregon coast ramps, most of the marinas put signs up forbidding powering onto the trailer (or the back of the tow rig, as was too often the case!). Secondly, I really suck at hitting the middle!
I launched and retrieved my 22CD single handed 90% of the time, and do the same with the 25CD. To retrieve, I back the trailer deep enough to let me float the boat within 2' of the bow stop. Then I step up on the tongue, hook up the strap, and winch it home with very little effort. I usually have a dock next to the ramp I'm using, so I walk over to the side of the boat, put a hand towel folded four times between the side guide and the hull, and pull the boat tightly against it. If I have placed the trailer just right, the friction of the carpeted bunks holds the boat tight against the towel while I pull up the ramp. Done. Perfectly centered. B~C has even made some ingenious carpeted spacers to hang on the side guides. Me, I'm happy with the towel, which I don't even need to dry my feet because I have yet to get them wet.
Fred showed me with his 22CD how he doesn't even have to worry about centering it before pulling up the ramp. He knows just where to put his shoulder to scoot the rear of the hull over while sitting on dry land.
Les said something once to a gentleman who was reluctant to dip his trailer hubs in the water and preferred to use a power winch to drag the boat up. He said the wheel bearings cost 35 bucks every couple of years, but the little bitty eye on the bow is bolted through a $40,000 hull. Back it in and make it easy. To take that a little further, Bearing Buddies cost less than the bearings, and if they are properly used, the bearings will last even longer.
C-WEED
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Tue Oct 26, 2004 10:19 pm    Post subject: Reply with quote
Starcrafttom:
I understand what your saying. Some of my delima is a wife that refuses to learn to drive a manual shift truck. Getting her to back a trailer is just unheard-of... I was raised to never drive a boat on a trailer. Anyway I have to back the trailer, then drag the boat from the dock. When I push the boat out deep to get it started up the trailer, this is where I need control of the stern and I don't have it. Then there is the bunks on the used rig I bought that aren't adjusted quite right. When you winch the boat up tight the bow wants to pull to one side slightly. The carpet is worn on the bunk edges and needs replaced. The ramp that I use is too steep. Get the trailer in far enough to float the front half off and the trailer is several feet below the stern. And I am always hit by a 90 degree crosswind when loading. Soooo when loading the relatively flat bottom boat there is not much of the back 2/3rds of the hull to even keep the boat from drifting over a sharp trailer corner has I pull out of the water. When centered on the trailer the lower stern corners are just inches from the trailer frame. I have loaded many deep vee hulls and they seem to almost self center as you pull out of the water. I am more than confident that the side guides will allow me to load in any weather with MUCH less hassle.
C-Bill
C-Dory Year: 1991
Photos: CharkBait
PostPosted: Tue Oct 26, 2004 11:45 pm    Post subject: Reply with quote
C-Weed
I took my wife to an empty parking lot with the boat in tow and let her gain some confidence with backing the rig up. It take a lot of time and patience, but it can be done. Go slow. At some point in time, she may have to do that without your assistance.
Bill
PS - She can also be a lot of help centering the boat with a boat pole or rope attached to the stern. The problem is like you say, with a nearly flat bottom. With side boards, that boat will still twist between the rails. If you have the distance between bunks to put a wide keel roller, it would be ideal as it would capture the keel as it was being winched onto the trailer and keep the boat straight.
PostPosted: Wed Oct 27, 2004 12:24 am    Post subject: Reply with quote
c-bill is that a yamaha 2 stroke on lake tahoe?? . we live in washington but we are from placerville. never toke my boat to tahoe becouse of the ban, is it a don't ask don't tell thing?????
C-Bill
C-Dory Year: 1991
Photos: CharkBait
PostPosted: Wed Oct 27, 2004 12:51 am    Post subject: Reply with quote
Those pictures were taken before the ban. I still have the same motor and I like it and I'm stubborn. I've heard the samething about the "Don't ask, don't tell." I quit fishing when the ban became effective. The fine can be very expensive!!! I'm still very ticked off at Steve Wynn (Mirage Casino, LV). As you have probably heard, it all started over the personal watercraft running up and down the lake adjacent to his then owned property (He no longer has property at Tahoe).
As soon as he started complaining about the noise from the PWC, I knew my days were numbered. I had high altitude jets and was not the polluter that many of the boats from near sea-level are that are brought up from down below, including inboards that still operate on the lake.
I did have many enjoyable days on the lake before I was banned.
Bill Evil or Very Mad
PostPosted: Wed Oct 27, 2004 11:11 pm    Post subject: Reply with quote
be warmed by the fact that when 4-stroke jet skis came out and were allowed on tahoe, many people made it a piont to circle in front of his house... in the morning...every day...till he moved.
C-Bill
C-Dory Year: 1991
Photos: CharkBait
PostPosted: Wed Oct 27, 2004 11:36 pm    Post subject: Reply with quote
Tom,
Thanks! Laughing I may consider a four stroke one of these days, but not yet. I really enjoy fishing the ocean and I'm very concerned with weight back near the transom. I've been on the ocean in some nasty conditions. My boat does a good job of handling it in the present configuration. The 22ft Cruiser was designed for 14 knots and the hull design will perform well with the proper distribution of weight. Here is a good picture of my boat from the rear. Picture taken by Sea Wolf Oct 9, 04 at Lake Shasta.
Bill Very Happy
Otter-BelleHavenMarina
City/Region: Alexandria
Vessel Name: Otter
Photos: Otter
PostPosted: Thu Oct 28, 2004 12:28 pm    Post subject: Reply with quote
Am not sure what the concern is about driving the boat onto the trailer. For me, the key is positioning the trailer just right: forward bunks just peeking out of the water at the front. Then I go to the boat, start her up, and slowly advance on the trailer until the bow slides in between the forward bunks and comes to a stop. Goose the throttle just a bit to slide forward on the bunks a few inches, turn off the engine, and raise the motor. The bow ring will still usually be about a foot to 18 inches away from the bow stop. Attach the cable and crank her up the rest of the way, nice and centered, no trailer guides necessary.
Believe me, it took me a while to get this right, but I just got sick of having the boat drift to one side or the other other over one of the wheels.
Tom on Otter
Page generation time: 0.048s (PHP: 69% - SQL: 31%) - SQL queries: 28 - GZIP disabled - Debug on
