Jim Gibson
Joined: 21 Feb 2006 Posts: 623 City/Region: Sacramento
C-Dory Year: 1998
Vessel Name: Pounder
Photos: Pounder
Posted: Thu Jul 26, 2007 1:15 pm Post subject: Fuel Capacity and Weight for 22 Foot Cruiser |
I currently have 2-18 gallon tanks and carry 3-5 gallon jerry jugs for back-up when needed, giving me 51 gallons total for gasoline. I know the newer models have two 25 gallon tanks, giving them the same 50 gallons.
I am interested in any 22 footers that have increased their fuel capacity to approximately 100 gallons for extended range and how they did it. Has anyone custom fabricated 25 gallon saddle tanks on each side of the stern of their C-Dory?
I am interested in the weight effect of adding another 50 gallons to the rear of the boat. I think I remember that gasoline weighs less than water which weighs about 8 pounds per gallon. Say gasoline weighs 6 pounds per gallon, then adding another 25 gallons to each side of the vessel would add 150 pounds to each side, and 300 pounds in total. Will the little 22 foot C-Dory realisticly take this extra fuel weight safely and functionally.
I am interested in possibly maximizing my potential cruising range for a future dream cruise. I cannot remember if Red Fox really beefed up his fuel capacity or range and how he did it? _________________ Jim on M/V Pounder
And the C-Tales Continue |
Bearbait
Joined: 28 Mar 2005 Posts: 151 City/Region: North Pole
C-Dory Year: 1991
Posted: Thu Jul 26, 2007 2:45 pm Post subject: |
I put in the 25 gal tanks and carry extra 15 gal drums. The 15 gal drums are as big as I can easily pick up and put on the lazzerette hatch to siphon into the tanks. The nice thing about the drums is as soon as I have room in the tanks I empty them and store them in the dinghy, out of the way. |
Joined: 02 Nov 2003 Posts: 21385 City/Region: Pensacola
Posted: Thu Jul 26, 2007 5:34 pm Post subject: |
With saddle tanks the weight would be slightly foreward of the current tanks. The problem is not just the weight of the gasoline, but all of the cruising gear which we all carry when we do long cruises. But it certainly appears that many folks carry at least 90 gallons, and I don't think that the gas alone is a problem. _________________ Bob Austin
tpbrady
Joined: 08 Feb 2005 Posts: 891 City/Region: Anchorage
Vessel Name: Bidarka II
Photos: Bidarka
Posted: Thu Jul 26, 2007 6:06 pm Post subject: |
My long range plan (Homer to Seward) is based on this loading:
Two five gallon jugs on the bow
Two five gallon jugs on the roof tied to the radar arch
Two five gallon jugs in a garbage can in the cockpit
Not counting the 6 gals in the kicker tank that is 80 gals. At a plan average burn rate of 3.5 mpg that is 280 miles.
Tom _________________ Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981- |
oldgrowth
Vessel Name: C-Voyager
Photos: C-Voyager
Posted: Fri Jul 27, 2007 12:38 am Post subject: |
Jim - I do not have a 22 foot C-Dory but made two 22 gal saddle tanks for my stretched 16 foot C-Dory and it helps with the balance of the boat and gives me a 300+ mile cruising range. My saddle tanks start a few inches inside the cabin and extend to about 16 inches from the stern. If your saddle tanks are in the forward portion of the deck, the boat should handle it nicely. If they are in the stern, it may put too much weight in back.
________
Dave  |
Casey
Joined: 02 Nov 2003 Posts: 1094 City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
Posted: Fri Jul 27, 2007 9:44 am Post subject: |
I fabricated a "roof rack" that accommodates four 6-gallon tanks, and attached to the topside handrails. It didn't rest directly on the roof, the weight was distributed to the handrails (sturdier than the center portion of the roof). The rack was constructed so it simply bolted-on, and could be easily removed.
Initially I thought about designing the rack for two 12-gallon containers. Due to the difficulty in transferring fuel from the larger containers, I finally opted for the 6-gallon jugs.
Interestingly, having that much weight considerably higher, I was expecting a change in the center-of-gravity which might increase Naknek's roll tendency. Didn't happen. I suspect the fairly flat hull on the CD22 really helped in that regard.
Sorry, I haven't found any picture's of the project. I suspect there might be some (ie. Wanderer's Inside Passage program...) somewhere.
Casey
C-Dory Naknek
Lake Montezuma, AZ |
Jim Gibson
C-Dory Year: 1998
Photos: Pounder
Posted: Fri Jul 27, 2007 11:54 am Post subject: |
Thanks all for the good input. That is especially impressive to me what Dave did with his 16 foot C-Dory on his saddle tanks. That is good advice to try to move the tanks as far forward on the sides as possible. |
Joined: 07 Nov 2003 Posts: 7932 City/Region: marysville
Posted: Fri Jul 27, 2007 3:24 pm Post subject: |
I saw daves saddle tanks at bellingham. They looked great and moved the weight forward. I would like to do the same for my 22. Not for the extra fuel, but for the extra storage when I remove the old tanks. I want to turn the tank area in to a storage area for fishing gear and large bulky light weight items. What i need to be able to figure out is how to make the tanks, I don't weld alum, How much they will hold given the room I have and how to mount them. I would be happy to get some of the weight off the stern. My fishing buddy alex, he's a custom cabinet builder in the seattle area, would be able to build two large drawer in that space on rollers. Lots of extra room there that could be used by moving the tank. and all my fishing gear weights less then the 40 gallons of fuel. _________________ Thomas J Elliott
Alasgun Guest
Posted: Fri Jul 27, 2007 4:17 pm Post subject: Fuel capacity and weight for a 22 ft cruiser |
This is purely imaginative, but have any of you thought of building narrow tall tanks? 25 gal of fuel = 3.342 cubic feet. I would think tanks that went from the cockpit floor up to the bottom of your 2 rear windows and from the sides right up to the cabin door would give a good increase in capacity. The overall thickness of the tanks would be limited by the wall space behind the open door. They could easily be made "temporary" and removed when not on one of those longer voyages. Weight is centralized too.
My 25 ftr has an opposite problem, I will never need anywhere close to the 100 gal. it holds. Once I get motivated and moving on the motor bracket project, I have considered thinning my tank down some in order to lower the cockpit floor 3 or 4 inches!
Mike |
Jim Gibson
C-Dory Year: 1998
Photos: Pounder
Posted: Fri Jul 27, 2007 5:59 pm Post subject: |
Thomas-
I totally understand what you are thinking. Yes moving fuel to saddle tanks really opens up valuable room in the back, and substitutes realitvelty dead space use for the fuel. In a small boat such as the 22 foot, layout is everything. That is probably why the 16 foot guy took the initiative here because space is even scarcer to them. Also, I think I saw some of the very old original C-Dory's with saddle tanks, if I remember right.
Sincerely,
Jim |
Casey
Photos: Dessert 1st
Posted: Fri Jul 27, 2007 7:50 pm Post subject: |
...interesting how comments (ie. Mike's comment, above) sets one to thinking:
If you put a saddle-type tank along each side, and made them somewhat wider - you could turn the top of the tank into a full length "step" for boarding or exiting your boat!
Hmmmmmm..............
Casey
C-Dory Naknek
Lake Montezuma, AZ
...the place that damn near got flooded-out an hour ago! |
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
Posted: Fri Jul 27, 2007 11:02 pm Post subject: |
That is an interesting idea...the space under the gunnel down to the deck
is largely wasted on a CD-22 anyhow...
I'd love to stick with the "plastic" - wonder what volume we would end
up with...
Be nice to go with saddle tanks amidships. Our deck chairs and
cooler fit right along the back, and of the course the door towards
the bow....
Mike |
Chester
Photos: Chester
Posted: Sun Jul 29, 2007 12:19 am Post subject: Re: Fuel capacity and weight for a 22 ft cruiser |
Alasgun wrote: | I have considered thinning my tank down some in order to lower the cockpit floor 3 or 4 inches!
Mike |
Um, might that turn the self bailing cockpit into a self filling model?
just sayin' |
Alasgun Guest
Posted: Sun Jul 29, 2007 9:39 am Post subject: Fuel Capacity and weight for 22 ft cruiser |
I guess Milehog's statement has some merit and with out thinking ahead your right, you would loose your bailing abilitys.
Look at all the other upgrades applied to my boat and you will soon discover that I am not the kind of guy who doesn't know whether to wind his a-- or scratch his watch.
Mike  |
Chester
Photos: Chester
Posted: Sun Jul 29, 2007 1:40 pm Post subject: Re: Fuel Capacity and weight for 22 ft cruiser |
Alasgun wrote: | Look at all the other upgrades applied to my boat and you will soon discover that I am not the kind of guy who doesn't know whether to wind his a-- or scratch his watch.
Mike  |
Easy there big fella, nobody's calling you a fool.
The "just sayin'" in the second line of my post is sorta like a rolleyes smiley, a tounge in cheek kinda thing.
Well, gotta go, I think I may be sittin' on my watch. |
