Bilge Pump
Nunya
Photos: Nunya
PostPosted: Wed Jun 10, 2009 11:02 am    Post subject: Bilge Pump Reply with quote
Seems I read somewhere on the forum about wether the area where the bilge pump is mounted in a 25 CD, was solid fiberglass or cored. My pump froze up on my last outing and while changing it out, I discovered that the area is cored. The four SS screws holding the base down were not sealed and there was a dab of sealant underneath the base?? I drilled out holes and potted with epoxy. This area seems to always have standing water, even after re-enforcing the deck hatches. I suggest everyone check this area out and make sure the screws are at least sealed.
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Thu Jun 11, 2009 3:43 am    Post subject: Reply with quote
I was just looking at my bilge pump today and wondering how well it was sealed up when it was screwed to the bottom of the boat hull. Will investigate that tomorrow.
Two battery boxes, in the same compartment, were screwed down that way also but I removed them to a higher compartment. Those holes were sealed with a dab of 5200 under the boxes. I put 5200 amply into the holes with a toothpick and around the holes and then put the screws back in. That is not up to Dr. Bob's standards but is good for now.
Has anyone just glued the bilge pump down with 5200 or 4200 with any success.???
Good news today.........I drilled into the outside of the transom near the bottom to mount a piece of starboard for a transducer mount. I was concerned on what I would find in the wood. Well it was nice clean,dry wood. No water or sign of it. Those 3 small holes were sealed extremely well. Very Happy
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Thu Jun 11, 2009 7:42 am    Post subject: Bilge Reply with quote
I think we might have the same issue with Tomcat's. It's already on my list for a winter project.
Captain Matt
PostPosted: Thu Jun 11, 2009 9:39 am    Post subject: Re: Bilge Reply with quote
In the meantime, you can let your arms grow about 18" and also sprout another hand on each one so you can reach them and handle tools way down there! Rolling Eyes
Then you can come do mine! Laughing
Noreaster
City/Region: Wallace
Vessel Name: Nor'easter
Photos: Nor'easter
PostPosted: Thu Jun 11, 2009 5:28 pm    Post subject: Reply with quote
I replaced my bilge pump this spring with Devcon 5 minute epoxy smeared on the bottom and it is holding just fine. I really only installed it that way because the factory had installed the origional pump the same way. I just roughed up the area and the base of the pump with some 60 grit sand -paper , cleaned up the bottom of the pump and the bilge area with some isopropyl and it has been in ther solid since early April.
Lenny
Jack in Alaska
PostPosted: Fri Jun 12, 2009 2:11 am    Post subject: Reply with quote
Today I unscrewed the bilge pump from the hull bottom. As I suspected it had been installed by a total "nimrod" that did not have a clue.
Little or no sealant under the base and an unused screw hole under it also.
I sealed it all up and reset the pump using the same holes.
The wiring to it was also relocated so as to keep them above the bilge water.
How can one prevent things like this from happening? Getting water into the hull bottom is not a pretty thing to deal with.
PostPosted: Fri Jun 12, 2009 9:04 am    Post subject: Reply with quote
Jack, one can prevent it by installing things that penetrate the FG into the core properly as described many times on this thread. Hopefully the new owners of C-Dory are watching closely, IMHO this is one of the best production changes they could make Idea as they manufacture their boats. I wonder how Sea Sports fasten their things into the hull... Anyone know? Question
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Fri Jun 12, 2009 10:37 am    Post subject: Seal Reply with quote
I agree Charlie.
As we have learned, manufacturers (nor electronics installers) do this properly. It would definitely take more time and cost more, but well worth it.
Nunya
Photos: Nunya
PostPosted: Fri Jun 12, 2009 11:24 am    Post subject: Reply with quote
Makes me wonder are there any other screw penetrations under the rear deck. My fresh water pump was also screwed down into hull with no sealant on the screws. I moved pump up along side battery and filled screw holes in hull with epoxy.
Has anyone removed their rear deck? How is the fuel tank held down?
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Fri Jun 12, 2009 11:48 am    Post subject: Sealing Reply with quote
This topic can drive you nuts...stanchions, cleats, etc., etc. I think the greatest danger is of course where there may be standing water.
designbug
City/Region: Annapolis
State or Province: MD
Vessel Name: Bella II
PostPosted: Fri Jun 12, 2009 12:00 pm    Post subject: Reply with quote
Hi All,
I'm concerned about this issue. My 2007 CD25 is in the water here in Annapolis all year and there is alway some water in the bilge area. Last summer I moved the water pump up onto the battery shelf - which has worked very well, but I left the mounting screws on the bilge floor. I had a lot of trouble getting to the mounting screws but I was able to tighten them down with the rubber footings in place. I am hoping the rubber footings would help prevent water from getting into the core.
My question is - do I have a potentially serious problem? I haven't even checked out under the bilge pump! I'm not that handy and feel very uncomfortable drilling out holes in the botton of the boat to fill with epoxy.
Any suggestions would be appreciated.
Thanks, Dick
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Fri Jun 12, 2009 12:34 pm    Post subject: Reply with quote
I thought -- but may well be wrong -- that the bottom of the hull is solid fiberglass but the vertical areas such as the transom are where they start using the core stuff. I do know they do not use core throughout the boats. I also know that the question of where the core is, precisely, can sometimes only be answered with a cross-section of the hull -- there are a couple of photos in the albums showing a hull cross-section from the factory. I have also heard that the location of core in a specific model varies from year to year, according to the design at that time.
Would appreciate confirmation of the above.
Doryman
M/V Lori Ann
Anacortes, WA
Nunya
Photos: Nunya
PostPosted: Fri Jun 12, 2009 1:00 pm    Post subject: Reply with quote
Designbug,
It's not a big deal to epoxy a screw hole closed. Just drill into it with a 1/4" bit about a 1/4 ~ 3/8 of an inch. Fill with epoxy and your done. All screw holes need to be filled. If you're going to put a screw back in, it will need to be potted a little deeper than the screw is long and undercut. This is easy to do, once you do one. There are instructions on the forum on how to do it. Do a search for "potting" should get you there. Boats that are stored in cold weather (freezing) definately do not want water in between the inner and outer hulls.
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Fri Jun 12, 2009 1:32 pm    Post subject: Epoxy Reply with quote
designbug wrote:
Hi All,
Thanks, Dick
Dr. Bob was kind enough to put together a great reference on how to do this:
http://www.commercialcaptains.com/Articles/Proper_Sealing.pdf
Catch 22
City/Region: Lynnwood
Vessel Name: Catch 22
Photos: Catch 22
PostPosted: Sat Jun 13, 2009 4:16 am    Post subject: Reply with quote
i made a thin aluminum bracket that i mounted the bilge pump plate to, then the bracket runs up the transom about a foot and screws in there, so the penetrations are not where water will ever be sitting, also with my transom box, it make for much easier access to the pump, since it sits about 4 inches below the bottom of the box....
Kevin Richards - Catch 22
Page generation time: 0.058s (PHP: 53% - SQL: 47%) - SQL queries: 28 - GZIP disabled - Debug on
