Trailer bounce empty
Larry Patrick
City/Region: Dallas
Vessel Name: Sea -Jo
PostPosted: Fri Oct 09, 2015 7:10 pm    Post subject: Trailer bounce empty Reply with quote
Drove the trailer 2.5 hrs to pull boat out. Seems to vibrate some and feel jumpy guess word to describe it. After weight of boat its fine. Wondering if I should try different ball heights for empty trailer? ,want to get it to drive empty and handle better. Is it common for empty trailers to feel like that? Next season will be driving it empty for 5 hrs from Lake Erie.
PostPosted: Fri Oct 09, 2015 7:21 pm    Post subject: Reply with quote
Bounce sounds normal. It's designed to haul the boat, not be empty The spring rate is high for the boat, not the empty weight. The other thing is to make sure the brakes are broken loose and the wheels are turning.
The trip isn't going to hurt it. It'll bounce no matter what you do.
RobMcClain
City/Region: Summerlin, NV
State or Province: NV
Vessel Name: Freedom
Photos: Freedom
PostPosted: Fri Oct 09, 2015 7:54 pm    Post subject: Reply with quote
As we leap frogged the boat and trailer cruising up the East Coast last year, several times we towed the trailer empty to the next location. This meant driving several hours. Yep, it bounced often but generally rode fine. I did, however, notice that eventually one of the long bunks broke lose from several of the bolts that had been holding it down. As a result, we had to replace the bunk since it was old and had started to decay where the screws were located. So be sure to check the bunks periodically. They may look properly positioned but physically try to lift and move each bunk to assure it is tightly secured. This will add to your piece of mind. It will also assure no bunk unknowingly starts to float and/or move position while the trailer is in the water.
Rob
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Fri Oct 09, 2015 8:31 pm    Post subject: Reply with quote
A few weeks ago we towed the trailer (empty) from FL back up to NY to retrieve "Dessert 1st." I was wondering if the trailer would jump around, so I dropped the tire pressure from 50psi (max) to 40psi.
The trailer towed fine, but frankly I'm not sure if dropping the pressure was warranted of not, but it worked.
Prior to reloading the boat we increased the pressure back to 50psi.
Best,
C&M
PostPosted: Fri Oct 09, 2015 10:39 pm    Post subject: Reply with quote
Lowering the tire pressure is a good trick. If you have a tandem axle trailer, another trick you can do for a long tow, is to raise one axle of the ground and chain it up. run the chain over the bunk board and it will help keep that from jumping around. Lifting the axle will add weight and decrease the "jumpiness". My preference is to lift the front axle. Puts more weight on the hitch, and lengthens the steering base. If you only have brakes on one axle I would lift the other one.
Dreamer
Photos: Dreamer
PostPosted: Sat Oct 10, 2015 1:20 am    Post subject: Reply with quote
Making sure the tires are balanced well helps too
Dreamer- Sold 25 Feb. 2013
PostPosted: Sat Oct 10, 2015 9:14 am    Post subject: Reply with quote
Also, the trailer itself has a lot of flexibility which adds to that "bounce". The boat, tightly secured gives the trailer more rigidity. Most trailers bounce empty. Lighter weight can be worse. The roads now days can be rather rough with cracks, etc.
Grumpy
City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
PostPosted: Sat Oct 10, 2015 10:16 am    Post subject: Reply with quote
And if you have electric over hydraulic brakes, back off the boost otherwise you can leave a lot of expensive blue smoke behind you if you have to brake even fairly hard.
Very effective with tailgaters Smile
M
Larry Patrick
City/Region: Dallas
PostPosted: Sat Oct 10, 2015 12:03 pm    Post subject: Reply with quote
Thanks sounds normal after hearing replys,will try lowering pressure next trip.We have Electric over hydraulic brakes,have lowered it to 5 when empty.Ask a question get a lot of good answers on this site.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Sat Oct 10, 2015 9:30 pm    Post subject: Reply with quote
Welcome to the "bounce your empty trailer club".
I had an Eagle steel triple axle trailer that did not bounce when being
towed unloaded. It was solid as a rock loaded or unloaded..
My current Venture aluminum tandem does bounce at 35 - 45 mph
unloaded but then calms down.
Why? I don't begin to know the answer. And, I'm OK with that.
Aye.
Grandma used to say, "Some things you were not meant to understand."
and
"It is what it is."
williwaw
City/Region: Portland
Vessel Name: Williwaw
Photos: Williwaw
PostPosted: Sun Oct 11, 2015 8:13 pm    Post subject: Reply with quote
As said earlier, try balancing the wheels as they're often not balanced on boat trailers. On my trailer it made a significant difference when towing empty.
BRAZO
City/Region: Full-time Travel
Vessel Name: Meyer Meyer
Photos: BRAZO
PostPosted: Sun Oct 11, 2015 9:07 pm    Post subject: Reply with quote
We took our empty trailer 2000 miles from Blaine WA to Wisconsin and had no bounce. Not sure why but it was something that I was worried about and it never happened.
2008 CD22 Twin 50hp
Pandy Girl
City/Region: Westfield, NC
Vessel Name: Pandy Girl
Photos: Pandy Girl
PostPosted: Sun Oct 11, 2015 11:05 pm    Post subject: Reply with quote
I agree with others I have our Wheels Spin Balanced & I do not any bounce unless I hit a Pot Hole Jim
Pandy Girl
PostPosted: Sun Oct 11, 2015 11:25 pm    Post subject: Reply with quote
A lot depends on the roads. Many interstates have concrete segments, which with time sink/raise, and especially in the S. to Mid USA, you are going to have empty trailer bounce! You get full vehicle bounce!
Larry Patrick
City/Region: Dallas
PostPosted: Mon Oct 12, 2015 5:13 pm    Post subject: Reply with quote
Will get tires balanced also. When driving our Lance truck camper on some roads you feel like your riding a bronco,it starts porposing in front. We have struts that go from nose of camper to hood of truck which helps a lot.
Page generation time: 0.0525s (PHP: 57% - SQL: 43%) - SQL queries: 29 - GZIP disabled - Debug on
