Air Conditioning - AGAIN !
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Sat Apr 11, 2009 8:05 pm    Post subject: Air Conditioning - AGAIN ! Reply with quote
For those of you who have installed a roof top A/C - How did you cut the hole, and how did you wire it ?
Would you recommend a jig saw, or rotozip?
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
Dreamer
Photos: Dreamer
PostPosted: Sat Apr 11, 2009 8:47 pm    Post subject: Reply with quote
Dave,
If you look at the "Thataway" album, you'll find Bob's well thought out and executed installation of a rooftop A/C. The original thread had detailed instructions.
Dreamer- Sold 25 Feb. 2013
eNORMous
City/Region: Beaufort
Vessel Name: Antibody
Photos: Antibody
PostPosted: Sat Apr 11, 2009 8:53 pm    Post subject: Reply with quote
I've cut a number of large holes through gelcoat, glass, etc. Other than the size/type/location of hole (e.g. enough working room to accomodate the saw is often the largest obstacle), I prefer a jig-saw. Two considerations for the jig-saw:
(1) Employ the fastest (highest rpm) jig-saw you have or borrow one; and, (2) use only the absolutely smallest toothed jig-saw blade you can accomodate in your jig-saw (something along the lines of a very fine-tooted metal blade). Under no circumstances use a wood (large serrated course-toothed) blade.
Two considerations for the drilling of the hole itself:
(1) Consider the size and the weight of the roof piece which will obviously be falling and separating from the roof. Be careful - you don't want the piece you are removing to rip away from you under its own weight and tear off from the roof (this would be a bad thing). Therefore, consider drilling two pilot holes and making your cut in two, divided into sections, or ensure someone is below to support the piece as you finish the last cut to catch the piece from ripping off and damaging the roof; (2) Take some heavy mil clear plastic and outline your area from under the roof with plasitc secured to the ceiling of the cabin to catch the dust and debris.
You will find by using the finest blade and fastest (highest rpm) jig-saw you can use will leave remarkably very little dust when you're finished. The line will be incredibly tight. The rotozip, well, my experience is you'll be completely covered and it's quite the mess.
m2cw
I am what I am & that's all that I am & there ain't no more.
E Pluribus Normus
PLB Beacon ID: 2DCE5DE29CFFBFF
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Sat Apr 11, 2009 9:08 pm    Post subject: Reply with quote
I like a Stihl with a 3 foot bar .....
Marc
Wefings Marine Website
Since 1909
eNORMous
Photos: Antibody
PostPosted: Sat Apr 11, 2009 9:10 pm    Post subject: Reply with quote
Mr. Green
Yes, and a belly of Beer with a fine Cigar
toyman
PostPosted: Sat Apr 11, 2009 10:36 pm    Post subject: Reply with quote
Some of the suggestions are great - some cause me to produce work like this http://www.c-brats.com/viewtopic.php?t=11186&highlight= this is the voice of experience speaking !
Page generation time: 0.0446s (PHP: 62% - SQL: 38%) - SQL queries: 23 - GZIP disabled - Debug on
