Kicker - Too Long
hank schneider
City/Region: blowing rock
Vessel Name: Ditch Witch
Photos: Ditch Witch
PostPosted: Mon Apr 06, 2009 11:42 am    Post subject: Kicker - Too Long Reply with quote
Hello Brats
The Kicker with a 20" shaft I bought on E-bay turns out to be a 25". It looks like the Prop Cavitation plate will end up a few (3) inches below the bottom of the boat. Can the brackets which raise and lower kickers be used in the up position to get the motor up a little or is there somekind of locking mechanism when down?
Thanks
Hank
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Apr 06, 2009 12:03 pm    Post subject: Reply with quote
Depends on the bracket, but many of them will lock at intermediate positions.
On a kicker motor, being a few inches too deep won't negatively affect anything.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
PostPosted: Mon Apr 06, 2009 12:50 pm    Post subject: Reply with quote
Yes, the brackets can be used in the up postion, and most which are adjustable, can be used in any position, even though they do not have a true "Lock". The problem with the longer shaft, is that it may drag in the water when the motor is locked "up"--
Having the cavitation plate 3" below the hull is not a problem, and may give cleaner water to operate in.
Page generation time: 0.0213s (PHP: 62% - SQL: 38%) - SQL queries: 16 - GZIP disabled - Debug on
