CREWING A KICKER TO TRANSOM
hank schneider
City/Region: blowing rock
Vessel Name: Ditch Witch
Photos: Ditch Witch
PostPosted: Sat Apr 04, 2009 5:14 pm    Post subject: CREWING A KICKER TO TRANSOM Reply with quote
Hello Again
Got my 9.9 Honda Kicker. Will not fit over my transom. Can I remove the bolt and screw it to the transom? It was described as a 20" shaft but it seems to sit a little low - might be a 25". I can build up a mount which will raise the motor and allow for mounting. Any Photos of what folks have done?
Thanks again
Hank
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Sat Apr 04, 2009 5:30 pm    Post subject: Reply with quote
Hank
My 9.9 Yamaha kicker sits on a mini jack plate bolted to the transom on the port side. Raises the motor up about four inchs and back about two and a half inchs. Sorry dont have pictures
Chuck
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Sat Apr 04, 2009 6:13 pm    Post subject: Reply with quote
If you go to "Our C-Dory's" at the top of the page ,
go down to #54 Anita Marie
double click on Anita Marie
Then open the photos "Anita Marie"
The first sub album is "Sucia"
The first picture shows a starboard mounted kicker on a fixed plate
not mine, and a bigger boat, but that's what it looks like
another view lower on page "Robin from stern 2"
If you take something like a long 2x4 and hold it to the boat bottom where the kicker will be mounted. That plane is about ideal as a goal for the level of the first plate above the prop. An inch or two lower won't hurt performance at all, you'll just hit bottom in 2" deeper water than perfect.
The further you go back the further you can come up from that plane,
maybe 1/2" per inch back.
Chris
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
PostPosted: Sat Apr 04, 2009 8:00 pm    Post subject: Reply with quote
Well, Hank, you get to mount your kicker as you wish, but a lot of people use a Garelick outboard mount as shown:
This allows one to do a lot. Obviously one can raise and lower the motor with the bracket. The upper position keeps the motor out of the water. We use the lower to load the motor when we launch Journey On, and when we drive Journey On with the small outboard. We also use the lower position when we transfer the motor to the dingy as shown here:
The one shown is what the factory gave us, and it's gone up in price, but is a good one.
eNORMous
City/Region: Beaufort
Vessel Name: Antibody
Photos: Antibody
PostPosted: Sat Apr 04, 2009 10:27 pm    Post subject: Reply with quote
As Boris indicated, lots use the Garelick. Here's a picture of mine (after market attachment mounts).
Link to full size image:
http://www.c-brats.com/modules.php?full=1&set_albumName=album902&id=CIMG0416resized&op=modload&name=gallery&file=index&include=view_photo.php
I am what I am & that's all that I am & there ain't no more.
E Pluribus Normus
PLB Beacon ID: 2DCE5DE29CFFBFF
cemiii
City/Region: Alamo
PostPosted: Sat Apr 04, 2009 11:04 pm    Post subject: Reply with quote
Boris and Norm, do you both trailer your boat regularly on the Garelick without concern?
Chris
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Sun Apr 05, 2009 9:17 am    Post subject: kicker Reply with quote
Hank did you remove your swim step or did you look for the L bracket I still don't know how to post pictures otherwise i would . Maybe someone can help out here send pictures of a motor mount that goes on a swim platform
eNORMous
Photos: Antibody
PostPosted: Sun Apr 05, 2009 9:50 am    Post subject: Reply with quote
I'm not quite certain of your question -
What do you mean?
Norm
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Sun Apr 05, 2009 12:26 pm    Post subject: Not to steal this tread but very similar, Reply with quote
What motor bracket would you suggest if someone has twins in the back? Are there specific motor brackets that would work better than others? I have twin Honda 40s and have been thinking about a motor bracket for my kicker.
cemiii
City/Region: Alamo
PostPosted: Sun Apr 05, 2009 2:02 pm    Post subject: Reply with quote
What I was trying (poorly) to ask is: Is your kicker removed for major trailering or is the Garelick strong enough that you have no worries about damage to the kicker, bracket or boat under most road conditions?
Thank you, Chris
PostPosted: Sun Apr 05, 2009 2:41 pm    Post subject: Re: Not to steal this tread but very similar, Reply with quote
My goodness, how many engines do you need? With twins, you normally don't worry about that!
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Apr 05, 2009 8:04 pm    Post subject: Re: Not to steal this tread but very similar, Reply with quote
The word I get is that with 40s you can successfully troll by just running one of your 40s at a time. Would like confirmation of this from those who have done it, though...
Doryman
M/V Lori Ann
Anacortes, WA
416rigby
Vessel Name: Foggy Dew
Photos: Foggy Dew
PostPosted: Sun Apr 05, 2009 8:32 pm    Post subject: Reply with quote
I hung our kicker on a Mini Jacker mount. Got the info from Chris on C-weed. Don't have any pics of it yet. It made a big difference in ease of use as opposed to the original way I hung it right on the transom. The Mini Jacker is cast aluminum and simple..no moving parts to wear out.
Rick
cbgale
City/Region: Calumet
Vessel Name: Raton
PostPosted: Sun Apr 05, 2009 8:45 pm    Post subject: Reply with quote
I have no problem trolling slow enough for lake trout with twin 40 Suzi. One is shut down.
20dauntless
Photos: Retriever
PostPosted: Sun Apr 05, 2009 9:50 pm    Post subject: Reply with quote
I had an OMC mount that was similar to the Garlick that some people mentioned above mounted on my Whaler. The kicker was a Yamaha T9.9 electric start. The kicker bracket constantly bounced while underway, and I broke several of the Yamaha motor mounts (the aluminum part that clamps to the bracket or transom) over the years. Eventually I didn't think it was worth the hassle of the kicker and sold it.
If I had twins on the C-Dory I certainly wouldn't get a kicker. If I do decide to get a kicker I'd go with the mini jacker thing mentioned above. No moving parts is very appealing...
Page generation time: 0.0321s (PHP: 76% - SQL: 24%) - SQL queries: 28 - GZIP disabled - Debug on
