Stopper stuck on port engine
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sat Apr 04, 2009 4:51 pm    Post subject: Stopper stuck on port engine Reply with quote
The stopper on the shaft of my port engine comes off easy. The stopper on my starboard engine is seized. I tapped it a few times and used two screwdrivers on opposing sides to try to push it off with no luck.
I did bump that prop while stationary at the dock - wind blew my starboard side against a pylon the first month it was in the water last season - prop was not engaged. There is a tiny bend in one of my prop blades but I mean I don't even think it's enough to repair. Both props spin easy when I push them by hand.
Suggestions?
Captain Matt
PostPosted: Sat Apr 04, 2009 6:49 pm    Post subject: Reply with quote
whats a stopper????????
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Sat Apr 04, 2009 7:50 pm    Post subject: Stopper Reply with quote
The first spacer at the very beginning of the prop shaft. (So you have to remove the prop before you can get to this last spacer).
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Apr 04, 2009 9:11 pm    Post subject: Reply with quote
Thanks for asking.... I have been looking and thinking .....what the heck is that ??? a cork ?? or an eletrical gizmo ?
Guess I am no help...(so what else is new?)
Joel
SEA3PO
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Sat Apr 04, 2009 11:20 pm    Post subject: Reply with quote
Matt
If your engine is like mine that metal stopper, or thick washer is a thrust bearing I belive. Mine was stuck also, just sprayed penetrating oil and tapped with a small brass hammer till it loosened. Came right off.
Chuck
Bootleg Hooch
Bad Boy
City/Region: Fresno
Vessel Name: Cat Fever
Photos: Cat Fever
PostPosted: Sat Apr 04, 2009 11:47 pm    Post subject: Reply with quote
Matt,
Put grease on the inside of your Thrust Washers start of each season and when you pull it out of the water for the winter. This will help with future removals. Sometimes, it will still be lodge in there pretty good, but it will always come off.
George
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Sun Apr 05, 2009 7:31 am    Post subject: Grease Reply with quote
Thanks gentlemen - I will definitely make a point to do this for winter layup. Everything else is of course carefully greased on the shaft.
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Sat Oct 24, 2009 10:18 pm    Post subject: Stopper still stuck Reply with quote
Well today I began the winterization process in earnest. Using an impact tool I was able to get all my lower unit gear oil screws out. (Two out of 6 were seized at the start of last season). I will be replacing all 6 screws.
I could not get the prop stoppers off though. I sprayed each with WD40, put a blow dryer on each for 5 minutes straight, used a rubber hammer as well as a solid hammer, screwdrivers on either side, etc. Neither of them would budge. (End of last season one was free but the other was seized - both are seized this year).
Any other suggestions? I used a solid hammer to dry to free them but I'm concerned about whacking them harder than I already have. I wonder if Suzuki shops use some sort of tool to pull them off (like a steering wheel removing tool)? The rear side of the stopper is rounded and I'm not sure I could get a bite with steering wheel removal tools.
Thanks for the suggestions.
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Sat Oct 24, 2009 10:48 pm    Post subject: Reply with quote
PB Blaster
Pete
Chester
City/Region: home
Photos: Chester
PostPosted: Sat Oct 24, 2009 10:55 pm    Post subject: Reply with quote
Aero Kroil or P B Blaster are very good penetrating oils. WD-40 has it's uses but as a penetrant it's not so good.
Spike
City/Region: Kent
PostPosted: Sun Oct 25, 2009 11:20 am    Post subject: Reply with quote
Matt
Going with Pete, That PB Blaster is great stuff. Spray on liberally and walk away for awhile. The stuff works.
Chuck
Bootleg Hooch
Cker
City/Region: Columbia
State or Province: SC
PostPosted: Sun Oct 25, 2009 12:50 pm    Post subject: Putting it back together Reply with quote
Snap-On tools (catch the trucks at car shops) used to make a compound called Never-Seez. It was a heavy grease with metallic powder. Used it for years on everything I put together (and woudl probably have to take apart again). Great stuff but have no idea whether or not it's still around. Ready-made for the realy hard ones like prop shafts.
Smoked mullet is every bit as good as smoked salmon if you ain't got no smoked salmon.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sun Oct 25, 2009 2:10 pm    Post subject: Reply with quote
When trying to remove the thrust washer, remember that there is a rubber oil seal behind the thrust washer.
Do not use a solvent that would damage the seal rubber.
Be cautious about too much heat for the same reason.
The prop shaft and thrust washer are tapered and can stick together. Perhaps checking with the dealer's service department would help.
Unless the lower unit needs to be taken apart, or the oil seal replaced, the thrust washer can remain on the shaft.
Larry H
Retired Evinrude mechanic
PostPosted: Sun Oct 25, 2009 2:20 pm    Post subject: Reply with quote
Can you get a small gear puller on the "stopper"?
I'd also suggest something like PB Blaster, Aerokroil or similiar. WD40 is a great "water displacer" (hence the WD) but that's about it IMO. I'd also put a small amount of silver anti-seize compound on prior to re-assembly and also on any small screws/bolts etc. You can get it at your local auto parts store. A little goes a loooooooong way.
Adeline
Photos: Adeline
PostPosted: Sun Oct 25, 2009 3:35 pm    Post subject: Reply with quote
I've always used Permatex and never had a problem,
BUT
Lanocote is real popular on the Cruising Forums.
Copper based anti-seize should be avoided.
Page generation time: 0.0777s (PHP: 51% - SQL: 49%) - SQL queries: 28 - GZIP disabled - Debug on
