Kicker Tie Rod
cbadmin
PostPosted: Mon Oct 27, 2003 5:49 pm    Post subject: Kicker Tie Rod Reply with quote
From: Da_Nag™ (Original Message) Sent: 1/29/2003 7:39 AM
Here's a recommendation on a great kicker tie rod.
It's sold by Cabelas, and the stainless model is currently under $50. Link is here.
It has a swivel joint on both ends, is adjustable for length, and can be easily bent if necessary. On my setup (Yamaha F80 + T8 kicker), it allows completely independent tilting of either motor while connected. If you need to remove it, it comes of in about 5 seconds, as the connectors on the swivel joints are spring-loaded.
Bill
Page generation time: 0.0187s (PHP: 74% - SQL: 26%) - SQL queries: 14 - GZIP disabled - Debug on
