Polishing Stainless Welds.
seabeagle
City/Region: Farmington Hills
Vessel Name: Sea Beagle II - Sold 4-19-12
Photos: Sea Beagle II
PostPosted: Sun Jan 25, 2009 12:44 pm    Post subject: Polishing Stainless Welds. Reply with quote
I'm working on a rail project and am looking for an easy way to make the welds look like the ones on the bow rail. I can polish the discoloration on the flat surfaces easily but, the weld takes much more work. The project will have a total of 18 welds, 6 base welds and 12 tee welds. What kind of buffing wheel or compound should I use?
I am the 125% I work so the 99% don't have to.
http://www.youtube.com/SeaBeagleII
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sun Jan 25, 2009 1:26 pm    Post subject: Reply with quote
You have a good hand... your welds look really professional...mine look like chewing gum...
What I did was buy a small 1" band sander from Harbor Freight (cheep one) and a mondo buffing machine (also cheep Harbor Freight) ... I sand the weld as smooth as I can...then buff the daylights out of it...using a rough compound then their stainless compound...that makes it look really nice... not as nice as factory welds but very acceptable.. I think that buffing machine was under a hundred...and the hand held belt sander something like $30....
Joel
SEA3PO
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Sun Jan 25, 2009 1:32 pm    Post subject: Reply with quote
I'd use a STAINLESS wire buffing wheel and it you really want a nice job buff them with white buffing compound and a buffing pad.
marvin
seabeagle
PostPosted: Sun Jan 25, 2009 1:35 pm    Post subject: Reply with quote
Joel
SEA3PO
Thanks for the compliment. I'm quite familiar with Harbor Freight tools. That weld was done with their TIG welder. I bought it just for this. I'll take a look at what they got.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Jan 25, 2009 1:39 pm    Post subject: Reply with quote
Use less heat & less fill. ( full-penn not required Wink )
I would get out the flapper wheel with 220-320grit & clean thoes up. Then polish with a felt bob & finer & finer compound till you get where you like it ! Mr. Green Beer
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Jan 25, 2009 1:52 pm    Post subject: Reply with quote
Ask Joe (of R-Matey). He and Ruth ran a polishing business for many years and know everything there is to know about it. You should see the polished fire hydrants and other objects in their immaculate garage!
Doryman
M/V Lori Ann
Anacortes, WA
seabeagle
PostPosted: Sun Jan 25, 2009 1:57 pm    Post subject: Reply with quote
I'd gladly make them a warm hearty meal of Hamburger Helper if he would come to frosty Michigan with some tools. Wink
boscoj
City/Region: South San Francisco
Vessel Name: Knoty Lady
PostPosted: Thu Jan 29, 2009 2:58 am    Post subject: well that's a tough join . . . Reply with quote
I guess this is a base/mount weld. Difficult due to the different mass in each donor. I would have turned the mount down so there was better heat transfer.
Now that it's joined I guess you can't put it on a lathe.
I would run the tip around again to pretty it up.
Or run the tip on the fat part to take the edge off and re-flow the existing weld.
Then a stainless brush with some compoud
Page generation time: 0.0351s (PHP: 62% - SQL: 38%) - SQL queries: 25 - GZIP disabled - Debug on
