Center console C-Dory 22?
dougnan88
PostPosted: Mon Sep 13, 2004 4:26 pm    Post subject: Center console C-Dory 22? Reply with quote
Question for the group. Is there any brand of center console fishing boat that uses the same hull shape as the C-Dory. Love the C-Dory hull for fishing and cruising shallow water but don't need or want the cabin.
Doug
Punta Gorda, Fl
PostPosted: Mon Sep 13, 2004 4:36 pm    Post subject: Reply with quote
I have seen photos of c-dorys from the past with only a center consol in a fishing book called salt water salmon angling by bob morttarm in 1989. but have never seen one in the flesh.
dougnan88
PostPosted: Mon Sep 13, 2004 4:40 pm    Post subject: Reply with quote
Starcrafttom,
I wonder if C-Dory used to make a center console model back in the 80's and since then have just built cabin models?
Doug
Punta Gorda, Fl
PostPosted: Mon Sep 13, 2004 5:23 pm    Post subject: Reply with quote
I think that they made both at the same time and then dropped the center console line at some point. a center console in the north west is not very useful.
dougnan88
PostPosted: Tue Sep 14, 2004 4:56 am    Post subject: Reply with quote
Thanks for the information. Maybe someone in this group will know of a center console fishing boat that is currently being manufactured and has a V dory hull.
Doug
Punta Gorda, Fl
Aiviq
City/Region: Juba
C-Dory Year: 1985
Vessel Name: Aiviq
Photos: Aiviq
PostPosted: Tue Sep 14, 2004 9:55 am    Post subject: Reply with quote
Check out Tolman Alaskan Skiffs (do a google search). They have a dory hull, and look a lot like a C-dory, but I've seen them with a center consol configuration. The down side is that they aren't being manufactured - they are home built from plans. There are some custom manufacturers building them, though, or if you are handy, I think they are within reach of an ambitious amateur woodworker.
jflug
City/Region: Bodega Bay
C-Dory Year: 1981
Vessel Name: Pescadory
Photos: Pescadory
PostPosted: Tue Sep 14, 2004 2:37 pm    Post subject: Reply with quote
C-Dory did once make a center-console v-hull, 22' I think. I think it was called the "Offshore" model. There's one in this area that I see from time to time.
Jim F
dougnan88
PostPosted: Tue Sep 14, 2004 3:09 pm    Post subject: Reply with quote
jflug,
Thanks for the info. Maybe I will call the factory and find out if they know of anyone building a center console using their hull style. Glen-L design has one in a plans only version called the V Dory but I don't have the time or patience to even consider a project of that magnitude.
Doug
Punta Gorda, Fl
Page generation time: 0.0949s (PHP: 25% - SQL: 75%) - SQL queries: 26 - GZIP disabled - Debug on
