Reposition batteries
C-Pelican
City/Region: SoCal
C-Dory Year: 1992
Vessel Name: C Pelican
Photos: C-Pelican
PostPosted: Wed Jan 14, 2009 1:59 pm    Post subject: Reposition batteries Reply with quote
Has anyone ever put two batteries on the floor of the cockpit between the two fuel tanks on a 22' cruiser?
I like the sound of it to even out the weight and gain more storage in my lazarettes and under the sink.
It also seems it would make battery access easier.
Worries:
I ocean most of the time and wonder about the splash (and yes, sometimes huge amounts) of salt water coming into the cockpit from over the stern splashwell.
I picture putting them in plastic battery boxes with a battery switch between them.
Thanks in advance.
Jeff
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Wed Jan 14, 2009 2:35 pm    Post subject: Reply with quote
Jeff,
My main concern would be the fumes from the fuel tanks. Could get rather explosive Shocked
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Wed Jan 14, 2009 3:20 pm    Post subject: Reply with quote
I don’t see it being a problem; the fuel tank vents are located on the outside of the hull-at least on a 07. They make marine battery cases exactly for this purpose that have vents and sealed terminal connections. If you use a Perko type isolation switch you’ll have to find a location for it. I managed to put both my batteries in the starboard laz along with my battery isolation switch.
If your worried about hydrogen gas go with a marine Gel or AGM instead of a Flooded battery, they also last longer and are more immune to the harsh saltwater environment.
Boatless for now but looking
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Wed Jan 14, 2009 5:02 pm    Post subject: Reply with quote
Did it on my 19 a few years back, which would be the same as a 22. Worked out great. However, I kept the battery switch mounted on the inside of the lazarette - doesn't take much more cable, and I liked being able to turn things on/off without crawling into the boat (think engine tilt when flushing...)
I also mounted a charger to the box, along with a waterproof plug - made for easy charging from an extension cord. Here's a link with a few more details and pics.
Tux Will, C-Brat Nerd Tux
PostPosted: Wed Jan 14, 2009 6:40 pm    Post subject: Reply with quote
We have two of the batteries in the 25 on the cockpit deck under the splash well. Not much difference between there and between the tanks of the 22. Batteries can explode and short--so that is a point. I certainly would put them in boxes--could be self made of fiberglass or the off the shelf plastic. Be sure that you can still get to the bilge pump.
We had other things we put in there when we owned C Pelican--but each of us has our own uses and makes modifications which fit our lives better.
Jeanie P
City/Region: Alexandria
Vessel Name: Jeanie P - sold 11/08
PostPosted: Thu Jan 15, 2009 1:49 pm    Post subject: Reply with quote
Both my batteries were under the splashwell between the fuel tanks. They were in plastic off- the -shelf battery boxes with lids, held in place with tie-down straps.
The battery switch was located in the starboard lazarette. Never any problem.
Allan
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Thu Jan 15, 2009 2:05 pm    Post subject: Reply with quote
What's wrong with putting them both in the lazarette? That is where mine are. It is a perfect spot for them.
PostPosted: Thu Jan 15, 2009 3:03 pm    Post subject: Reply with quote
Some people like them there.
The chief advantage is ease of access to check them out, add water, the short distance to the battery switch, and keeping them away from the water down on the hull floor.
The disadvantages are that they are a very tight fit and hard to rerplace (for two 24 or 27's--- larger batteries won't fit in pairs), that they raise the center of gravity of the boat up higher, and they use up space that could otherwise be used for convenient arm level storage.
Alternately.....
Batteries on the floor lower the center of gravity, free up one lazarette for storage space, and free up another for use as a bait tank or more storage, and they utilize the empty space between the fuel tanks.
On the other hand, batteries on the floor between the tanks have to have longer cables, must be in battery boxes and strapped down tightly (by drilling holes in the floor that must be sealed properly), are more difficult to inspect and service, and can make access to the bilge pump(s) more difficult.
I have one group 27 in the starboard lazarette along with the battery switch and many electrical connections, a second 27 in a box between the fuel tanks, and two more 27's in boxes up under the forward dinette seat ,with a switch for the forward two on the side of the dinette seat. The extra weight on the port forward side slightly imbalances the boat to port, but a bit of cargo weight shifting returns things to normal.
Hope this helps!
smittypaddler
City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
PostPosted: Thu Jan 15, 2009 8:40 pm    Post subject: I have two type 27's between the tanks Reply with quote
I have two group 27 deep cycle batteries in plastic battery boxes on the cockpit floor between the two gas tanks on my CD22. They're easily replaced, which I can certify, since I just replaced mine (took 15 minutes). The two disadvantes are: (1) Mine are flooded batteries, and it's a pain in the butt to get down there to check the fluid levels; I bought a small mechanics mirror on an extendable handle, which helps. (2) The second disadvantage is the extra weight (about 120 pounds) that far aft means my engines don't quite clear the water in the up position.There's a photo here:
http://smittypaddler.com/cds/cd7/fl08/photos/large/d080228/IMG_0299.JPG
In this position my sacrificial zincs are clear of the water, but the lower housing is still in the water, so I have a potential electrolysis problem, which I hope to've solved by hanging a fish made out of zinc over the side in the water, with an alligator clip attached to a piece of bare metal on the engine steering assembly (I also have to make sure to remember to lift that zinc fish out of water before casting off Smile.
jlastofka
City/Region: Vista
Vessel Name: Bossa Nova
Photos: Bossa Nova
PostPosted: Thu Jan 15, 2009 11:41 pm    Post subject: Weight and balance Reply with quote
I feel like my boat is somewhat stern heavy and I run with a fair amount of trim tab down. I've been thinking of moving my two batteries forward under the V-berth area, putting them in sealed boxes vented overboard.
I saw this thread and I just did a couple quick calculations. (As an engineer and former airplane pilot I learned how to do weight and balance calculations. It's actually pretty easy.)
If you assume a 2500 lb boat with a vertical CG 2 ft away from some reference point and then move 120 of those lbs another 2 ft vertical distance, the overall vertical CG would move just over an inch. I did that one because someone here mentioned it.
In my case of interest, moving 120 lbs 10 ft forward in the boat would move the CG about six inches forward, again assuming a 2500 lb total.
I guess the boat probably weighs more like 3500, and I'm just guessing on the batteries, but these calculations show the approximate effects of these kinds of changes.
I don't think we'd ever notice a small vertical CG change, but I'd think the fore/aft CG change would make a noticeable change in running trim.
Next time I'm out with a passenger I'll get everything stabilized with the passenger near the stern battery area and then have him/her move up to the V-berth area. The effect should be about equal to my proposed battery move.
Jeff
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Thu Jan 15, 2009 11:55 pm    Post subject: Re: Weight and balance Reply with quote
Jeff
Jeff I've thought about doing the same thing but rather than venting the batteries why not use AGM batteries which I don't think would need to be vented? Only draw back I see is the size of the conductors to account for voltage drop. I expect you'd need perhaps 2/0 wire and it would add quite a bit of weight itself but it would be distributed along the length of the boat.
marvin
Levity
City/Region: Shippensburg
Vessel Name: Levity
Photos: Levity
PostPosted: Fri Jan 16, 2009 2:59 pm    Post subject: Reply with quote
Jeff,
My C-Dory 22 came with the batteries under the splash well and between the tanks. They were in boxes and secured to the deck with nylon straps. The nylon straps were secured to the deck with nylon tie down anchors. The tie down anchors were secured to the deck with stainless screws. This was satisfactory for 2 years after which inspection of the stainless screws showed them to be significantly rusted and improperly set(no epoxy). The area under the splash well was very dirty as the batteries trapped gunk. The transom drain hole was not easily viewed and extremely difficult to access (spare plug in emergency). Maintenance of the batteries was not easy as they had to be released from the tie downs and dragged into the cockpit to remove the covers. Installing and maintaining a bilge pump in the aft depression proved to be difficult with the batteries in this position. The batteries were relocated to the starboard lazarette. They are crowded in there but easier to access, yet more difficult to remove. The under splashwell area is cleaner, easier to inspect and bilge pump maintenance is easy. I am glad I made the change.
Mike "Levity"
PostPosted: Fri Jan 16, 2009 6:17 pm    Post subject: Reply with quote
Moving the batteries forward may be more complicated than you think. You have to cut into the V Bunk structure, remove foam--and have less floatation. You have to make a door for this aperature. You then have to run heavy cables to the engine for the starting--not too hard to do, but costly and some weight in the middle of the boat.
I assumed that the battery in C Pelican was put under the galley for the Wallas--the run is short, and the battery didn't take up much room there. I didn't move it because I didn't see the need to..If it works better for you between the fuel tanks--go for it.
C-Pelican
City/Region: SoCal
C-Dory Year: 1992
Photos: C-Pelican
PostPosted: Tue Jan 20, 2009 10:49 am    Post subject: Reply with quote
Thanks for the replies everyone, darn, now there is more to think about!
At least my trailer is now fixed (broken cross member) so I can think deeply about the battery repositioning.
Doc Bob, still using those same batteries that came with it when I bought it from you...and they are strong and sure!!!!
Jeff
PostPosted: Tue Jan 20, 2009 7:32 pm    Post subject: Reply with quote
Jeff,
Those batteries were on the boat when I bought it--and were not new then. Maybe you can set a record for battery life!
I have to ask--did you fix the road to your house, as well as the trailer?
Regards,
Page generation time: 0.0517s (PHP: 73% - SQL: 27%) - SQL queries: 32 - GZIP disabled - Debug on
