Fish hook removal... OUCH!
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Sat Jan 10, 2009 6:27 pm    Post subject: Fish hook removal... OUCH! Reply with quote
THIS IS GONNA HURT
Pete
Capn Jack
City/Region: La Conner
C-Dory Year: 1988
Vessel Name: Pocket Yacht
Photos: Pocket Yacht
PostPosted: Sat Jan 10, 2009 6:38 pm    Post subject: RE: OUCH !! Reply with quote
Been there done that. Cry It's the best reason I've seen for "Barb-less" hooks. Crook ... CoolSmile Jack
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sat Jan 10, 2009 7:30 pm    Post subject: Reply with quote
Its actually easier, but still painful, to push the hook through the skin so the barb is outside, then cut the barb off and withdraw the hook. Remember antiseptic!
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Sat Jan 10, 2009 9:23 pm    Post subject: Reply with quote
Also been there but unlike the hook in the video, mine was barbed and in the tip of the index finger. I wound up at the UW emergency room where they gave me a lot of local anesthetic injections and (after I insisted) cut the shank and pushed it out point first. Was one of the most painful things I've experienced. Barbless = good.
RJD Wannabe
City/Region: Elk Grove
PostPosted: Sat Jan 10, 2009 9:50 pm    Post subject: Reply with quote
Why I carry Lidocaine and a syringe in my fishing box
Soon to join C-Dory owners
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Sat Jan 10, 2009 9:56 pm    Post subject: Reply with quote
Yes OUCH and then some!!! That photo brings back a little bit of bad and whole lot of good memories of a week long canoe trip I made with my youngest son on Yellowstone Lake just after his graduating from High School. We had camped for the night at the Promontory Point boat campsite when just before dark with a cast I buried two prongs of a three prong hook in my right cheek. Yellowstone Lake is a barbless hook fishing area, but it is legal to just crimp the barbs with pliers. Sure wished I had crimped them a lot better then I had. Found the skin on the face is much tougher then I ever dreamed it could be. Jayson pulled those those hooks way out there with no give. Finally He cut the hooks apart and that vibration I could feel right to my toes. He then tried to push them through as Roger described and though the skin seemed to stretch again in front of the point it wouldn't break through the skin. Ended up heating a knife tip and cutting them out. Found it very hard to hold still while he pulled and cut. What helped the most was taking my mind off it by videoing my face while Jayson did the job. Was a much better ending then spending the night with hooks in my face and then making the many mile run the next day across the lake to the lake hospital and was able to continue for several more days fishing, exploring and building wonderful memories.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sat Jan 10, 2009 11:02 pm    Post subject: Ouch Reply with quote
One time a buddy of mine kindly lodged his lure into my face as he tried to cast. I feel your pain...ouch yours looks deeper and more painful I'm sure.
Hit it with the antiseptic and make sure tetanus is up to date!
Captain Matt
Socrateur
City/Region: Danville
Vessel Name: Sea Skipper
Photos: Sea Skipper
PostPosted: Sat Jan 10, 2009 11:06 pm    Post subject: Reply with quote
Sorry, but this one is not worth the battery power for the video cam used to photograph it. I do like the Maker's Mark whisky, though.
Capt Jay
anticipationpc
City/Region: Panama City Beach
Vessel Name: C-Quest
Photos: C-FLE
PostPosted: Sat Jan 10, 2009 11:32 pm    Post subject: Reply with quote
I have been a Charter boat Captain for 30 years now. I have seen alot of hooks inbedded in hands, fingers, and even a face. There is a simple proceedure to remove the hook.
Take a 10" piece of heavy fishing line, loop it between the shank of the hook and where it meets the skin, twist the line 5-6 times, hold the line vertical to the hook shaft and close to the skin. Then with a quick hard yank jerk the hook out. The trick is to get the line as close as you can to the barb. Works every time!
Jim C
Aiviq
City/Region: Juba
C-Dory Year: 1985
Vessel Name: Aiviq
Photos: Aiviq
PostPosted: Sun Jan 11, 2009 5:09 am    Post subject: Reply with quote
A trick that has always worked for me requires a good size hypodermic needle (an 18 or 20 gauge, depending on the size of the hook). You slide the needle along the wound track along the inside of the hook and engage the lumen (opening) of the hypodermic needle onto the barb of the hook. With the barb covered by the lumen of the needle, you have basically made the hook barbless, and it can be backed out easily with the needle remaining engaged on the barb.
PostPosted: Sun Jan 11, 2009 7:59 am    Post subject: Reply with quote
Now THAT's good information. Thanks, I usually have some hypodermic needles on board to allow me to deflate the swim bladders of yellow eye (which we have to release here in WA). Now I have another reason to carry them.
garyk
City/Region: Ketchum
State or Province: ID
Vessel Name: AMIGO 11
Photos: Amigo II
PostPosted: Sun Jan 11, 2009 12:23 pm    Post subject: Fish hook removal... OUCH! Reply with quote
The hook removal procedure shown in the video and described by Jim C. is far and away the best way to remove a hook. The one step that was not pointed out which is VERY important. The eye of the hook must beheld down so it can not rotate. In the video simply holding the lure down, which is attached to the hook eye would keep the hook from rotating. I assume this was being done but was not shown. In the case of a smaller hook or fly, holding the eye down against the skin with your thumb while the barb is (yanked)out in the same direction it entered.
I've used this system many times in my 65 years of Alaskan sport fishing and guiding novice fisherman and woman.
Gary King
captd
City/Region: Chain of Lakes
State or Province: MT
C-Dory Year: 1994
Vessel Name: Kon Tiki
Photos: Hunky Dory
PostPosted: Mon Jan 12, 2009 7:33 am    Post subject: Reply with quote
To wet your imagination: Fishing out of Prince of Wales for halibut. I was using a double # 9 circle hooks. Top one on a slide. We were catching 20 to 30 pounders and turning them loose. Trying to detach one while hanging it over the side the slider hook swung around and hooked the end of my finger. The hook went in and came out the opposite side. the fish seen to that. The fish had to come off the first thing. One of us needed immediate relief. A #9 is thick enough where we could not cut the shank. With a lot of work we flattened the barb. Then did the jerk thing.
Having had tainted salmon on the hook as bait. We needed to sterlized the wound. My wife came up with the solution. Pour iodine in one hole so it comes out the other. WRONG! Like putting a blow torch to your finger. I suggested Hydrogen proxide thinking that wouldn't hurt WRONG again. We injected it with a hypodermic. That was as badas the iodine, but it went all the way through.
Painfull to remember.
captd
100 ton Master
garyk
Photos: Amigo II
PostPosted: Mon Jan 12, 2009 12:18 pm    Post subject: Fish hook removal... OUCH! Reply with quote
Captd,
Wow,
I've never had the need to try to remove a circle hook from any thing but a Halibut. My fishing buddy is good at it but I have a hell of a time getting one out of the fishes lip. I think that might be a good subject for the Brat's ......"How do you remove a circle hook, with out killing the fish"
We hooked a 100 lb plus Skate in the wing, didn't want to kill it , we had a hell of a time getting it out, the damn fish would not co-operate.
Gary
PostPosted: Mon Jan 12, 2009 6:40 pm    Post subject: Reply with quote
In any afterward. I like Betadine or Hydrogen Peroxide.
Also consider how you will remove a fish hook if you are alone? I found that pushing on through and cutting off the barb has worked best for me when I had to remove a hook (generally small) when alone. It is hard to stabalize the hook, the skin and jerk on the string when alone. But this is a good technique when several people are available.
Page generation time: 0.0913s (PHP: 46% - SQL: 54%) - SQL queries: 28 - GZIP disabled - Debug on
