Cutting Garmin GA29 antenna cable
marco422
City/Region: Salt Spring Island
Vessel Name: Gaiasika
Photos: Gaiasika
PostPosted: Tue Dec 02, 2008 1:07 am    Post subject: Cutting Garmin GA29 antenna cable Reply with quote
The Garmin passive antenna for my GPSMAP 545s comes with a 30-foot cable. I'm the kind of person who doesn't like a bunch of cable coiled up in the cabin. Is it OK to cut it down to 8 feet and install a new BNC connector?
PostPosted: Tue Dec 02, 2008 2:59 am    Post subject: Reply with quote
Marco-
Thataway (Dr.Bob) may be able to answer this, but have you looked in the installation manual? It will probably cover this.
You can also call or write one of the company's Technical Representatives and ask them. Get the phone number or email address from the Owners or Installation Manual.
Having talked to the manufacturer's representative directly may give you some additional protection if a Warranty issue develops with the unit, especially if seems to have come about in relationship to cutting the cable.
Cutting co-axial cables and installing connectors is sometimes difficult, depending on the connecter and cable types.
Go slow and be sure before you do anything. You can always coil it up for now and then cut it later when you know it's OK to do it, and how to do it successfully.
Good Luck!
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Tue Dec 02, 2008 3:00 pm    Post subject: Reply with quote
It is not recomended because the accuracy of the unit is based on timing, and a shorter cable alters the timing slightly.
That being said, I have seen guys shorten cables and not have noticable side effects.
Bigger question- will it void the warranty?
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
AstoriaDave
City/Region: Astoria
PostPosted: Tue Dec 02, 2008 4:26 pm    Post subject: Reply with quote
Not true. The unit's accuracy is based on the difference in timing between different satellites. Consequently, changing the length of the cable changes the timing equally for all the satellites. Go here for more information: http://en.wikipedia.org/wiki/Global_Positioning_System#Basic_concept_of_GPS
I believe GPS manufacturers simply do not trust the average Joe or Jane to make a good BNC connection which will stand up to vibration, moisture, and the vagaries of a boating environment.
Dave Kruger
Astoria, OR
PostPosted: Tue Dec 02, 2008 4:29 pm    Post subject: Reply with quote
I agree with Dave, it is because of the difficulty of putting a BMC connector on the cable. The extra cable will do no harm--i would just bundle it on the shelf or behind the console.
eNORMous
City/Region: Beaufort
Vessel Name: Antibody
Photos: Antibody
PostPosted: Tue Dec 02, 2008 4:53 pm    Post subject: Reply with quote
Agree on the delta in Satellite timing (interestingly they just had this on Discovery last week - Einstein, E=MC2, Satellites & GPS timing intervals). Agree - the average Joe is clueless on putting together a BMC connector. I thought about doing it (have done it in the past), but I like most probably figure, hey you know what - I just might want that extra cable some day if I move it. So, I just bundled her up and left well enough alone Mr. Green
I am what I am & that's all that I am & there ain't no more.
E Pluribus Normus
PLB Beacon ID: 2DCE5DE29CFFBFF
Page generation time: 0.0388s (PHP: 63% - SQL: 37%) - SQL queries: 19 - GZIP disabled - Debug on
