Fuse for an LED light
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Sun Nov 30, 2008 8:37 pm    Post subject: Fuse for an LED light Reply with quote
I just bought a new sealed LED all-around white anchor/navigation light. It will replace the badly corroded non-LED light that came with the boat. I have a question about fusing a mix of LED and non-LED lights on the same circuit.
The all-around light is controlled by a rocker switch that also controls the two (starboard and port) navigation lights. "Up" turns on only the all-around light for anchoring, and "down" turns on all three lights for night navigation. The starboard and port navigation lights are not LEDs. All three lights are wired through a 15 amp fuse at the switch.
The instructions for the new LED light says to protect the light with a maximum 5 amp fuse.
Should I:
- change the 15 amp fuse to a 5? (Isn't a 5 amp fuse likely to be too small for the port and starboard navigation lights which are not LED?)
- place a 5 amp fuse inline where I'm connecting the new LED wiring to the existing wiring?
- ignore the instructions and leave the new LED wired through the 15 amp fuse?
Rewiring the new LED light to a new separate switch with it's own fuse is not practical.
Part of me (not the part that's on a budget) wants to replace the port and starboard navigation lights with LEDs also, but those lights are working perfectly and do not appear to be corroding at all. Also, I haven't investigated LED red and green navigation lights for fusing requirements. One might guess the requirements, at least from the same manufacturer, would be the same, i.e., 5 amps, but that seems to be the kind of information you only get after you open the package.
Any advice is welcome.
Bill
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Sun Nov 30, 2008 8:52 pm    Post subject: Reply with quote
If it were me, Bill, I'd replace the present fuse with a 10 amp and wire a 5 amp inline fuse between the 10 amp fuse downstream side and the LED light. Easy to remove if you ever decide to go LED everywhere, unobtrusive, and effectively protects the light while keeping the running lights protected.
Don
NORO LIM
Photos: NORO LIM
PostPosted: Sun Nov 30, 2008 9:20 pm    Post subject: Reply with quote
Thanks, Don. That certainly seems like a straightforward and simple solution.
Now I get a chance to display my ignorance, but I want to be sure about how to proceed. I was thinking of just putting the inline 5 amp fuse at the junction of the existing wire to my radar arch and the 24-inch wire that comes attached to the new LED. (This would put the fuse at an unobtrusive but accessible point, and would not require cutting, pulling or undoing any existing wiring.) Any need to worry about that placement?
Sneaks
Vessel Name: C-Brat
PostPosted: Mon Dec 01, 2008 1:33 am    Post subject: Reply with quote
Only if it's in a spot that often gets wet. There are marine grade inline fuses with water resistant covers, but feces occurs. I'd take real care in waterproofing the junction of the old and new wires, using the heatshrink with sealant inside (also available at West Marine) and then disconnect the wire at the anchor light switch behind the helm and add the fuse there. Water, especially that salty stuff west of you can screw up a fuse/holder pretty fast, especially if it stays wet.
We don't worry as much down here in San Diego. We had a torrential rainstorm move through just before thanksgiving that set a 40 year record. One INCH Rolling Eyes, bringing our year rain total to around 3 or 4 inches. I think you guys get that every afternoon....
Don
Mary & Don Anderson
Brat #483
mmitchell
City/Region: Whittier
Vessel Name: ShiRoz
Photos: ShiRoz
PostPosted: Mon Dec 01, 2008 1:48 am    Post subject: Reply with quote
I've changed out all the interior fixtures out to LED and the anchor fixture. Have left the running lights to incandescent as they only are on when we are under way so it is being charged by the motors. We have never camped out at the docks so have to be very frugal in how much power is being drawn on the batteries. We installed a class 37 for the house battery and it has been fine for about a day and a half. That is running the Wallas 24-7. So back to the fuses. I don't thing it's a real worry to be concerned about the 15 down to a 5 for the fuses.
The LED light only draw about a 5th of what the incandescents draw. They are much brighter too as we went from a 12 watt stock to a 42 watt.
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Mon Dec 01, 2008 6:15 am    Post subject: Reply with quote
I'm no electrical engineer, but I'd leave the fuses alone.
The purpose of a fuse is to prevent something "bad" from happening when a circuit shorts, or overloads. If all the nav lights have been getting power through a common fuse, the risk of an overload at one light knocking out the fuse, and thus the power to all nav lights, is apparently tolerable. If that possibility is not tolerable, separate the circuits now.
Otherwise, so what if the led shorts or overloads, and draws a little more power than it's fuse rating before blowing the existing fuse? It's not going to burn out the wires (they're supposedly sized for the higher amp fuse), it's not going to start a fire, and it's not as if we're dealing with an instrument which needs protection from a slight overload to save the whole unit. The led's are not cheap, but, in the end, they're still light bulbs.
If you do fuse the led separately, I recommend you don't install the fuse externally. If the fuse blows at night, on rough water, you don't want to go overboard changing it out. I prefer to keep the fuses where they're readily accessible, from the helm station.
2003 CD22 Cruiser with Honda 90
PostPosted: Mon Dec 01, 2008 3:40 pm    Post subject: Reply with quote
We converted the 360 light to LED, and left the fuse the same. There is no protection for the light with the 5 amp fuse. You are basically protecting the wiring, if there is a short. There is a separate wire from the back of the switch which goes to the all around light--and you could put the separate fuse in that (behind the console)--but I don't think it is necessary, since the circuit is fused before the switch.
I have also converted some of the interior lights to LED--and left the same fuses in place.
Sneaks
Vessel Name: C-Brat
PostPosted: Mon Dec 01, 2008 4:41 pm    Post subject: Reply with quote
Fuses are an interesting and in many ways misunderstood electronic/electrical component. They come in many flavors, the most common are general purpose, fast acting, and slow-blow. Usually the fuse is sized as a percentage of expected current flow. IE: if the expected draw is 10 amps, the fuse is sized to not only prevent wire damage but more often to prevent a fire or major damage within the device it's protecting. Lets say 50% greater or 15 amps. Anything close to 10 amps might cause an unwanted fuse failure, anything over 15 amps increases the risk of damage. A compromise.
Motors typically use "slow blow" fuses simply because the startup current is so high. It basically "holds off" blowing until it realizes the current has not dropped below the fuse current rating quickly enough, signifying serious trouble.
Some slow blows are incredibly tolerant of of overcurrent. One fuse in a radar I maintained kept blowing at the most inopportune time. Turns out the fuse was wrong. the proper fuse was rated at 600% overload for 3 full seconds!!!! Once the right fuse was installed, that puppy never blew again.
In something as simple as our C-22, general purpose fuses work just fine. My earlier recommendation to drop the 15 amp down to 10 amp was simply to keep the present current to fuse rating ratio the same. Bob's suggestion is just as valid. If a wire did short, either fuse will detonate before the wire even got warm. I do, however, still stick with the recommendation that the actual junction between the LED wire and the boat wiring be carefully made to prevent any water intrusion, and if you put a fuse in, put it where it's easy to replace - even at night at sea.
There's an old rule of thumb for hardware techies working for the government. I learned this from Charlie: If it blows fuses, get a bigger fuse.... Wink
Don
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Mon Dec 01, 2008 4:51 pm    Post subject: Reply with quote
If you add a fuse, do it behind the console for two reasons-
Easy to get at.
Protects the wire from switch to light.
But I don't think I would worry. I'd leave the 15 in place and use it.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
PostPosted: Mon Dec 01, 2008 5:44 pm    Post subject: Reply with quote
One other thing to remember is that the circuit has both the "anchor" in one position, and "navigation" in the other position. Be sure that you get the correct wire, if you do elect to put a fuse in line.
I have fused a number of circuits in the C Dories, and for the most part either added a second fuse block behind the console (in both the 25 and TC 255) as well as putting some in line fuses, for circuits which connected to the main battery switches or additional batteries. For all of these I used the blade type of fuse--used crimp fittings which had adhesive shrink wrap on the leads, and packed the rubber fuse holder with grease, so that there could not be any corrosion--even though all of these fuses are directly protected from the weather, they are still in high humidty environments. Also when adding fuses and working on the electrical system, be sure and label all of the wires and fuses. It makes it a lot easier if a fuse blows to find the right one! I use 1/4" wide plastic labels and wrap the label around the wire near a terminal. I put the label right along side of the fuse. Label both ends of a wire--for example if you add an additional battery--label the wire at the switch, and at the terminal of the battery--such as "house battery #2". Label both the plus and neg legs.
NORO LIM
Photos: NORO LIM
PostPosted: Mon Dec 01, 2008 8:07 pm    Post subject: Reply with quote
Thank you all for the excellent suggestions and discussion.
I have been planning all along to solder and shrink wrap the new wire connections below the light. Both the old lamp itself and the old wire connections below it, showed considerable corrosion. With the new sealed LED lamp, corrosion in the lamp itself should not be an issue, but I do want to have a better wire to wire connection than the original. It actually took me a little while to figure out what was going on with the wiring until I got the old lamp and stalk disassembled. There were three wires from the lamp going into the top of the stalk, and only two wires coming out the other end. The original Perko lamp was a two bulb fore-and-aft affair designed for switching between one bulb for navigation and two bulbs for anchoring. Maybe it's common practice to convert these two-bulb lamps for all-around use on smaller boats? However, the hot leads from the two bulbs were joined to the hot wire from the switch in a not very well done three-way connection that finally came out of the stalk as a sticky wad of electrical tape, some kind of sprayed in foam, and loose butt-end connectors. I will see if I, a complete novice at this, can do better. I'm not taking bets, but I think I can.
I am leaning towards leaving well-enough alone and not adding an extra 5 amp fuse. I'm still uncertain about whether to leave the current fuse at 15 amps, or to drop it to 10amps. Any consensus on that?
forrest
City/Region: Chehalis
Vessel Name: Long Story
Photos: Long Story
PostPosted: Mon Dec 01, 2008 9:07 pm    Post subject: Reply with quote
Circuit breakers or fuses protect the wire that is feeding a load. The maximum size fuse is determined by the size of the wire. You can install smaller rated fuses if you want to protect a load more closely. Electronic devices that need a fast blow fuse are generally supplied with an internal fuse or a inline fuse directly ahead of the device. A good analogy to this would be a circuit in your house. No matter how many lamps, vacuum cleaner or TVs that you plug in, you don't go out and change the circuit breaker at the panel. If you have number 12 wire in your house you have a 20 amp breaker. If you have number 14 wire in your house you have a 15 amp breaker. Breakers (or fuses) are sized to protect the wire. If a bulb burns out so what, you replace it. If your hair dryer burns out, you buy a new one. If your stereo shorts out, a fuse inside the stereo blows. In each case the wiring in your house (or boat) remains intact (it doesn't burn up) because it is protected by the proper rating of the fuse or circuit breaker ahead of the wire. Another example would be when you pull your boat trailer. Just because you add a couple of tail lights and five clearance lights when you plug in your trailer, you don't increase the fuse size in your pickup for the extra load. The fuse that is in your distribution block is sized for the wire at the factory. If there is a short or load that exceeds the wire rating the fuse or circuit breaker trips. If you have a dedicated circuit such as for a pump, you can fuse the load according to the manufacturers recommendation as long as you don't exceed the rating of the wire.
Forrest
NORO LIM
Photos: NORO LIM
PostPosted: Mon Dec 01, 2008 9:59 pm    Post subject: Reply with quote
I guess I should say my concern all along has not been about the wire, but about the LED. It's a sealed lamp with no replaceable bulb, and it ain't cheap (at least by my standards!). Since the LED manufacturer says the LED should be protected by a maximum 5 amp fuse, I was seeking advice on how seriously I should take this direction considering that there is a 15 amp fuse already in the circuit. From what Bob and others have said, I'm inclined not to worry too much.
PostPosted: Mon Dec 01, 2008 11:14 pm    Post subject: Reply with quote
The fuse does not protect the LED--it protects the wire. The fuse does not regulate voltage, it only limits maximum current. The current draw of the LED is inherient in the circuit--and cannot be limited by the fuse. You would have to measure the current draw of the two running lights (red and green) plus the LED light to see if a 10 amp fuse would be adequate--it probably would be.
Even though I have done a lot of soldering in electronics, I use crimp fittings and heat setting adhesive shrink sleeve protection on wires on boats. The only solder I use is the rare time that I have to wire a switch which a lug will not fit on. Incidently, invest in a good rachet crimper --this should be in every boater's tool kit, along with a digital volt/amp meter.
Solder joints are a bit more subject to cracking by vibration--but they can be done. If you solder, tape will not give adequate protection--use the adhesive shrink tubing. The best to do is to seal the bottom of the LED socket and any wire going there. This is not always easy, but silicone or specific self amlgimating tape can give a water tight seal around a socket.
Yes, some C Dories had a specific foreward steaming light, and separate stern light, with a second bulb in the "anchor light" to give the 360 degree coverage. This doubled the current draw of the anchor light over the steaming light. A 360 degree light is legal on this size boat, and is more effecient because of decreased current draw, and battery drain.
NORO LIM
Photos: NORO LIM
PostPosted: Tue Dec 02, 2008 12:36 am    Post subject: Reply with quote
Thanks, Bob. And here is what looks to a complete ignoramus like me to be a pretty good tutorial on crimping heat shrink connectors. Maybe others will find it useful, too.
http://www.pbase.com/mainecruising/wire_termination&page=1
Page generation time: 0.0563s (PHP: 67% - SQL: 33%) - SQL queries: 32 - GZIP disabled - Debug on
