Window Removal and frame repainting
Montana Kev
City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
PostPosted: Thu Nov 13, 2008 12:31 am    Post subject: Window Removal and frame repainting Reply with quote
Looking for feedback. My 2 front windows on my 16 need the frames repainted on the exterior. Anyone have any experience removing and painting the window frames? I could leave them in place but it would be nice to pull them out and do a nice rehab and recaulk. Seems they are tacked in place pretty good with adhesive/caulking.
Kevin
JT
City/Region: JUNEAU
C-Dory Year: 1990
Vessel Name: Lil Toot
Photos: Palomino
PostPosted: Thu Nov 13, 2008 8:42 pm    Post subject: Reply with quote
The front windows on my 16' angler are aluminum, no paint. It is your call if removing them is necessary. Not much help. But hey it's a reply anyway. If you remove them take some pictures to post!
JT
Beer F/V "Palomino"
Montana Kev
Vessel Name: Grace
Photos: Grace
PostPosted: Thu Nov 13, 2008 10:25 pm    Post subject: Reply with quote
Here is what the chipped paint looks like. I don't know if this is a common issue with older boats or not.
http://www.c-brats.com/albums/album608/Window_Paint.sized.jpg
Kevin
PostPosted: Fri Nov 14, 2008 12:25 am    Post subject: Reply with quote
Kevin-
Those windows could be bedded in with smething really tough like 3M 5200.
Yu might bend the frames trying to get them out.
I'd consider sanding and painting them in place, just to avoid possible problems.
You might be able to judiciously use a good paint stripper to get the old paint off, but be very careful around the fiberglass gel coat.
Might just be easier to sand and repaint them with several coats of polyurethane paint. It flows out great and has a great chip resistance and flexibility. And you can brush it on easily.
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Fri Nov 14, 2008 6:37 am    Post subject: Reply with quote
Kevin:
I've never pulled window frames on a C-Dory, but have removed hatches from other boats, which are pretty much the same thing. The biggest problem is that after you remove all retaining screws, the frame is still locked in place by adhesives. What you want to avoid at all costs is to remove the frame, and have chunks of fiberglass and gel coat come with it. That turns a fairly inexpensive project into something else altogether.
The only way I've seem frames removed without this additional damage is to tape the adjoining fiberglass areas, and then work a piano wire between the frame and the gel coat, all the way around, to cut the adhesive loose. You'll need several different lenghts of wire, each with a broomstick at the ends so you have something to pull against.
Once you've made the cut, you can work the frame loose with other tools, as long as you're careful not to bend anything.
There are also several products available which would work on the seal chemically. Check with West Marine.
Once the frame is out, a first class job would require that you pull the glass, have the frames sand blasted, etched, and powder coated. You then have to reinstall or replace the glass, and put everything back together again. This is a big project. If you do the painting yourself, it's still a big project.
Quite frankly, if it were my boat, I'd probably mask everything off, clean up the frame as best I could with sandpaper, spray on a little primer, and then paint with Interlux Brightside single part urethane. If you etch the aluminum before priming, the job will last a lot longer.
If they clean up fairly easily, I'd probably just prime and paint. If I had to spend a lot of time getting them clean, I'd etch, prime and paint. The bottom line is that if you don't properly etch aluminum, an oxide will form before you can get the primer on (no matter how fast you work), and the job will ultimately fail. But, if doing it all over again in a few years won't be that big of a deal, just prime and paint.
Let us know what you end up doing.
2003 CD22 Cruiser with Honda 90
Montana Kev
Vessel Name: Grace
Photos: Grace
PostPosted: Fri Nov 14, 2008 3:07 pm    Post subject: Reply with quote
Good feedback. Thanks.
I did decide to leave them in place and mask everything off to perform the refinish.
Seems there are some good paints available that can handle the job.
Kevin
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Thu Nov 20, 2008 6:58 pm    Post subject: Reply with quote
My first thought was- "If they don't leak, don't remove them."
Something to do with a lady named Pandora?
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Page generation time: 0.0335s (PHP: 60% - SQL: 40%) - SQL queries: 24 - GZIP disabled - Debug on
