Prop Problems
tejohnsrude
City/Region: Bremerton
Vessel Name: Darlene Mae
Photos: Darlene Mae
PostPosted: Tue Oct 21, 2008 3:43 pm    Post subject: Prop Problems Reply with quote
I have been having serious problems with prop failures. After about 50 hours they begin to free-wheel (engines race without cause). My mechanic tells me that this a a prop failure and not an engine problem. I do not do jack-rabbit starts, nor have I hit anything My prop-guy said that the wrong props were installed originally so different ones recommended with different pitch and different inserts between prop shaft and the actual prop. STILL NO BETTER. I have installed FIVE props in 2 Honda 40 HP outboards in a period of 18 months. Anyone else with this problem? Any insights?
Ted
PostPosted: Tue Oct 21, 2008 3:56 pm    Post subject: Reply with quote
This is undoubtably a "spun prop". If you search on that term, you'll find some hits. There's a rubber bushing between the drive shaft and the innards of the prop that is supposed to be a vibration/surge damper, I think. If you have hard/bad rubber or over torque it, the rubber can break down and the prop will spin loosely.
It's either indicative of a bad prop (the rubber is faulty in some way and failed) or over torqueing causing the rubber to fail. I had two Honda 45's on a 22 Cruiser for years and never a spun prop.
Thank heavens, a boat and not a political post. (unless the Democrats caused it! Shocked )
PostPosted: Tue Oct 21, 2008 4:28 pm    Post subject: Reply with quote
I was told by the counterperson at Pitch-O-Meter Propeller Service in Alameda, Ca, that the rubber bushings and hubs were presed into the props using a hydraulic press with Kayro Syrup as a lubricant.
My guess is that the sweet syrup dissolves out later with water and time, and/or sets up hard until the prop is eventually immersed in water.
Sounds feasible, enough, huh? Wouldn't want to use a petroleum product on a rubber bushing......
PostPosted: Tue Oct 21, 2008 5:57 pm    Post subject: Reply with quote
There has to be something wrong. I have only spun two outboard props in over 50 years of owning outboards which had the pressed in hubs.
Bad Boy
City/Region: Fresno
Vessel Name: Cat Fever
Photos: Cat Fever
PostPosted: Tue Oct 21, 2008 6:48 pm    Post subject: Reply with quote
What diameter and pitch are you turning?
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Tue Oct 21, 2008 7:20 pm    Post subject: Reply with quote
Are you maybe over torquing the prop nut?
marvin
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Oct 21, 2008 7:37 pm    Post subject: Torque on Prop Nut Reply with quote
Marvin,
I did not know that there was a specific Torque on the prop nut. Then again, I have never read the manual on changing the prop, I just did it.
Can you provide more info...
Steve
marvin4239
Photos: C-FLE II
PostPosted: Tue Oct 21, 2008 8:35 pm    Post subject: Reply with quote
Steve I don't presently have a Honda but I did have a Honda 50 for about 9 months. If I remember correctly the manual called for a very low torque on the prop nut maybe 15 lbs as opposed to my Suzuki which calls for 45 lbs torque. If you have the owners manual I'd check the torque value.
marvin4239
Photos: C-FLE II
PostPosted: Tue Oct 21, 2008 9:24 pm    Post subject: Reply with quote
http://www.honda-marine.com/mar_pdf/31ZW4600.pdf
Steve heres a link to the Honda prop install. It doesn't say to torque the nut at all just to hand tighten it. Then just tighten enough for the carter pin hole to be aligned.
Page generation time: 0.0417s (PHP: 64% - SQL: 36%) - SQL queries: 26 - GZIP disabled - Debug on
