Voltage leak?
C-Dawg
City/Region: Spanaway
Photos: C-Dawg
PostPosted: Wed Oct 08, 2008 11:18 pm    Post subject: Voltage leak? Reply with quote
I was in a hurry to button up the boat in her slip after fishing on Saturday and forgot to turn the battery off. I remembered on Wednesday and went to the marina to find the battery deader than dead. That took only four days to drain it.
Obviously there's a voltage leak somewhere. So what's the easiest way to find it? Should I place an ammeter between the POS post and main cable, then disconnect things until I notice a drop in amps? I could do the same thing at the fuse block behind the helm, couldn't I?
Since it's moored in saltwater, is there anything weird to consider?
Rick & Shirley
Go Dawgs!
C-Dawg sold November 2018
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Wed Oct 08, 2008 11:37 pm    Post subject: Reply with quote
Using an amp meter is a good way. The CO Detector runs all the time when the battery switch is on. Disconnect it first and see if the amps drop to zero. I have left my switch on and ran the battery dead because of the detector. Bilge pump is another one or anything else that might have been left on.
Jody Kidd
KE7WNG
Northern, Utah
PostPosted: Wed Oct 08, 2008 11:39 pm    Post subject: Reply with quote
Turn off all switches. Is there a AM/FM radio? This can drain;memory. Many electronics can also drain if in stand by. After the obvious ,check obvious with ampmeter.
ccflyer
City/Region: Bradenton, FL
Vessel Name: Retriever
Photos: ccflyer
PostPosted: Thu Oct 09, 2008 8:26 am    Post subject: Reply with quote
This may work for you. I installed it on a car that repeatedly had a dead battery due to the AM/FM radio issue mentioned by Dr. Bob
http://cgi.ebay.com/ebaymotors/Battery-Buddy-Computerized-Battery-Switch-Always-start_W0QQitemZ170260752807QQcmdZViewItem#ht_500wt_0
There is a very fine line between "hobby" and "mental illness".
Page generation time: 0.0296s (PHP: 58% - SQL: 42%) - SQL queries: 21 - GZIP disabled - Debug on
