Electronics/Electrical issues -- coincidence?
Lucky Day
City/Region: Churchton
State or Province: MD
Vessel Name: Lucky Day
Photos: Lucky Day
PostPosted: Sat Oct 04, 2008 10:51 am    Post subject: Electronics/Electrical issues -- coincidence? Reply with quote
I had Lucky Day out yesterday after it had been sitting in its freshwater slip for quite awhile. Three issues showed up:
1 - The Garmin 172C GPS started and worked fine, but shut itself off after 2-3 minutes of operation. Retried it many times but it continued to power itself off. The other gear on the same switched circuit operated fine.
2 - The depth gauge was intermittently erractic (reading shallower than the actual depth.
3 - The starboard trim tab would not deploy. The light at the switch/indicator came on and the port side tab functioned normally.
I will be doing all the standard troubleshooting on each device. Curious if there be a possible common source for the problems. Or just coincidence.
Thoughts?
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Sat Oct 04, 2008 4:23 pm    Post subject: Reply with quote
Maybe a bad ground connection.
Jody Kidd
KE7WNG
Northern, Utah
Lucky Day
Photos: Lucky Day
PostPosted: Sat Oct 04, 2008 4:37 pm    Post subject: Reply with quote
Thanks - I will check that out.
PostPosted: Sat Oct 04, 2008 9:49 pm    Post subject: Reply with quote
Measure the voltage at the connection for the GPS with a digital volt meter--take all of the connectors off, clean them and put back on with a corrosion blocking gel. It certainly could be a ground, but also on the positive side, with some corrosion.
Lucky Day
Photos: Lucky Day
PostPosted: Sun Oct 05, 2008 3:38 pm    Post subject: Reply with quote
Thank you Bob. I will check that as well.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun Oct 05, 2008 7:30 pm    Post subject: Unlucky? Reply with quote
I would also ensure that the transducer is clean and clear of any gunk. You might also check the setup to ensure that it is reading feet and not meters.
No other great ideas...
Steve
Page generation time: 0.047s (PHP: 61% - SQL: 39%) - SQL queries: 19 - GZIP disabled - Debug on
