Singles versus Twins
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sat Mar 24, 2012 7:02 pm    Post subject: Reply with quote
The other issue can be that you have two right hand motors--which is quite likely. You may need more trim tab correction.
From earlier remembrances, there are no outboards under 100 HP (I believe that is the HP cut off) that are available as counter clockwise, and I do know that our twin 50 HP Johnson (Suzuki under a Johnson cover) are clockwise rotating. I don't know the amount of "toe-in" on ours, but most certainly there is obvious trim tab correction. I've never noticed any "off steering" tendency on Sea Shift. I remember when Les at EQ Marine took me out on the "shake-down" cruise, that was one of many things he checked out for the proper set up.
Dave S.
"Sea Shift"
C-Brat #16
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sat Mar 24, 2012 7:29 pm    Post subject: Reply with quote
According to Les, Honda only makes left hand motors at 90hp and up so all of us with smaller Honda twins have right hand motors.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Sat Mar 24, 2012 11:22 pm    Post subject: Reply with quote
I certainly would not be one to argue with Les, but my Honda 90 swings a right hand prop. Most single engine boats run right hand props.
Mercury makes a 90 hp counter rotating lower unit. There were some counter rotating engines back in the late 80's Not sure that there are any true counter rotating outboard currently.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Sun Mar 25, 2012 12:35 pm    Post subject: Reply with quote
My engines are the same, and I am pretty sure they are right hand. I have tried to even out every other possible cause. I ended up adjusting with the tabs on the engines and got most of it out but it seems like with about 20 degrees of adjustment in the tabs it doesn't make for the most efficieint running. I might try the 3/16 toe in and see what that does.
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Sun Mar 25, 2012 12:47 pm    Post subject: Reply with quote
As I have a single 115 and kicker it really does not pertain to me, but I am interested. How do you adjust "toe" on an outboard? Thanks
Chuck
Bootleg Hooch
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sun Mar 25, 2012 1:17 pm    Post subject: Reply with quote
You don't with a single, but it looks like you get that. On twins you can adjust the bracket (at least on mine) to make them so the are not perfectly parallel with one another.
Spike
City/Region: Kent
PostPosted: Sun Mar 25, 2012 2:45 pm    Post subject: Reply with quote
T.R.
What bracket are you talking about? Do you shim one side of the motor as it hangs on the boat, or adjust using the tab under the cavitation plate? The mechanics of this intrest me. On my main I see no way of adjusting for toe. Maybe I'm missing something. Thanks
Chester
City/Region: home
Photos: Chester
PostPosted: Sun Mar 25, 2012 2:47 pm    Post subject: Reply with quote
The trim tabs on our boat are set at at least 20 degrees, prolly more. Don't be afraid to add another 5 or 10 degrees. You won't know unless you try. The drag imposed by that little tab is miniscule compared to drag created by having to force the boat to maintain course.
Look at the size of Doel Fin or Bennett trim tabs that some of us shove into the water in order to make our boats more efficient.
Chester
City/Region: home
Photos: Chester
PostPosted: Sun Mar 25, 2012 2:50 pm    Post subject: Reply with quote
Spike wrote:
T.R.
There is an adjustable tie rod between the engines that is a part of the steering linkage.
Yellowstone
State or Province: MT
C-Dory Model: 22 Classic
Vessel Name: Farwest II
Photos: Farwest III
PostPosted: Sun Mar 25, 2012 3:57 pm    Post subject: Reply with quote
Just a thought. Having crossed the Pacific several times on the water and seeing ships with one propeller (although most trans- oceanic ships have twin or multiple screws) making the crossing. given the reliability of both 2 and 4 cycle motors properly maintained, the redundancy of twin motors may be more of a comfort factor than a reality one. But it really may depend on the nature of your boating. I guess I'm more confident in today's motors. Besides, twins gobble up space on the transom of a 22' complicating swim steps, steering and tabs, and simply are less economical on plane than a single engine. It is interesting to note that the Marinault is designed for a single engine; Les and his folks are comfortable with the single engine design. Then again, each person needs to scratch his fleas in his own way. John
PostPosted: Sun Mar 25, 2012 4:02 pm    Post subject: Reply with quote
Spike wrote:
T.R.
Toe in/out is only used with twin engines. Think about feet and "pigeon toes". You can't do toe in/out with one main engine. The little trim tab under the cavitation plate is there to help offsite the single prop rotation and keep it on course at higher speeds where the tab has more effect.
Think of the front wheels of a car for toe in/out. Two wheels. If you were riding a unicycle, it would not apply.. Wink
Spike
City/Region: Kent
PostPosted: Sun Mar 25, 2012 4:48 pm    Post subject: Reply with quote
I knew that I did not need to worry about toe in or out as I have a single with a kicker. I was wondering how a person set and adjusted the toe on a twin set up.
Chester
I did not even think of the tie bar between the two motors. Next questions, Can you adjust the toe in or out force useing just the tab under the cavation plate, and do you have to adjust for toe in/out when the motors are mounted farther apart as in a Tomcat or a larger mono hull deep V where the motors may be farther apart than say a 25 or 22 CD. Thanks
Chester
City/Region: home
Photos: Chester
PostPosted: Sun Mar 25, 2012 5:29 pm    Post subject: Reply with quote
Spike wrote:
Chester
The tab is there strictly to compensate for steering torque. Toe in is the geometric relationship between the motors. Deep V hulls require more toe in than shallower hulls such as C-Dory monohulls.
I don't know how varying distance between the motors affects toe in requirements. Some race boats use toe out for certain applications but that also is above my pay grade.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Mon Mar 26, 2012 2:11 pm    Post subject: Reply with quote
One thing to clarify is the definition of toe "in" vs "out". The way I understand it is, that for toe in, you adjust the front of the outboards outwards, more away from each other, as compared to exact parallel.
This increases efficiency and provides better steering centering by aligning them with the natural direction of water flow at the stern of the boat. You want the two wakes to merge correctly at some distance behind the boat at a given speed -- I do not know that speed/distance, it would vary by the length of the boat and the distance between the engines.
Is that what others understand?
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Mon Mar 26, 2012 2:20 pm    Post subject: Reply with quote
Teleflex says:
"Toe-out = props farther apart than engine centerline (the prop is the "toe" of the foot, the engine gear housing is the heel).
Toe-in = props closer together than engine centerline (pigeon toe!).
Although I don't know the percent of single screw commercial ships--it is very high. Many of these can de-couple a cylinder and then use 11 instead of 12 (for example)--Some can be repaired under day. Most commercial fishing vessels are single screw.
Page 6 of 7
Page generation time: 0.0695s (PHP: 65% - SQL: 35%) - SQL queries: 28 - GZIP disabled - Debug on
