Singles versus Twins
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Grumpy
City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
PostPosted: Fri Mar 23, 2012 11:01 am    Post subject: Reply with quote
Charlie,
As payment for my past sins, many of "my" products are incorporated in brand new airplanes which take off, make a left turn, and fly over my house many times per day Shocked
Don't start me on my favourite soapbox, it runs through several bottles of wine.
But, if your car or boat had the same despatch reliability as a modern airplane, you would sell it quickly.
Cheers,
Merv
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Fri Mar 23, 2012 1:05 pm    Post subject: Reply with quote
rogerbum wrote:
However, I will point out that there were a couple of times, I launched my 22 to discover after untying that the mechanical steering had seized due to no use for a few months. That's really uncomfortable after you've pushed off a dock and are adrift in a current. On a couple of occasions, brute force released it. But after that, I learned to check my steering before pushing off and to move the engines every month or so during storage.
The USCG requires a commercial captain to test the steering by turning from lock to lock prior to getting underway. Woe to the captain who forgets and casts off with no steering!
Larry H
A C-Brat since Nov 1, 2003
PostPosted: Fri Mar 23, 2012 1:30 pm    Post subject: Reply with quote
Larry H wrote:
The USCG requires a commercial captain to test the steering by turning from lock to lock[b] prior to getting underway.[/b] Woe to the captain who forgets and casts off with no steering!
Since this is Singles vs Twins, I just can't resist. This Lock to lock check -- a good idea, especially for a singles system. It has not been my practice to even turn the wheel until I am out of the marina Shocked but then with the twins hanging out on back, the low speed steering is done with the differential throttling or unilateral forward and reverse control. Crook Looks like now there is something else to add to the pre trip check list. Good heads up, Thanks.
Chester
City/Region: home
Photos: Chester
PostPosted: Fri Mar 23, 2012 1:48 pm    Post subject: Reply with quote
Harvey, a quick question. How much toe in do you run on your outboards?
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Fri Mar 23, 2012 4:23 pm    Post subject: Reply with quote
I'd skip the Teleflex system and go straight to a Voith Schneider Propeller:
http://en.wikipedia.org/wiki/Voith_Schneider_Propeller
They make them for large ships and tugs, and there's a tiny version for RC models, so we just need something in between! Smile
Of course, the draft wouldn't be 8 inches anymore...
PostPosted: Fri Mar 23, 2012 4:27 pm    Post subject: Reply with quote
I do know there is such a thing, but I don't know how much mine are set at. In talking with my mechanic, if I remember right, because the twins are very close together comparatively, I don't recall that "toe in" would make any difference.
I'm open to learning more on it. Affect on vessel, with and without, and anything else important, I guess.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Fri Mar 23, 2012 4:47 pm    Post subject: Reply with quote
I have twin 80's on my CD25, the toe-in is set for 3/16" at the front steering bar that joins the two motors. That is the number I was given when I took delivery of the boat, and have kept it there (repaired the slave steering cylinder once, requiring removal). Not sure how critical this is or even if it affects the operation/steering.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Fri Mar 23, 2012 4:55 pm    Post subject: Reply with quote
This captain now requires it too. But I learned it the hard way and it took me two lessons (I'm a slow learner).
Chester
City/Region: home
Photos: Chester
PostPosted: Fri Mar 23, 2012 4:58 pm    Post subject: Reply with quote
My boat came with 1/4" toe out, measured at the nose cones and propeller shafts. It was difficult to maintain course at that setting. After changing it to 3/16" toe in it handles much, much better. Thing is, I haven't tried fine tuning it and it is possible there is a better setting.
PostPosted: Fri Mar 23, 2012 5:10 pm    Post subject: Reply with quote
Pretty hard to measure on a TC255. We have a "liquid tie bar" which allows an almost infinite toe in toe out setting. Our engines are VERY far apart compared with a usual twins setup.
Come to think of it, maybe control of that connection could do a partial Optimus 360 trick!!
PostPosted: Fri Mar 23, 2012 7:05 pm    Post subject: Reply with quote
Two words--Lightning Strike--either direct, or nearby in the water. All systems are out! I see it happen frequently down here in Florida.
I know of one at least one large Nordhavn which was totally disabled by systems electronic failure. (There is suspicion that a second one also had this and was the cause of its loss). These are very high end yachts which cost millions of dollars, and should have back up systems.
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Sat Mar 24, 2012 12:25 pm    Post subject: Reply with quote
This is the first time I have noticed a discussion on "toe-in" for twins. I have never been happy with the steering on my 22, it bears to starboard. I changed the tabs on the engine and it helped but still not correct. Does anyone know the correct toe-in for twin honda 35's, 40's, or 50's?
Chester
City/Region: home
Photos: Chester
PostPosted: Sat Mar 24, 2012 2:32 pm    Post subject: Reply with quote
I assume you have twins?
Dues the boat sit level, side to side, with everyone aboard?
Are the props identical? Does one, or both, have hidden damage. Have you tried switching them?
Are both tachometers accurate? Are you reading them accurately (parralax?)?
Does the steering system need maintenence?
Try 3/16" toe in.
Keep after the tabs.
Make one change at a time so's you can identify and isolate problems.
I'm not an expert, this is just me thinking out loud.
PostPosted: Sat Mar 24, 2012 2:40 pm    Post subject: Reply with quote
Chester, according to his profile, he has twin 35's.
Maybe the port one got switched with a 45 and just LOOKS like a 35??
Shocked Laughing Rolling Eyes
PostPosted: Sat Mar 24, 2012 6:47 pm    Post subject: Reply with quote
The other issue can be that you have two right hand motors--which is quite likely. You may need more trim tab correction.
Page 5 of 7
Page generation time: 0.0729s (PHP: 64% - SQL: 36%) - SQL queries: 32 - GZIP disabled - Debug on
