Posted: Thu Dec 30, 2004 5:32 pm Post subject: |
Larry, good to know. I've got so many electronic gadgets on my shelf that I'd never be able to give it up. Do you have any pictures?
K4KBA |
Posted: Thu Dec 30, 2004 6:27 pm Post subject: |
Tom and Charlie-
I have a manual wiper on my 22 which has a fixed window. Absolutely great in a driving rain, even with electrics on the other two windows.
The electric one won't work on the center one because the motor won't fit where it has to at the top or bottom due to the shelf above and the tray below. Might work without the top shelf as Larry has done.
My manual wiper pivots on the left side, about 4 1/2 inches down from the corner. Would have put it on the right side, but the massive wiring harness from the shelf electronics comes down right at the side where the hole would go.
Ken (BC) has a manual wiper on an opening front center window set up in such as way that the window opens just fine by simply swinging the wiper off the frame, if I remember the conversation from last year correctly. He will soon be along to clarify this. There is a photo in his album of this set up here:
http://www.c-brats.com/modules.php?set_albumName=Blue~C&id=wipe3&op=modload&name=gallery&file=index&include=view_photo.php
HTH. Happy New Year! Joe. _________________ Sea Wolf, C-Brat #31
terraplane
Joined: 09 Dec 2004 Posts: 524 City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
Posted: Tue Jan 04, 2005 5:06 pm Post subject: udate on possible purchase |
Well, thanks for all the advice and good humor.
I'm off to the Baltimore Boat Show to talk to Cutter Marine, in late January.
I think I have my specs in order now and will post the updated list of options for comment soon.
RE: camper back. Does it have to stay up all the time? Or, can just the top cover be used without the sides at times. The thunderstorms on the Chesapeake with winds sometimes of 40 and 50 might preclude leaving it up. How is it mounted?
tom/ terraplane |
Posted: Tue Jan 04, 2005 5:31 pm Post subject: |
Tom, I've just got a bimini on Capt's Choice but a camper back is a bimini with sides... The sides can be solid, screened, clear, zippered or snap on, etc. As many types as you can think of ideas for. The frame is either stainless or aluminum and it fits in sockets or on the hardware you can buy for rails, etc.
It can cover the whole cockpit back over the motor well or just back to the motor well, lots of styles. King Canvas on the West Coast is the best known of the makers, you can see their work on the CD factory website.
Not sure who makes them here on the right coast but the folks at Cutter can tell you and I'm sure others will chime in.
Good luck..Charlie |
Levity
Joined: 02 Nov 2003 Posts: 204 City/Region: Shippensburg
Vessel Name: Levity
Photos: Levity
Posted: Tue Jan 04, 2005 8:37 pm Post subject: |
Tom,
I have a 22 from Cutter purchased in 11/03. My suggestion for cockpit cover is to mount it with stainless hardware as the stainless stuff is significantly more robust. Also, a zipper installed within a couple inches of the cabin top mounting track will enable you to unzip the top and drop it in a hurry. Otherwise the entire top must be slid out of the mounting track. Look up the canvas top installation on DaNag. This installation appears well thought out and well executed. Cutter did not do the canvas installation nor would they recommend an installer. I did order mine from King and had it installed by a local installer. The canvas top is a trade off between protection when the environment turns harsh and added complication in storage, cleaning, erecting and collapsing the top.
Mike 'Levity' |
terraplane
Vessel Name: BANJO
Posted: Thu Jan 06, 2005 9:12 pm Post subject: some more questions for 22 c dory purchase |
OK, getting close. Got a contract today from Cutter with the detailed list of options, etc.
Question: I've ordered the windlass..Delta, and it comes with chain ...is that a good idea. Here on the bay ,with eight boats, i've always had about 20 feet of chain , then line. Comments?
Never had towed a boat...how big a vehicle do i need? I have a Subaru Forester, automatic, rated for 2,000 pounds towing.
Any help appreciated.
tom,/terraplane |
Posted: Thu Jan 06, 2005 9:25 pm Post subject: |
Tom, with our soft bottom on the bay(not mine personally mind you ), that amount of chain is fine. I've only got about 10 ft with 150 ft of 1/2" nylon rode. No windlass. Never had a problem with anchoring anywhere around the bay area.
The Forrester won't cut it . A fully loaded CD 22 on either a single axle or double axle trailer will go 4000- 5000 pounds . There is lots of traffic on the site about towing weights, do a search on some of the words. I tow with a 3/4 ton Dodge V-10, admittedly an overkill but I also tow a 28' camping trailer that goes about 11,000. That truck doesn't know the CD is there when I tow it .
Here's your chance to buy a new vehicle too! What could be better! Almost any of the mid size SUVs will do the trick, half ton pickups, etc. Go for it. Keep us posted and come see us down on the Potomac.
Charlie |
terraplane
Vessel Name: BANJO
Posted: Fri Jan 07, 2005 5:12 am Post subject: anchor/towing |
Thanks Charlie, Suspected as much about the Forester.
Cutter says the rode of chain helps balance the boat, that without it the bow tends to be a bit up in the air. I agree about the Bay...have never needed more than what i described, even in an emergency.
I've been up the Potomac many times...in my old slow boas. We make a trip of it, from Rock Hall to DC, with stops at Tilgman, Deal Island, Solomons, St. Mary's City, then up the rivere, with one overnight somewhere on the Potomac before DC. With a c dory, even at 6kit, this will be an express trip!
tom |
terraplane
Vessel Name: BANJO
Posted: Wed Jan 12, 2005 9:32 pm Post subject: terraplane places 22 order! |
Today I placed my order with Cutter Marine, Chesapeake Bay, for a C.Dory, 22....nicely equipped, as they would say.
Will take delivery in early April, giving me time to sell my children, my mother in law and my priest to get the money! (Just kidding).
Thanks to all of you who were kind enough to give me advice. I am constantly telling people about this site, even if they are not C Dory owners...great humor, great boating advice, and nice people.
tom/terraplane |
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2376 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Wed Jan 12, 2005 9:52 pm Post subject: |
Congratulations Tom,
Keep us posted. We have photo gremlins over here near the factory that can snap a picture. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Joined: 02 Nov 2003 Posts: 8562 City/Region: Birch Bay, WA
Posted: Thu Jan 13, 2005 10:32 am Post subject: Re: anchor/towing |
We too have a Forester and were planning to take our boat home with it...a friend suggested we check the manual for towing capacity, and as you have discovered, a C-Dory requires about double the towing capacity of a Forester. So we dashed out and bought a used Expedition, the new roof will have to a wait a few more years...
terraplane wrote: | Thanks Charlie, Suspected as much about the Forester.
tom |
Otter-BelleHavenMarina
Joined: 03 Nov 2003 Posts: 390 City/Region: Alexandria
Vessel Name: Otter
Photos: Otter
Posted: Thu Jan 13, 2005 10:36 am Post subject: |
Congratulations! Look forward to cruising with you sometime this spring or summer!
Best wishes, _________________ Tom on Otter |
Crab Cake
Posted: Thu Jan 13, 2005 7:01 pm Post subject: New CD 22 |
Hi Tom,
We also boat out of Rock Hall and like you I've been looking
at CD 22's. If we get really serious I may pick your brain
a bit to gain from your experience. The feedback on this board
is great and really gives you things to consider before putting
down the bucks. Good luck with your new purchase. By the
way, are you the one who said blue was a bad c-bay color?
Would love to hear more on that! Steve / crab cake  |
Posted: Thu Jan 13, 2005 7:12 pm Post subject: |
Hey Tom (Terraplane), don't sell the kids and mother-in-law , or maybe just the MIL, why don't you get one of those new life insurance policies like I got.
They gave me the money now and when I die, the kids have to pay it back....
They seem to be suddenly worried about my welfare....  |
Posted: Thu Jan 13, 2005 7:17 pm Post subject: |
Tom, another comment, just went back and read the thread...
Wait on all the chain. My boat sits with the bow slightly down, even without all the chain. I don't have the midships bilge pump and I get water in the cabin, or did until I put a plug in the drain hole between the cabin and the cockpit. A pain to drain/soak up after a rainstorm. A bit more down by the stern would be fine for me. Once I get underway, the water runs aft, and the pump takes it right out.
You really don't need much chain for the bay anyway.
Charlie |
