C-Series vs E-Series vs Garmin + Autopilot....
Goto page Previous  1, 2, 3, 4
PostPosted: Fri Feb 01, 2008 10:18 pm    Post subject: Reply with quote
RayMarine is CYA on a subject which now has over 25 pages of posts on THT and which they are very aware. The person who had the complaint has placed a copy of his registration on line, as well as the seriel number of the chart plotter, which showed it was manufactured in March 05, and he has electronic proof of purchase it in 06. This is not at all unusual. Here is what he wrote:
"When originally I REGISTERED all 4 items on RAYMARINE's website electronically, they created an "INSIDER" account. In there you can register all your products, serial numbers, your personal information etc. It said nothing about I needed to send in the registration cards as well. I was under the impression, and I think I am right about this, the electronic registration was in lieu of sending hard copy. At THAT time they they also asked for proof of purchase..They had me fax them only thing I had. Print outs of PayPal transactions and the EBay information as printed from the screen."
RayMarine had dealings with him about the unit, and until it was obvious that the unit had to be replaced there apparently was no question.
But apparently the registration along with screen shots of the pay-pal and E/bay transactions were not enough proof for RayMarine.
I buy Electronics on the internet, but in every case, I buy from an outfit which is established, has certified techs on their payroll, and I get an invoice in the packed material. I would think that if you have a letter signed by an official of RayMarine saying that your object which you purchased on E/bay was covered, then that would certainly be sufficient. But I would not rely on just "information".
I put this on the forum for what it is worth--a caveat.
PostPosted: Sun Feb 03, 2008 12:49 pm    Post subject: Autopilot? Reply with quote
OK, it's a done deal (again!) this time from a reputable dealer and not through E-Bay. Got the E80 System Pack and the 4KW dome. Was able to find it with a 5M cable (vice the 15M one) that has a right angle connector for the display. That should be just right as the dome will be near the front of the pilot house. I hated to coil up all that cable on CAPTAIN'S CHOICE.
Now for an autopilot. Byrdman has a SIMRAD that he swears by but they apparently don't make his model, the AP16V any more. I'm a little leery of the interface with a dissimilar mfr but since it's a NEMA electronic one, shouldn't make any difference. I'd like to have the wireless capability but would want the control head too. My TC255 has the Seastar Hydraulic steering with twin Suzi 115's on it. The autopilot should give me the stable heading info I need for the correct Radar overlay, I think.
What are others using and what is your recommendation? Where are the electronics/hydraulic pump located? I had a ST6001 on CAPTAIN'S CHOICE but never got around to installing the pump. Hopefully the new owner did it.
PostPosted: Sun Feb 03, 2008 1:55 pm    Post subject: Reply with quote
I misspoke and need to make a correction. Garmen bought up TR-1 to fill their need for a auto pilot not furno. sorry about the miss information.
Sawdust
City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
PostPosted: Sun Feb 03, 2008 3:04 pm    Post subject: Reply with quote
Charlie,
Not to worry. I have the Simrad pilot with the E120/4KW - works great.
Dusty
PostPosted: Sun Feb 03, 2008 4:32 pm    Post subject: Reply with quote
Has anyone interfaced the NEMA on the Suzuki Engines with the RayMarine E series to get an engine display?
PostPosted: Mon Feb 04, 2008 12:23 am    Post subject: Reply with quote
You should get a rate gyro on the auto pilot, rather than just the flux gate compass, for several reasons. First it will give a more stable heading with the pilot, and second it is necessary for the Radar overlay. RayMarine makes several very good pilots. Simrad/Robertson also has some very good pilots---but not sure about the compatablity of the rate gyro compass (which is available on the Simrad also. Both RayMarine and Simrad have the virtual feedback, and with the outboards I would consider this a real plus. Most outboard pilots come with a linleal feedback, which does not work well--and it is best to do with a rotary feedback.
This is a place where you would be smart to contract with an electronics firm. You will need some help with setup--although it can be done, it can be a bit tricky. Also you will have to bleed the SeaStar hyraulics. There is an electric pump set which makes this much easier, less messier and much faster, which a good installer will have. Maybe you can do the physical installation, but then have the final setup done by the technician.
As for the 115 Suzuki--From what I understand you will have to use the Suzuki or Lowrance (the same) NMEA back bone--and probably use a Lowrance LMF 200 or LMF 400 guage for part of the interface--then splice a RayMarine cable to the Suzuki cable. There does not seem to be a direct Suzuki to RayMarine cable--plus you need the backbone. There are two connectors--red--the newest and Blue--the older ones. Try and use all red connectors. There should be a 3 cm plug on the left front of the engine which is 3 cm in diameter and the EP 20 adaptor will plug in there, and then into the backbone. The question is how much "stuff" do you want to clutter up the navigational display with. Most folks who are doing this, are using the Lowrance guage for most of their engine data (it includes fuel flow, oil and water pressure, temps etc).
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Feb 05, 2008 12:53 am    Post subject: Reply with quote
I am trying to do the same thing with my Yamaha NEMA. Tried to find a Yamaha booth at SBS but no joy. Will have to contact Yamaha directly, I guess...
Doryman
M/V Lori Ann
Anacortes, WA
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Tue Feb 05, 2008 10:42 am    Post subject: Reply with quote
Captain Cat;
I have a Garmin 3210 with all network digital options and the 4kw radar. Love it.
However, I chose the Simrad AP16 for the autopilot, which has a virtual rudder feedback rather than mechanical. This makes for easier install and less items to break, which is common with mechanical feedback rods. I didn't hook up the AP to my plotter but, it is a simple operation if I thought it was needed.
Mounting was all overhead and I have a completely clear view and clean dash board. Look at photos in my album to see mounting.
Gene Morris
tight lines
PostPosted: Tue Feb 05, 2008 11:01 am    Post subject: Reply with quote
Thanks Gene, nice looking install. In the picture that has the hydraulic pump in it, where are those electronics/pump located? Looks like it may be forward of the helm under the hatch in the bow berth? Maybe I wouldn't have to cut my hydraulic lines, just run them from the pump to the helm ones and run the old ones that were into the helm to the pump. Is that what you did?
Gene Morris
Photos: Reefmadness
PostPosted: Tue Feb 05, 2008 10:22 pm    Post subject: Reply with quote
Charlie;
Yes, they are forward of the helm in the starboard sponson. The compass is on the centerline under the berth.
Hope that helps
Gene
Chester
City/Region: home
Photos: Chester
PostPosted: Thu Jul 03, 2008 9:18 pm    Post subject: Reply with quote
A little late to the party but here goes.
It seems that power consumption might be considered when deciding which system to go with.
For example the Honda 40's common on many C-Dorys only have 10 amp, 126 W alternators. The engines aren't necessarily run at rpm's that will yeild those numbers either. And batteries could be weakening too.
An E series Raymarine that uses 20 W power coupled with the 34 W draw of the 4Kw radar antenna on top of all the boat's other electrical demands really add up. Although a C series that uses 10 W matched the 2 Kw antenna using 28 W saves only16 W.
Lets not forget the 30 W the depth module uses.
Or am I making a mountain out of a molehill?
Page 4 of 4
Page generation time: 0.0547s (PHP: 66% - SQL: 34%) - SQL queries: 24 - GZIP disabled - Debug on
