Batteries - Again / Still
PostPosted: Mon Dec 31, 2007 1:33 pm    Post subject: Reply with quote
The visual damage is confined to the strap from the starting battery negative post to the house battery bank negative post, and the strap from the VSR battery switch to the starting battery positive post. Guess I won't find out about anything else until I replace those two items and the battery switch. Don't know how to test for other damaged wiring...
AstoriaDave wrote:
I suspect you may have some damage to wiring you can not detect visually.
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Mon Dec 31, 2007 1:34 pm    Post subject: Reply with quote
journey on wrote:
Welcome to the club, Pat. Now you know how humans learn, at least me and my kin.
Remember the KISS principal, espoused by Sea Wolf, above. It minimizes (doesn't eliminate,) the chance of screwing up.
By the way I looked up the Xantrex XC charger. It's more expensive than the Truecharge Plus charger, and appears to be better only if you mix different types of lead acid batteries; i. e., AGM with flooded with gel, etc. If you don't do this, why pay extra? Yes, I'm cheap. Defender has the 20 amp Trucharge for $260. It's enough for your battery setup.
If you add in the cost of the remote display, which comes with the
xc3012, the two chargers are nearly the same price. The remote
display is nice and saves you the trouble of wiring meters. I would
say it's easier to wire the control display for the xc3012 than it
would be to wire meters. I don't know much about the remote display
for the truecharge.
Note that the mounting positions of the xc3012 are limited. I don't
remember the details, but check the manual, which is available online,
before purchasing.
Mike
PostPosted: Mon Dec 31, 2007 3:02 pm    Post subject: Reply with quote
Mike has a good point. Whomsoever buys one gets to take their choice.
However, remember to install a separate battery voltmeter, since the remote panel is OFF when there is no AC power.
And, yes, I do not have much to do today.
PostPosted: Mon Dec 31, 2007 4:24 pm    Post subject: Reply with quote
Pat-
Wow! Glad you weren't hurt or burned with acid, etc.
I guess the batteries were out in the cockpit so that most of the battery acid was spewed out where you can wash it down and out of the back of the boat?
If you decide to move the two Optima batteries up into the cabin, you might think about the weight involved and the balance of the boat. I put two group 27 marine batteries under the forward dinette seat, and it threw off the balance of the boat enough that I wound up adding a couple of spare anchors under the galley to help balance them out!
Good Luck!
Joe. Thumbs Up Teeth
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Dec 31, 2007 4:49 pm    Post subject: Reply with quote
Pat,
I would hose off anything that the fumes got to. Those fumes are acid!!
After washing down, sprinkle some baking soda around the batteries and anywhere the fumes got to. If the baking soda fizzes, then acid is still present. The baking soda will neutralize any remaining acid.
If your 25 has an aluminium gas tank, I would wash out the bilge and the tank compartment.
You are lucky, some direct shorts on batteries result in an explosion!!
I always carry baking soda to neutralize any acid spills around batteries.
If those are wet cell batteries, check the fluid level in the battery. If very much fluid is missing, that acid was boiled out.
It might be a good idea to take the batteries to a battery company to be checked out. (Pacific Power in Everett on Broadway near 41st is one place)
Larry H
A C-Brat since Nov 1, 2003
PostPosted: Mon Dec 31, 2007 5:02 pm    Post subject: Reply with quote
I did not see any liquid...just gas clouds.
Anyway, for some very expensive cabling, 6' of #2 black to connect the negative posts of the two banks, 2' of #2 red to go from the VSR switch to the starting battery, all is APPARENTLY working again. Power to the house and power to the outboard. The only thing I don't know is if the relay that is supposed to control charging from the alternator still works or not...
All this from just changing out a starting battery and making a careless mistake...
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Mon Dec 31, 2007 5:21 pm    Post subject: Reply with quote
Just chalk it up Pat, one more thing you probably WON'T do the rest of your life! People are usually good at doing something, you're evidently real good at making brew (will have to try some someday). So don't beat yourself up too much, we've all been there, some admit it, some don't. Rolling Eyes
Thanks for sharing your thoughts too. Happy New Year (gotta be better, eh?).
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Mon Dec 31, 2007 5:33 pm    Post subject: Reply with quote
Pat- Thanks for sharing your 'teachable moment'. I learned from it and appreciate it.
MartyP
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Dec 31, 2007 6:17 pm    Post subject: Reply with quote
Pat,
The gas cloud IS acid. Please... at least sprinkle some baking soda around the affected area to see if there is any acid on the surfaces.
While I was a mechanic years ago, I caused a battery to explode in a new MGB by disconnecting a running battery charger (a customers car, not mine). The battery was under the rear package shelf and spread acid all over the inside of a new car.
The mechanic next to me grabbed a water hose and sprayed me and the car interior. We continued washing down the interior and managed to save the car. (and my job!!)
For safety, always turn your face away from a battery when detaching a battery charger or jumper cables.
PostPosted: Mon Dec 31, 2007 10:23 pm    Post subject: Reply with quote
Battery Stories, Continued............
#1:
I had a "baddish" nearly discharged battery explode (one cell only) in a little 12 foot Gregor aluminum boat a few years back.
I knew the battery was largely discharged, but decided I'd run the motor all day, mostly trolling, and see if the little 4 amp charger in the motor would bring it back to fully charged.
About four hours later it exploded! Sounded like a cherry bomb!
Fortunately, the battery was in a battery box with the lid strapped down.
I stopped the boat, waited for the noise to stop, then used water from the lake to dilute the acid, etc.
2#:
We were visiting my Aunt in Los Angles eons ago (right after WWII) when someone knocked on the door, saying they had a battery problem. This was a old car, a pre-war Plymouth, as I remember, with the battery under the front passenger seat! We went out and it looked like "Old Faithful" was under the seat spewing forth! (This was back in the days when cars had 6-volt batteries!) Tow truck time!
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Dec 31, 2007 10:40 pm    Post subject: Reply with quote
[quote="Larry H"]Pat
Or Smoke from wire insulation??
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Dec 31, 2007 11:02 pm    Post subject: Reply with quote
tsturm,
Pats description of "clouds of gas" lead me to conclude that the batteries were overheated by the direct short and boiled.
If it was smoke, thats better.
Perhaps this is better advise:
I suggest checking the fluid level in the batteries and if it is low, then treat the area for acid. It the level is normal, then suspect smoke and look for burned wiring or melted insulation.
PostPosted: Tue Jan 01, 2008 12:28 am    Post subject: Reply with quote
We had burned wire for sure...I did hose the cockpit down with water and sprinkled it with baking soda. Tomorrow I will check the electolyte level on the starting battery, there is nothing to check on the Optima house batteries. Both are showing full charge, so hoping all is OK...we are anchored up at Andrews Bay in Lake Washington for the night, nothing to do except hope the Wallas does not shut down!
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Tue Jan 01, 2008 1:54 am    Post subject: Reply with quote
Pat,
That's good news!!
I hope you get to enjoy a nice NEWS YEAR DAY!!
Larry H
PostPosted: Wed Jan 02, 2008 10:01 pm    Post subject: Reply with quote
Wow, I fly back from LA and all you want to know (and more) about batteries comes up on the forum!
The only other comments I might add are:
1. We consider 50% discharged at 12.20 volts (the are variations of the table and the voltage varies by manufactuer and type of battery)
2. We use AGM for batteries which will be left for peroids of time and not used, for batteries which are kept in the living spaces, or batteries which are mounted in unusual positions (for example in our 25 the two group 31's are on their sides behind the water heater)
3. We put a breaker equal to the current draw or input 7" from both the battery and the charger. For example, we have a 40 amp breaker on both ends of the #6 wire going from the charger in the Tom Cat to the batteries which are in the Lazarette.
4. When we are going on a long trip--away from resources, we will replace our batteries every 4 years. They may last longer, but we find that 4 years is a good replacement cycle. The Golf Carts in my RV are 5 years old, and still holding charges well, so we will stick with them for now, since we have a new engine/generator starting battery and the golf carts are not essential to operation.
5. Battery weight equals capacity--the more weight, the more capacity. If you have a 30 lb Optima battery, there is no way it will have the same capacity as a 60 lb lead acid battery, although the technology in the Optiima is "better".
Pat, I am glad you were not hurt--what an experience!
Page 3 of 5
Page generation time: 0.0473s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
