Bulging Fuel Tanks
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Sun Feb 13, 2005 6:59 am    Post subject: Great Saying... Reply with quote
Gee's, I love it:
"...as we wander down that golden road to geezerhood, and thus why we all wind up as old gnarly farts joyously fiddling around in boats..."
Priceless.
Thank you!
Casey
C-Dory Naknek
(50% Geezer; 50% Gnarly ... but getting There!)
Sawdust
City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
PostPosted: Sun Feb 13, 2005 12:04 pm    Post subject: Reply with quote
Wow! I love it too. If only I could remember my name and sign this...er.... this what? Today's me day. 85! Wow .... soon catch up to Tyboo Mike.
PostPosted: Sun Feb 13, 2005 12:22 pm    Post subject: Reply with quote
Dusty-
85 and still messing around (in boats, that is)! I love it! Congratulations!!! You're the Role Model and the "Poster Child" of this wonderful community. Have a brew or two and enjoy yourself on this special day! Joe.
PostPosted: Sun Feb 13, 2005 3:25 pm    Post subject: Reply with quote
Sea Wolf wrote:
Mike-
"It is kind of strange that those heavy walled tanks would bulge as much as they do. But every container of liquid wants to be round by nature. A circle provides the largest area of any shape with a like perimeter dimension. (Oh no - if I got this physics statement wrong, Sea Wolf will be all over it!) Otherwise we would have square pipes, and millwrights could be plumbers."
Grade = A. CONGRATULATIONS!
Right you are!!! Pressure in a liquid flows out equally in a liquid or gas and results in rounded shapes: circles in two dimensions and spheres in three.
This also explains why our brains are encased in spherical skulls, namely, so that more nerve cells can be packed in a smaller space, making for the miracle of human intelligence!
It also explains, after a few years of time passing, why some people seem to have lost a good part of their original God given cranial content, since liquids like to flow downward under the influence of gravity, and hence the term "Brain Drain". <text clipped>
Might also explain why so many of our bodies seem to take on more circular shapes as we get older.... I'd much rather blame in on physics than a lack of exercise combined with a lack of self control....
Roger on the SeaDNA
Mighty Bite
Vessel Name: Mighty Bite
Photos: Mighty Bite
PostPosted: Wed Mar 09, 2005 2:28 am    Post subject: Reply with quote
My new 25 gal tanks rolled in so its time to decide how I want to do the cleat/retainer treatment for them.
Lateral cleats will be mounted on the underside of the splashwell and bear on the top edge of the tanks.
For the front cleats I will use either plan A, which is to epoxy SS bolts in the floor and in doing so enlarge the cavity sufficiently to accept a generous amount of epoxy and thereby (hopefully) enhance the strength and holding base for the bolts. Pretty much as Ken on Cavu did, except I plan on using stainless angle for the cleats as opposed to the starboard material.
Or....... epoxy threaded inserts in the cockpit floor, here again, within an enlarged cavity, and using ss bolts to secure the stainless steel cleats to the cockpit floor. This latter option may be rendered moot if I'm unable to come up with adequate threaded SS inserts. I'm ready to pretty much guarrantee there is nothing of the kind available in lovely Fairbanks, AK, as I think I've exhausted the local possibilities.
I do have the luxury of a little time however, as it is still too cool to mess with epoxy outside.
Mark on Mighty Bite
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Wed Mar 09, 2005 9:52 am    Post subject: Reply with quote
Maybe there has been a tank failure and the poor SOB never lived long enough to tell anyone about it. Clock I shudder at the thought of that fuel getting loose in the cockpit. I have noticed the bulge in my tanks and the first screws in the front startboard have kinda pulled. If they bulge at rest they must really flex in and out when you hit rough water. The front starboard seems like more of a protector of the front of the tanks than any real solid mount. Has anybody used a buckle strap going around the circumfrence of the tanks? One of those small ratchet straps would really pull up tight. Seems like getting this good and tight when the tank is near empty would help stemmy the outward expansion of the tank without a modification to the boat.
Chris
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Wed Mar 09, 2005 12:39 pm    Post subject: Reply with quote
I seem to recall that the bulging in plastic tanks is not caused by the weight of gas in the tank, but it is caused by a reaction of the tank with gasoline.
Greg (Red Fox) installed plastic tanks made by another manufacturer and the instructions said to alow for 10% expansion.
Does anyone know if the bulges come and go with the amount of gas in the tank?
Has anyone had to reposition the cleats more than once due to bulging?
Larry H
A C-Brat since Nov 1, 2003
Mighty Bite
Photos: Mighty Bite
PostPosted: Wed Mar 09, 2005 3:55 pm    Post subject: Reply with quote
My feeling is that there is going to be some bulging and expansion on the standard C-Dory tanks, whether they are the older 20 gal tanks or the new 25 gal tanks. Hopefully, it will be less with the new tanks. That doesn't bother me and I don't feel it is a big problem. A little space can be allowed to accomodate that.
I do feel that the system for cleating and holding the tanks in place is one that can and should be improved. It is simply to much to expect the factory cleat system to hold up over time without problems of the cleats and screw upsetting and allowing water entry to the balsa core. If the tanks are removed for cleaning, access to the area, or replacement the problem is exacerbated, as the fiberglass is not receptive to a lot of
"screwing around" (no pun intended).
The only anchor we have for those screws is the relatively thin skin of fiberglass that makes up the cockpit floor. I don't know if it would be possible to mold in a solid band of glass across the cockpit floor where the cleats are or not, but I look for some changes from C-Dory somewhere down the road as it seems like such an obvious need.
In the meantime has anyone used SS threaded inserts and bolts to anchor their cleats to the floor.
Levity
City/Region: Shippensburg
Vessel Name: Levity
Photos: Levity
PostPosted: Tue Mar 22, 2005 8:10 pm    Post subject: Reply with quote
Back to the original topic (bulging tanks) with a new question.
When resetting the StarBoard onto the cockpit floor why drill new holes? These holes create an opening for water to enter the C-Dory's balsa core; water is to balsa core what kryptonite is to Superman. I would like to bond the starboard to the cockpit floor instead of drilling and using screws. Adhesive Methods and Technology Inc. claims their 7540AB adhesive will make a powerful bond between StarBoard and fiberglass. Using the shim method described in this thread would allow for any future adjustments in spacing between the permanent StarBoard and the tanks. Making the Starboard permanently attached to the cockpit floor will not interfere with removal of the tanks if removal is needed in the future. This sounds like a good fix but before I go this route please give your thoughts on the merits or hazards of this concept.
Mike 'Levity'
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Tue Mar 22, 2005 8:48 pm    Post subject: Reply with quote
I seem to remember looking into that 7540AB "special adhesive" and the methodology included carefully flame treating the starboard. It didn't look that easy to get done right the first time, especially for an amateur.
Don
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Wed Mar 23, 2005 12:25 am    Post subject: Reply with quote
3rd Byte, You asked about threaded inserts. If you're not already done, here's what I've learned. West Marine has them, $5.00 each http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=3856 . Also Yardley(4 varieties) http://www.yardleyproducts.com/mold.htm . And Pennfast http://www.pennfast.com/fastening_products/prod_desc.php3?cat=SI+Inserts+for+Plastics . I'm planning on using 1/4"-20 on my 25 upgrade.
Pete
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Wed Mar 23, 2005 12:32 am    Post subject: Reply with quote
Levity,
I just finished installing my tanks today. I used the bolt epoxied in the floor method. I also considered trying to bond the starboard to the floor but decided to use a more simple method. I think if I had it to do over, I would simply epoxy a wood strip to the floor and paint it white. The more I live with starboard the less I like it. My previous boat (Arima) had the whole cabin built of starboard. Screws were always pulling out, the material is soft and fairly porous, and stains easily. Because of the light surface texture, fish blood and stains are very hard to clean off once they dry. Just my 2 cents.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
terraplane
City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Wed Mar 23, 2005 6:01 am    Post subject: fuel tanks Reply with quote
I'm sure i'm not the only one awaiting the arrival of a brand new 22 to wonder if I can expect my fuel tanks to be rattling around back there in a short time. With normal use, is it to be expected that one will have to correct this? When? Would appreciate input from Jeff at the factory and Les...and anyone else.
tom
Levity
Vessel Name: Levity
Photos: Levity
PostPosted: Wed Mar 23, 2005 4:09 pm    Post subject: Reply with quote
Don,
Thanks, the flame treatment does sounds like it will require practice to get right. Larry Doring from Adhesive Methods explained the process in detail which will help in attempting to get it right. There will be practice trials on some spare StarBoard before the application of the adhesive to the cockpit floor. Starboard isn't easy to clean but it is rot proof.
Where possible the starboard will have bolts and nuts for fasteners to avoid the tendency for screws to be pulled out. Thanks again for the tips.
Mike 'Levity'
dogon dory
Vessel Name: DogOnDory
PostPosted: Sat Apr 30, 2005 7:42 am    Post subject: Reply with quote
Page 3 of 4
Page generation time: 0.0428s (PHP: 67% - SQL: 33%) - SQL queries: 32 - GZIP disabled - Debug on
