fridge users please help
Pete in NY
City/Region: Western LI Sound, NY
State or Province: NY
Vessel Name: Miss Pam
Photos: Miss Pam
PostPosted: Fri Aug 12, 2005 9:51 am    Post subject: Reply with quote
I don't know if this is the best price, but fishing shops here on east coast sell these for use in coolers:
http://www.anglerdepot.com/htm/bait%20tray/carolina-bait-tray.asp
PostPosted: Fri Aug 12, 2005 10:15 am    Post subject: Reply with quote
Fast forward, now we have the Norcold on the CD25, and two AGM house batteries, plus a generator (maybe we should add solar panels too!). We still use a cooler with block ice for beverages, large items and whatever does not fit neatly in the fridge. The Target locker shelves do sound useful. It is amazing how a lot of stuff can be adapted for use on a C-Dory!
rogerbum wrote:
Pat - a few years back I found some shelves at Target that were designed for use in school lockers. They're made out of two plastic pieces that nest one within the other and are designed so that one can be pulled out and locked at many different lengths to allow one to adjust it to the width of the locker and jam in place (rubber feet on the end retain it). The pieces are about 1" thick honeycomb material - they made a great false bottom for a cooler. Look for them this year during the back to school sales...
Roger on the SeaDNA
Swee Pea
City/Region: Bath
Vessel Name: Swee Pea
Photos: Swee Pea
PostPosted: Mon Aug 22, 2005 8:06 am    Post subject: Reply with quote
Please don't shoot the messenger, but...I still have the factory ice box in place. I'm not excited about dropping $700 plus on a frig for my
CD22 (not that it wouldn't be a nice convenience, but I still want to keep things as simple as possible). And yes, I still have the manual windshield wipers.
Has anyone out there in CD Land had any success (or is it possible) to add insulation to the outside rear of the ice box to increase its cooling efficiency? Seems I read somewhere that either a Brat or a Dog did just that and had success. Add a block of ice and go. Naturally, the ice box would be used to store the food stuffs for long term coldness. Drinks and the "got to get tos" would be in the ice chest. The ice box would be only for long term stuff.
Just a thought. I have been counting my bucks and doing some thinking in regards to a fridge .. but $700 + bucks. I saw a Honda 2000 for $870 including shipping. Wouldn't that be a much better investment?
P.S. Any reasons for not using dry ice in the ice box? Any bio hazards? Does it melt like regular ice or vaporize gases that will stunt your growth, prematurely age you, or cause the big C?
Swee' Pea
PostPosted: Mon Aug 22, 2005 8:30 am    Post subject: Reply with quote
Swee' Pea
Dry ice (solid CO2 or carbon dioxide) is colder (-109F compared to 32F) so its best for frozen goods. It doesn't melt, it sublimes - e.g. turns from a solid to a gas directly. CO2 is generally harmless with the exception that "carbon dioxide is heavier than air and it can concentrate in low areas or in enclosed spaces (like a car or a room where dry ice is sublimating). Normal air is 78% Nitrogen, 21% Oxygen and only 0.035% Carbon Dioxide. If the concentration of carbon dioxide in the air rises above 5%, carbon dioxide can become toxic. Be sure to ventilate any area that contains dry ice, and do not transport it in a closed vehicle." quoted text from http://science.howstuffworks.com/question264.htm.
Hence those that use dry ice in their ice boxes should consider that the v-berth is below the levels of the windows and hatch and asphyxiation is a real danger if the boat is not well ventilated and the cooler is generating CO2 rapidly (like on a very hot day)- it might be wise to leave the cabin door open as that's below V-berth level.
The effect of high levels of CO2 in the air is symptoms that can include nausea, dizziness, mental depression, shaking, visual disturbances and vomiting. At extremely high levels, loss of consciousness may occur. In some cases, the affected individual may not realize what is happening to him/her prior to losing the capacity to correct the problem.
As far as the Norcold fridge goes .... I had one in my boat since day 1 and wouldn't do without it. I have 2 batteries and the fridge will run for several days without draining them. On my recent return from Neah Bay I realized that I must have "donated" my 30A to 15A 120V adapter to the dock out there and hence couldn't plug the boat back in at home until I bought another. Hence the fridge ran off of battery power from Wed afternoon (when I left Neah Bay) until Sun AM (when I dropped another $50 on the adapter). Average daily temps were about 75F with 50F evenings. Nothing else was drawing power during that time.
Roger on the SeaDNA
shikari
PostPosted: Mon Aug 22, 2005 7:12 pm    Post subject: Reply with quote
One hundred watt solar panel could keep a small fridge happy for quite some time ....and could assist motor recharging too.
Modern solar panels are very efficient and they can be set up on top of the wheel house and invisible.
I dry camp on land with one and usually the panel feeds my power requirements quite adequately.
They produce power even on cloudy days albeit at a reduced rate.
My IRA
City/Region: Springfield
C-Dory Year: 2013
Vessel Name: Aidiam
Photos: My IRA
PostPosted: Mon Aug 22, 2005 8:22 pm    Post subject: Reply with quote
The new generation Danfoss compressors require very little current draw. We opted for a Tundra unit which I installed this past winter $585 total cost including Refrigerator, cable, fuse block, switch, and vent covers (installation details are in our photo album under winter projects).
In 60-80 degree ambient air temps. the unit runs 5 min. and is off for 25 min., for a duty cycle of 10 min. per hour and a draw of about 2 amperes when running. We figure 48 hours minimum without charging while cruising in the Northwest (our batteries (2) are Optima Blue tops wired in parallel). Smile
Jerry and Helen
1984 Arima Explorer sold 1985
1985 Arima 17 SR sold 1992
1992 C-Dory 22 Cruiser sold 8/96
1992 OLympic 26XLF Sold 10/2000
1989 Arima 19 SR sold 2003
2004 C-Dory 25 sold 10/05
1992 Bounty 25 Offshore Pilot sold 6/2010
2006 Arima 17 SC sold 9/2012
2013 C-Dory 23 Venture
Big dave
City/Region: Vancouver
Vessel Name: Raven Dancer
Photos: Raven Dancer
PostPosted: Mon Aug 22, 2005 9:02 pm    Post subject: Reply with quote
I don't mean to be a wise guy, but my boat is still being made and my wife and I thought that the ice box was a "cool" idea for keeping things cool for 2~3 days by placing a block of ice in the top shelf, we will also have another cooler in the cockpit.
Is the major problem leakage, ice mealting in just a day or less, I guess I just don't expect to much out of it but I would like it to hold ice for at least two days, am I in lala land ? I still have time to cancell the ice box and get the storage shelf. Is anyone out there happy with the ice box. I live in the Pacific NW and we don't get a lot of hot days.
Thank you.......Big Dave
PostPosted: Mon Aug 22, 2005 9:17 pm    Post subject: Reply with quote
Sure, that's what they all say!
Welcome to the Pub, Big Dave! And congratulations on the soon to be boat.
A lot of people, including me, have removed the icebox from CD 22s. It is thin walled, flimsy, and does not hold ice very long. It does work as an icebox, though, and a lot more people have and use them. The only reason I initially jerked the one out of my boat was becase it was busted up around the mounting flange. My wife thought it worked fine. (She thinks the Norcold we now have in the CD 25 is much better, though.)
I am sure they have since fixed it, but in the older boats, the drain hose for the icebox was not routed out of the cabin until the owner did it. That is an easy fix, but a major whining point for a long time.
So, no, if you think the icebox might be adequate, do not delete it. If at some point you want to junk it, the box it is in is pretty square and easy to convert yourself.
In the mean time, just be as wise a guy as you want, because it sorta fits with the name of the group. Glad to have you here.
PostPosted: Mon Aug 22, 2005 9:19 pm    Post subject: Reply with quote
Wow!!! 2 amps for 1/6 of an hour = 1/3 amp-hour/hour!
Take a 115 amp hour rated group 27 battery with about 75 usable amp-hours of power available and you get (theoretically)
75 amp-hours/0.33 amp-hour/hour = 225 hours= 9.4 days!
Of course, the start up current is probably higher than 2 amps and we don't know where the low voltage cut-off point is, but with these numbers electrical consumption has ceased to be a problematic factor in adding refrigeration to your boat.
Now where to put the bugger and where to move the stuff to that it displaces?
As an aside, do any of you remember seeing photos of Zoe's Pride on the C-Dog's site with the full blown freezer setting in the cockpit with the generator and about 57 other essential pieces of gear on his Inside Passage trip to S. E. Alaska?
Joe.
El and Bill
City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
PostPosted: Tue Aug 23, 2005 10:57 am    Post subject: Reply with quote
Joe --
Yep, we sure do remember the load that Zoe's Pride was carrying to Alaska, and when we didn't hear anything from him for months after his scheduled return, we recall the concern (from us) and many others on the site. He had a great trip, we remember from his posts when they finally came. Anybody heard from or about him recently?
Sea Angel
Photos: Sea Angel
PostPosted: Wed Aug 24, 2005 10:31 pm    Post subject: Reply with quote
Hi All;
I am new at referencing site info; but, in my Sea Angel pixs, [pg18, group 2 of 3, last pix], is the Norcold with some of the factory info.
I have had made the mistake of leaving the house battery[type 27] on when I left the marina a few weeks ago and the 2 90s had to be kept above 1150 to recharge it enough to keep the voltage control relays from chattering and meet the added loads. The starter batteries were not on. That is the only time I have had the refrig load/kill the house battery. The 2 90s are 16amp each, more than enough to handle all the toys and the refrig at this time.
I will not be without a refrig any more. Hauling ice to the boat, along with all the family stuff has simplified life, to say nothing of having a nice cold drink under my butt. Laughing . I have thought abt the change out to a larger [3] batteries, but the alternators dictate these as optimum, from what I have read.
Go for the frig.. You won't be sorry. Not enough temporary cold storeage can be done with an ice chest on the back deck, or elsewhere, when the rare occasion arrises..
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
Swee Pea
City/Region: Bath
Photos: Swee Pea
PostPosted: Thu Aug 25, 2005 6:18 am    Post subject: Reply with quote
I'm still in the experimental stage. No real hurry to swap out the ice box for a refrig yet. I did pull out the ice box to see what this creature is made of. Plastic and styrofoam. (not really styrofoam, molded foam beads. Come to learn styrofoam is a Dow Corning registered name) Doing some research, contacted the box's manufacturer - seems the little bugger has an R rating of 3.
I also discovered that IF I wanted to insert a refrig, it may be a problem because the shore power breaker panel is located behind my legs at the helm seat. The wiring protrudes into the space just behind the ice box which isn't that deep. A retrofit refrig might not slide into the area due to wires and protruding breaker stuff. If I get serious about a refrig, I will persue some options.
What I did do as an experiment is add a heat reflecting surface around the ice box. There is a product called Reflectix that is sold at Home Depot and other places. It is like bubblewrap with foil on both sides. Its purpose is to relflect heat away (or cold back). The key to its efficiency is to create an air space (hence the air bubbles of the bubble wrap). Hey - keep awake out there!!!!
To offer some additional heat reflecting, I lined the hull wall and the floor under the ice box with the Reflectix. I created some more air space by attaching the Reflectix about an inch away from the hull and off the bottom. (You can do this by rolling some of the Reflectix, taping with aluminum tape, and creating "studs" taped to the hull and the floor). The ice box styrofoam was covered in Reflectix and all seams sealed with reflective aluminum tape, the kind heating and air mechanics use. I slid back the ice box and will test the bugger to see if this process did any good. Cost=$14.95. Had the tape. Time=1 1/2 hours. I will report on results. I contacted the company that manufactures Reflectix and they said at minimum I probably added R-4. I did notice that a Glacier Bay website did not think much of the usefulness of the Reflectix, but the manufacturer, emphatically disagrees. Reflectix is used by shippers that ship perishables across country and must keep contents refrigerated. So I gave it a shot. The least it can do is nothing, the best it can do is allow the box to hold ice better.
The ice box top shelf does have a drain out so melting ice is not a problem.
My wife says I have too much time on my hands. I also just finised sewing privacy curtains for Swee Pea. Will install snaps tomorrow. But that is for another post.
Hope I didn't bore you all too much. Safe boating. Love this site!!!!!!!
Swee Pea
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Thu Aug 25, 2005 5:58 pm    Post subject: Reply with quote
I ran across this site while following references to 9 day coolers. Not only are the coolers impressive, so are the "freezers." Especially interesting are the power requirements for the MT35F
9 day coolers
MT35F freezer/fridge
Tech data, MT35 power usage
Swee Pea
City/Region: Bath
Photos: Swee Pea
PostPosted: Sat Jul 22, 2006 8:57 pm    Post subject: Ice Box Experiment Reply with quote
It has taken me a while to get off my behind and conduct a test on the Ice Box installed in my 22' Cruiser.
As I noted in my last post on this subject, I insulated the exterior of the ice box with Reflectix and the entire interior hull wall and under the ice box as well.
I bought two 8" blocks of ice. At the "ice house", it was explained to me that these blocks were NOT old time blocks. They were crushed ice pressed into blocks and were not as good as real ice blocks. I proceeded anyway. Swee Pea was parked on the blacktoped driveway, full sun most of the day.
On Wed 7/19 at 2:30 PM, outside temperature was 92 degrees as well as inside the icebox. I used a photographic thermometer to check temps. One hour later, ice box temp was 51 degrees and outside temp had risen to 96. Average outdoor temps for the next 3 1/2 days was 92 degrees in the day and about 70 + degrees at night. Average ice box temp was 51 degrees. By 5AM Sat 22nd, ice box temp was 50 degrees. With two half blocks of ice remaining in the ice box, temps averaged 44 degrees. Lowest recorded temp was 42 degrees. Cabin temps comparable to outside temps, since the boat was stationary. No AC or fans.
I know there are a lot of variables. Ice boxes should remain cooler longer if the ice were solid blocks to start with. Ice box remained empty through the entire test. If the ice box is filled with pre-chilled/cold food, the ice box should be more efficient. I opened the ice box 12 times to check temps.
My personal conclusion/application is to use the ice box for food stuffs to remain cold for cooking. It will not be used as an ice chest for drinks - I will use a cooler for that.
Two "crushed ice" blocks lasted about 3 1/2 days. I will use solid blocks in the future - filled 2 liter bottles frozen. Hopefully, they will last longer. And when there is melt down, I will have some water at my disposal.
I'm not yet ready to throw away the factory ice box. By investing about $15 bucks and a little time, I have a useable ice box that will last a long weekend without new ice. Throw in an extra bag or two, and it is usable a little longer. Granted, it is not a refrigerator. But I didn't spend $600 bucks on a refrigerator and in addition, and have to buy a generator.
Just trying to keep things simple. It works for me. It may not be everyone's "cup of tea", but I'm satisfied.
P.S. Ice Box plumbing worked flawlessly and drained to the outside.
Swee Pea
ffheap
City/Region: Hingham
C-Dory Year: 1983
Vessel Name: Inn-The-Water
Photos: Inn-The-Water
PostPosted: Sat Jul 22, 2006 9:10 pm    Post subject: Reply with quote
Hi Folks,
My youngest daughter married in to a boating family, and one day I was getting a tour of my daughter's father-in-law's boat.
He installed a Solar Panel for the purpose of supplying energy to his Fridge. it gives enough power to maintain the ice cubes and keep the food cold when the engine is not running.
It is a direction we ought to be looking because we sure have a lot of space to put solar pannels on our cabin top.
Fred
Fred
Page 3 of 4
Page generation time: 0.0653s (PHP: 56% - SQL: 44%) - SQL queries: 32 - GZIP disabled - Debug on
