timflan
Photos: Two Lucky Fish
Posted: Fri Sep 21, 2007 1:45 pm Post subject: |
OK, here's the problem:
I've got an exhaust leak. About two grand worth of exhaust leak, as the midsection casting known as the "Engine Holder" needs to be replaced completely, along with a bunch of associated gaskets and little parts.
It's corroded clear through in one spot, allowing exhaust out, into the engine enclosure, thus starving the engine for oxygen. It also means there's an incredible mess of carbon and soot inside the engine enclosure, but that's just ugly; it doesn't prevent the engine from operating correctly.
Now about the warranty. Jacobsen's called, and I called: BRP says that, aside from the warranty having expired (about a month ago...doh!), it wouldn't be covered anyway. Why not? Because corrosion isn't covered; it's a maintenance issue. Oh, well OK then...  _________________ Timothy R. R. Flanagan |
tsturm
Joined: 01 Nov 2003 Posts: 1165 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Fri Sep 21, 2007 2:33 pm Post subject: |
timflan wrote: | OK, here's the problem:
Now about the warranty. Jacobsen's called, and I called: BRP says that, aside from the warranty having expired (about a month ago...doh!), it wouldn't be covered anyway. Why not? Because corrosion isn't covered; it's a maintenance issue. Oh, well OK then...  |
You should be able to find a used (fresh water) exhaust housing or complete motor cheaper than new parts! Good luck on your quest. Mite be time to look @ the F80-F115 Yamaha  |
timflan
Posted: Fri Sep 21, 2007 2:57 pm Post subject: |
On a three-year-old engine? I'm not sure how easy it might be to find the big casting on the used market. |
Posted: Fri Sep 21, 2007 3:01 pm Post subject: |
Those engine parts probably haven't been changed since they started building them, at least not until the new EFI ones came out. My lower unit was the same on my 45 from now back as far as '94 and earlier. Find one with a blown power head, that's a lot more common!
K4KBA |
timflan
Posted: Fri Sep 21, 2007 3:17 pm Post subject: |
This is the Suzuki-built EFI four-stroke Johnson sold for a very few years while the E-Tec was under development. There MIGHT be Suzuki parts available...I don't know how long Suzuki has been building these engines. |
DaveS
Vessel Name: Sea Shift
Photos: Sea Shift
Posted: Fri Sep 21, 2007 5:09 pm Post subject: |
The Suzuki and Johnson are the same with the exception with the exterior housings (ie: housing color and name). Suzuki will have what you need. _________________ Dave S.
"Sea Shift"
C-Brat #16 |
Island Ranger
Joined: 02 Jul 2004 Posts: 326 City/Region: Whidbey Island
C-Dory Model: R-25 Tug
Vessel Name: Island Ranger
Photos: Two Lucky Fish and Island Ranger
Posted: Fri Sep 21, 2007 7:44 pm Post subject: |
Sure doesn't sound right to me.
I find it hard to believe a three year old motor could have this kind of major failure and not be covered in warranty.
(Or would they say we have extremely corrosive water in Puget Sound - not what the engine was design to operate in?)
I'll cross off Suzuki/Johnson motors off my list.
Mac |
timflan
Posted: Fri Sep 21, 2007 8:51 pm Post subject: |
Island Ranger wrote: | I find it hard to believe a three year old motor could have this kind of major failure and not be covered in warranty. |
Me too! And the service manager at Jacobsen's Marine agrees. They called BRP, and I called after they did. BRP isn't being unpleasant about it, they're just sticking to a strict interpretation: it's corrosion, which is out of their control, and the warranty has expired anyway.
My fear is that if THIS casting has corrosion...are the other midsection castings (to say nothing of the powerhead or the lower unit) similarly corroded, and they just haven't failed yet? Wow...that would suck, wouldn't it? |
timflan
Posted: Fri Sep 21, 2007 9:00 pm Post subject: |
By the way, I'm starting to feel like a real "orphan" with regard to this engine. Suzuki-authorized service departments don't want to work on it because it's a Johnson. Johnson-authorized service departments are happy to work on it, and they can get all the parts, but they acknowledge right off the bat that they don't see many.
I guess (but have no firm evidence) that BRP cut this deal with Suzuki to sell rebranded Suzi outboards for a couple of years while their own plants were busy R&Ding and retooling in preparation for the big E-Tec push. They needed to feed SOMETHING into the retail channel in the meantime, so they worked the deal with Suzuki. |
timflan
