Posted: Tue May 22, 2007 3:17 pm Post subject: |
Bob, what's an "unsealed core"? Just no protection where fittings are mounted, or what?
K4KBA |
Joined: 02 Nov 2003 Posts: 21507 City/Region: Pensacola
Posted: Tue May 22, 2007 5:25 pm Post subject: |
Charlie, that is correct: any core material which is not sealed with epoxy. At times poyester is used--and is used on the transom of the C Dory 25 on the top and polyester with a layer of mat is used to seal the 3/4" pieces of plywood (2) which make up the 1 1/2" wooden core of the transom. Fiberglass with resin is often not stiff enough in a flat pannel, nor does it have the strength, so core is added to make it stronger, stiffer, or to fill a void (like engine stringers).
Epoxy has much better adhesive properties than polyester. Many of the early Taiwan boats were made with cabin sides and decks of layers of fiberglass over plywood--(vs the plywood molded into the glass). Many of these trawlers have gotten rot in the plywood core, because it was not sealed.
Another typical case is in production boat where the hull and engine stringers are wood encapsulated in polyester resin and glass cloth. Then limber holes (drain holes) are cut, but the wood is not sealed. Moisture gets into the wood (core) and then rot forms.
Balsa is semi sealed--it is actually a "hardwood" by definition. That is the cells are short, even though the wood its self is soft. As you may remember the Kon Tiki got lower and lower in the water, as the balsa logs adsorbed water. The end grain balsa theoretically should not absorb
water if each cell is sealed. Unfortuanately the polyester does not adhere well enough to the balsa, and water is adsorbed. I will be adding a piece on balsa in the transom thread as soon as I post the photos, and some new findings today--related to un-sealed core. _________________ Bob Austin
Posted: Tue May 22, 2007 7:49 pm Post subject: |
Thanks Bob. What type of the Nida-Core did you use? There are several kinds on their website. I've got a cabin top on a Columbia 26 sailboat to repair, where the mast step fitting leaked in the way of the bolts. It made the top so spongy that the guy that had it was afraid of it. It's not bad now that it's dried out but I'm going to cut the top skin off, pull out the core and replace it. There are two bulkheads under it and 4 vertical posts that'll give me lots of support. Was going to use Balsa but the Nida-Core looks better.
Charlie |
Posted: Tue May 22, 2007 8:19 pm Post subject: |
Under a mast step I would use solid marine plywood, epoxy saturated--you can use core material around the sides if you need--but under a direct compression post--there can be too much point compression for the Nida-core, or most foams. You would have to spread out the load some way, even with a high glass content, and a heel plate. I have seen a lot of deck fitted masts which broke down core material, including plywood (especially when it got wet) (there are some exotics which are light and will work--but not worth it for this application).
We used the 8HPP Nida-core. |
Adeline
Joined: 03 Nov 2003 Posts: 985 City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
Posted: Tue May 22, 2007 9:33 pm Post subject: |
Hi Charlie, When you get around to re-installing your mast step THIS may be helpful. _________________ Pete
Posted: Wed May 23, 2007 8:36 am Post subject: |
Thanks Pete, that looks nifty, I'll take a hard look at it. I like the idea of not having the bolts go all the way through the cabin top. Not quite sure how thick it is there yet, haven't cut into it. I have a 30x38 metal building to put together before I start this project!
Bob, the step isn't directly over the supports but rather in the middle of about a 2.5' X 2.5' square that has the support posts (really a part of the bulkheads of the cabin underneath) at the corners. I will probably put plywood in there though, that sounds like a smart idea!
Thanks for the info on the Nida-Core.
Charlie |
Posted: Wed May 23, 2007 9:12 pm Post subject: |
My recollection of the Columbia 26 is that there was a laminated beam between the two bulkheads--and the area above this was plywood core.
There were 2 x 2" pieces of mahagony grooved on one side for the bulkhead, and the beam was over this. (I am thinking of the Mark I--S & S designed. If you are thinking of the Mark II, Bill Trip designed, it was relitatively similar--but I think a more substantial lamination. |
stclairgal
Joined: 14 Feb 2013 Posts: 55 City/Region: St Clair Shores
Vessel Name: Dragonfly
Photos: Dragonfly
Posted: Sat Dec 02, 2017 12:42 pm Post subject: Rotted Core around deck plate |
Hi everyone,
thought I would re-activate this topic and warn everyone to check their cockpit deck plates. I knew ours were leaking when we opened the gas tank access port and found a pretty deep layer of scum. It caused our fuel level sensor to stop working. With the help of a generous fellow C-Brat we got the wires cleaned up and reconnected - problem solved! (Thanks again Tom!!)
I removed the deck plate this morning to reseal things and found the wood core all around the plate to be mush, in some spots almost two inches in. I am digging out the rotten core and will let things dry out over the winter. In the spring we will follow Bob Austin's great instructions for replacing the core and sealing the opening with epoxy.
If anyone has any additional tips let me know!
I'll post a couple of pics of my mess in the Dragonfly album.
This is a great forum. Proud to be a C-brat! _________________ Joyce and Wolfgang |
Posted: Sat Dec 02, 2017 6:34 pm Post subject: |
Thanks for the kind words, and reminders! I am going to check out that 2006 boat in Pensacola--and see if that is an issue there!
I had commented that I had assurances from the factory in 2007 that there would no longer be any leaks--that the 2007 boat would not have that problem....well--they do--and I suspect even newer ones also will. A lot depends on how the boat has been stored, and if there have been leaks, water intrusion and freeze thaw cycles.
Hopefully your core issues will only be a few inches, and you will not have to do the total rebuild. But it may be a good time to check out the fuel tank--and prevent any issues there also.
Regards, |
South of Heaven
Photos: Blue Water
Posted: Sat Dec 02, 2017 8:32 pm Post subject: |
Its so weird to see all the posters from this thread. Most of them are not active anymore.  _________________ <><><> Jason <><><>
1995 C Dory 16' Angler (40 hp Yamaha, sold 2/16) |
Posted: Sat Dec 02, 2017 8:40 pm Post subject: |
South of Heaven wrote: | Its so weird to see all the posters from this thread. Most of them are not active anymore. :( |
Really? I am still quite active. I hear from Capt Charlie periodically, Brent B is certainly active. I hear from most of the others every now and then...maybe not frequent posters, but certainly around. |
South of Heaven
Photos: Blue Water
Posted: Sat Dec 02, 2017 9:09 pm Post subject: |
thataway wrote: | South of Heaven wrote: | Its so weird to see all the posters from this thread. Most of them are not active anymore.  |
Yes, Brent and you are very active. It's just interesting for new Brats like myself to see these "foreign" names on the old threads! Lol. A different time I guess. Most online forums are very cyclical in nature. |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Sun Dec 03, 2017 12:40 pm Post subject: |
That's it! I'm posting just to post  |
South of Heaven
Photos: Blue Water
Posted: Sun Dec 03, 2017 1:53 pm Post subject: |
T.R. Bauer wrote: | That's it! I'm posting just to post  |
Good! |
Jack in Alaska
Joined: 17 Aug 2004 Posts: 1192 City/Region: Anchorage/Ninilchik
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
Posted: Mon Dec 04, 2017 1:33 pm Post subject: old timers |
What T. R. Bauer said.............. C-Dory owner since 1983
Jack (still in Alaska) _________________ On the HIGH TIDE-II, wife Carolyn and I.....Another summer fishing on the HIGH TIDE II in the Cook Inlet at Cape Ninilchik, Alaska.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Bare hull & trailer sold in Nov. |
