Chester
Photos: Chester
Posted: Sat Oct 09, 2010 9:22 pm Post subject: |
Fishhawk wrote: | O.K.,
There is one oz. per gallon of Berrymans in the gas (premium). Is there any chance that with a little time and daily running they will open up?
Dan |
There is a chance. The idle and low speed circuts on one of my motors were cured by Chevron Techron additive. I used Techron additive, not their dilluted fuel system cleaner with Techron. |
Yellowstone
Joined: 07 Feb 2006 Posts: 475 City/Region: White Sulphur Springs
State or Province: MT
C-Dory Model: 22 Classic
Vessel Name: Farwest II
Photos: Farwest III
Posted: Sun Oct 10, 2010 4:48 pm Post subject: |
Perhaps my comments may be irrelevant to most readers, but water introduced into the fuel may have little to do with whether tanks are stored full or empty during the off season. I have done it both ways and have found no water in my filter systems. My Honda 90 over five years showed no water in the fuel, boating on the pacific and in the gulf of Mexico, My current motor is a 2006 Mercury EFI 115 (actually a Yahama), and a small visible filter is near the squeeze bulb and another small filter sits inside the cowling in the line feeding the EFI system. Frequent checks show no signs of water after running over 500 gallons of gas through the motor. I would wager contaminated fuel from vendors rather than fuel tank "sweating"is the problem. John _________________ hopelessly addicted C-Dory user |
Matt Gurnsey Dealer
Joined: 11 Nov 2008 Posts: 1532 City/Region: Port Orchard
Photos: Kitsap Marina
Posted: Mon Oct 11, 2010 12:05 pm Post subject: |
Be very careful with the use of Heet and other fuel driers. They contain alcohol to absorb the water and help it mix with the gas. That's what makes them effective, alchohol's ability to attract water.
Of course, now that there is alchohol in the fuel, the fuel is absorbing more water until it is saturated, causing the alchohol/water mixture to seperate from the gasoline.
Iso Propyle based fuel driers may do a better job of kjeeping the fuel and water mixed.
Premium fuel is worse than regular fuel, in that it degrades more quickly than regular, as it is less stable to begin with. Save the money and just run regular, unless the engine manufacturer recomends it. _________________ Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991 |
drjohn71a
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
Posted: Mon Oct 11, 2010 1:01 pm Post subject: |
Matt,
Thanks for the info. Perhaps there are differing factors in differing locations.
My info is from ppl in the business for over 70 years around the Grand Lake, OK area. Of course there are differing opinions everywhere, but here seems to be the summary for much of the 1450 mile coastline of Grand Lake, Ok:
- Heet IS Isopropyl Alcohol
- 90 percent advise 91 octane fuel. In fact, it is difficult to find Regular gasoline at the local marinas, even if you wanted it.
- Many boats here operate all year 'round. Many are sitting in the water, unsued, over the winter.
- I have not seen any fuel dock on the lake providing fuel with alcohol in it.
I know my Honda owner's book recommends 87 octane, but it is rarely available down here.
There are many refineries in Oklahoma, so maybe that is why the fuel situation is as it is.
When I first used my boat on Grand Lake, during rough water spot in a storm, while going under a bridge, my Port engine lost fuel and I was able to navigate through the waves and bridge with the Starboard engine.
I found water in the fuel filters which apparently had become stirred up by the rough water.
Since using the Heet and still running all year, I have found no water in the fuel filters.
So, maybe it was bad fuel? Maybe condensation? Maybe the Heet helps?
I am sticking with my regimen since everything has remained clean since beginning it.
I can see how one might choose other options depending upon his/her unique situation.
John |
Matt Gurnsey Dealer
Posted: Mon Oct 11, 2010 1:17 pm Post subject: |
Heet has two formulas- the yellow bottle is Methonal, the red is Isopropyle. The red (Iso-Heet) is certainly much better than the yellow.
Regional differences also come into play as you mention, so while there are some basic guidelines, techs in a local area can give good insight as to what works best (although with ethanol, there may be different approaches to what to do, we all agree it's bad stuff). |
Yellowstone
Photos: Farwest III
Posted: Mon Oct 11, 2010 1:37 pm Post subject: |
Matt - I'm no chemist, believe me. But when water and propene are combined, the result is isopropyl alcohol, commonly called rubbing alcohol which comes in 70% and 99% varieties. So introducing ISO into a fuel tank is putting some water into it. I have no way of knowing the chemical reactions which take place with gasoline when isopropyl alcohol is introduced. My simple mind says avoid using anything with water in it in my fuel tanks. We must have a chemist in our group who can tell us the realty of using ISO. John |
BrentB
Joined: 15 Jul 2006 Posts: 4420 City/Region: Greenwood
State or Province: IN
Photos: BrentB
Posted: Mon Oct 11, 2010 2:40 pm Post subject: |
I am not a chemist but adding alcohol to gasoline does not remove the water but keeps both in a solution and from separation. _________________ Brent Barrett |
Matt Gurnsey Dealer
Posted: Mon Oct 11, 2010 5:07 pm Post subject: |
I'm not a chemist either, and while I did work in the automotive chemical field, it's been a few years, and the formulation for gasoline has changed a bit since then.
Brent's correct, the alchohol maintains the water in suspension, which Isopropyl Alchohol does better than Methyl Alchohol. Both of which are probably better at maintaining suspension than Ethyl Alchohol.
It's what happens when the alchohol reaches a saturation point with the water.
Keep in mind that the teatment for a 15 gallon fuel tank is one of the 12 oz bottles, or a 80 to 1 mixture. E10 gas is a 10 to 1 mixture.
It's been awhile since I've dealt with automotive chemicals, but I seem to recall that a 12 oz bottle of Isopropyl fuel drier will treat up to 8 or so ounces of water in the fuel. Even if we assume that it is one to one, that means that bottle of Iso-Heet (for example) is designed to handle 12 ounces of water (1 1/2 cups).
I don't know how much water it takes to overwhelm the Ethonal's ability to absorb water, but it seems to take very little water to cause phase seperation. And in the 15 gallon tank example above there are 96 ounces (1.5 gallons) of alchohol. It sure doesn't seem to take much to cause phase seperation.
I do know that if you put enough water into fuel to make Methyl Alchohol seperate from the fuel, that isopropyl alchohol could resuspend the water / methonal mixture back in the gas. But that was in limited quantities in test tube experiments. Does Isopropyl help keep ethonal in suspension? I don't know.
I wish we could still get E0 gas here in our area. Rumor is that Poulsbo and Brownsville have E0 gas, but that could have changed. |
Posted: Mon Oct 11, 2010 5:36 pm Post subject: |
Guess we're just lucky here. We can get E0 at several local gas stations (at least 3 I know of) and several local marinas (at least 2). Lots of trailerable boats here and most folks I know go out of their way to buy the E0 stuff. That's not to say you can't get a shot of water from anyone, that's the only problem I think I've had in the past, bad gas, not the methanol phase separation problem...
I still treat with Blue Stabil and Startron every time I buy gas...
K4KBA |
Hunkydory
Joined: 28 Mar 2005 Posts: 2733 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Mon Oct 11, 2010 6:39 pm Post subject: |
Charlie, Yes you are lucky for now, but don't think that luck is going to hold.
Just last summer there was plenty of places to go for EO though I generally chose Chevron due to personal preference. Now I can't find a single one around here or on my way back from Lake Powell, so this is the first year its going into storage full of E10 and blue stabil.
Have never had problems in the past. Motors always have started instantly following reconnecting and pressurizing motor fuel inlet. Always stored full with red stabil, disconnected fuel inlet, ran motors till they quit and then drained each carb.
During the boating season this year added blue stabil at every fueling and twice added the recommended amount of Techron to fuel.
Hard to fathom the thinking that has got us into this mess. E10 and now maybe E15, government forced and subsidized additives that we must add even more very expensive additives to prevent them from doing damage to the motors. Would make my day to stuff just one of the individuals responsible for this continuing mess into the Mokai and make just one more rounding of Cape Ommaney with them in tow.
Posted: Mon Oct 11, 2010 6:45 pm Post subject: |
Hunkydory wrote: |
Jay |
I feel your pain Jay. Next thing you know, they'll make us all buy health insurance!
I know, I know....don't go there!!
Charlie |
