Permatrims: My 2 cents
Goto page Previous  1, 2, 3
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Fri Jul 29, 2022 12:52 pm    Post subject: Reply with quote
I have successfully TIG welded on many cast aluminum pieces. This is a permanent solution and would a very easy job for a skilled welder. After touch up painting, you won't even know the holes were there.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Thu Nov 16, 2023 2:32 pm    Post subject: Reply with quote
Hunkydory wrote:
The Permatrims on my twin Honda 60’s are much larger than the ones on my replaced Honda 40’s. My now Permatrims would fit all Honda’s between 60 hp & 150 hp, yet I still have & use the Bennett trim tabs too. I run heavy & with the extra hp of the twin 60’s, find the combination of the larger permitrims & trim tabs very useful in varying boat weight & sea conditions.
I needed to correct this, as I was recently checking the USA Permatrim website, I noticed instead of mine fitting between Honda 60hp & 150 hp it’s actually 60hp to 130hp, though they are still much larger than the ones that fit the Honda 40hp. And these, H9 SILVER PERMATRIM FOR HONDA MOTORS fit 135-225HP AND 2010 & UP 115HP.
Page 3 of 3
Page generation time: 0.0261s (PHP: 54% - SQL: 46%) - SQL queries: 15 - GZIP disabled - Debug on
