Heads up - LiFePO4 and ABYC recommendations
Goto page Previous  1, 2, 3
PostPosted: Mon Oct 18, 2021 6:43 pm    Post subject: Reply with quote
croakz wrote:
Just remember those Chinns, Ampere, and Zooms don't have low temp charging protection. So a good deal, for the right use cases.
Amazon does have a low temp Chin's battery for $659.99Here on Amazon. You are paying considerably more for the low temp (probably a heater circuit). But it is available.
I would think that most of the use in a C Dory would be in temperature greater than 32*F. (Think of putting the battery inside the cabin.) Thus probably not really an issue for most of our boaters.
robhwa
City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
PostPosted: Mon Oct 18, 2021 7:16 pm    Post subject: Reply with quote
My Li battery BMSs will have low temperature charging PROTECTION, as in they won't charge below 32F (battery temperature). Don't you mean these don't have a heating circuit that will heat the battery internally when temps drop low enough that the BMS stops the battery charging? Interesting, the battery can still discharge just fine below freezing. It is the charging that the BMS stops. Given in a C-Dory that the battery case will usually be sitting on a sole that is hopefully sitting in liquid water, dropping below freezing hasn't ever happened in my C-Dory 22 (batteries below sink), even when outside temps drop below freezing. In my camper and in our mountain yurt, the BMS does shut down charging when it gets really, really cold. It'd be nice to have a battery that has an internal heater in that case, which are available but more expensive than what I have now.
PostPosted: Mon Oct 18, 2021 9:22 pm    Post subject: Reply with quote
Well, I'll keep going.
First of all, Chin li batteries are only rated for 100 amps and Honda Accord starters (as far as I know) use at least 150 amps. So one needs to have a lead acid battery for starting. That's one reason for a lead acid battery.
Next, Journey On has a 150 hp Honda engine with 40 amps of output, max. But a li 100 ah battery will take up to 100 amps in charging. This means that the Honda alternator will be putting all it's output into charging the li battery with nothing left over for the house loads, such as the MFD, fan, wipers, etc. Therefore one has to limit the charge current for the li battery. I selected a Regony 20 amp charger, assuming 20 amps would charge the lead acid battery and run the house loads. Regony was the cheapest, without bluetooth. Turns out I installed a Balmar SG2000 monitor which has the option for bluetooth, so if I want I can get a remote reading for the battery state. In a C-Dory, I don't think I'll need anything remote.
Now the battery charger has a li setting, which charges until a fixed voltage is reached (~14.6 Vdc). The battery charger then disconnects, which is kinda a shock on the alternator Indeed, if there are no house loads, it'll blow the alternator. Fortuitously, if the lead acid battery is connected it'll take the surge and everything will continue to operate happily. That's another reason for a lead acid battery.
Now, how does one control to DC-DC charger? Two ways. One there is a line coming out of the charger which has to be connected to a 12 Vdc source in order that the charger will operate. This prevents the starting battery from being drained in order to charge the li battery. One can connect it to the alternator output or as I have, through a switch on the dash. All I have to do is remember to throw that switch and I'm betting Judy will remind me. In addition there's a line coming out of the charger that, when activated, limits the charger to operate at 1/2 the normal charge. Again that's a switch in the dash, used if the alternator is struggling to deliver adequate voltage.
And i live in San Diego County where it never freezes so low temperature charging doesn't concern me..
Wish me luck.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Oct 19, 2021 9:40 am    Post subject: Reply with quote
My poor little honda rectifiers only make 10 amps.....they are almost always giving all they got. They must be designed to do that?
PostPosted: Tue Oct 19, 2021 1:16 pm    Post subject: Reply with quote
I assume that what you're saying is that the alternator on the motor is rated for 10 amps @ 12 volts. If the load is more than 10 amps, the voltage will drop. Until you remove the load. Is that what you are saying?
In my example above, if the alternator is feeding loads that require more than 40 amps, the voltage will drop and cause the starting battery to supply the extra current. And run down.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Tue Oct 19, 2021 5:58 pm    Post subject: Reply with quote
Will Prowse just did a teardown of a new "marine grade" LiFePO, although a manufacturer calling a battery marine doesn't necessarily mean it meets one's needs. But at 206 amp hours and $1K each, thats getting really competitive with Flooded Lead Acid (and Mr. Prowse seems to think they are better than Battle Born).
I can't see the application on my little C-Dory, but I'm almost hoping the batteries will fail on my trawler. Very Happy
https://www.youtube.com/watch?v=zJmIS5tmzPU
croakz
C-Dory Year: 1997
Vessel Name: Jolly Blue
Photos: Jolly Blue
PostPosted: Tue Oct 19, 2021 6:14 pm    Post subject: Reply with quote
I love the size of the SOK Marine battery too. 13.4" long, where my Expert Power 200ah is 20.6" long! And the SOK is not even 1" taller or wider.
T.R. Bauer
PostPosted: Tue Oct 19, 2021 8:53 pm    Post subject: Reply with quote
Yup. It's almost always giving it all it has.
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Thu Aug 11, 2022 10:43 am    Post subject: Reply with quote
ABYC has finalized new recommendations for Li batteries. Here’s an article that discusses them. I don’t see any mention of a requirement that the BMS be external. I suspect manufacturers (including Victron) will be making some product changes before July of 2023, when the new recommendations become effective. The comments are worth reading as well.
https://panbo.com/abyc-ratifies-e-13-their-first-lithium-battery-standard/
Paul
PostPosted: Thu Aug 11, 2022 12:10 pm    Post subject: Reply with quote
Paul, Thanks for posting about the ABYC "standards". It is also a reminder to me that I got away from reading Panbo after Bell Ellison bowed out to Ben Stein. I will get back to regular reading. Also the reference to Peter Swanson’s “Loose Cannon” website and the standards is important.
Nothing earth shattering about the standards--in fact I am a bit surprised that they are not more stringent. It also seems to emphasize the use of the higher quality batteries to meet the ABYC standards.
The requirement of dual systems, is important. It may just be a starting battery, but needs to be independent--and something which is easily available to take over if BMS cuts off the Li system.
Ventilation is important, as is appropriate fusing.
Page 3 of 3
Page generation time: 0.1634s (PHP: 19% - SQL: 81%) - SQL queries: 27 - GZIP disabled - Debug on
