Posted: Thu Jan 23, 2025 10:14 pm Post subject: |
The latter post I made referred to turblance in the lock as water was let in or out of the lock. Some are mild, but we have been in many where there was significant turbulance. The boat involved with the lock wall was right in back of us--next time we meet I'll show you the video.
The concern is the forward line, which goes from the lock wall to the far side of your boat over the cabin top, would rub on the edge of the cabin, and cause damage to the gel coat. How did you lead this line back to the cockpit so you could keep tension on it, either up or down? Something has turn that line back to the cockpit--and thus a snatch block. Do you put the line under the forward horn of the cleat and lead it back?
The bollards are always much easier than the locks which have lines. The majority of American Locks we have been thru had lines permently on the wall of the lock. Many other world locks have you throw the lines to one of lock attendants, who secure them to the lock wall at the top, and then you let your lines in or out. Our large boat we had 4 100 foot lines, one foreward and one aft on each side of the boat, for center lock position. Then those on the boat tend each of these lines; _________________ Bob Austin
Posted: Thu Jan 23, 2025 11:06 pm Post subject: |
Quote: | The latter post I made referred to turblance in the lock as water was let in or out of the lock. Some are mild, but we have been in many where there was significant turbulance. The boat involved with the lock wall was right in back of us--next time we meet I'll show you the video.
Good evening Bob,
I don't know if I ever saw video, but I did see the photos he posted. You are not the only one I've heard report significant turbulence. I've just never felt anything in the locks (other than the one Erie lock) that I would consider significant. Perhaps like wave and chop, it's all relative. Yet I know you've had a helluva lot more boat experience than I have. Either I'm just lucky in the locks, or I've figured out a better way to keep my boat in position.
I understand your question now in regards to line positioning. To be honest, I've sat here trying to remember just how I've handled the lines when solo. I know I've gone to the other side of the boat with a line, and perhaps that's been with single line. I can visualize having to watch my line coming between the bimini and roof. (My bimini has a window curtain between, that I can take out. Or I had the bimini folded back.) And it's possible that with two lines, I had the forward line come across the roof. Most likely, during that time I was in the bottom half of the lockage, so with the angle from above, there was little rubbing on the roof. I guess I'll have to pay attention next time I'm in a lock with lines to see exactly what I do. It's all kind of second nature now and I don't even think about it. Also, most my lockings have been with the bollards. I believe most the Mississippi Locks used lines, and it's been a few years since I've been on the Mississippi. The Erie Canal had lines, and I barely remember holding both lines while sitting on the gunnel on the lock wall side of the boat. (Or it's possible I only used one line). I also remember once or twice leaving the kicker run and using it to help keep the boat parallel to the lock wall. (From the cockpit helm). Whatever I did, it seemed to work, as other than the Erie, I can't remember ever having much of a problem. But no, I never used a tackle block or anything to "pulley" the lines. I'm beginning to think in locks using lines hanging down from above, I rarely used two lines, and rather just used one...but held the line from the center of the boat, just behind the cabin bulkhead. |
Joined: 27 Oct 2012 Posts: 3580 City/Region: SW Michigan
Posted: Fri Jan 24, 2025 11:27 am Post subject: |
On the Erie Canal on my 22, it is not usually possible to grab two lines (the boat is too short). Using one line is not a problem, but you might have some issues with the boat twisting. This is not usually a problem unless the lock wall has some chunks out of it than could potentially catch the boat if it twists into the gap. It is just a question of managing the twist.
As mentioned, being able to hang on to the ladder at the front and the back of the lock is easier when single handling a smaller boat. |
gulfcoast john
Joined: 14 Dec 2012 Posts: 1044 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Fri Jan 24, 2025 4:51 pm Post subject: |
Hi friends,
Yesterday we breezed through the Franklin lock on our OWW cruise, our 226th lock in this boat. Like 99% it was ‘Cat O’ Mine secure, lifejackets on, engines and radar off, standing by on 13 for exiting permission.’ We learned from our Infamous Joe Wheeler Locking Incident of 2018 (among others) and installed ‘locking cleats’ just aft of the cabin so Eileen never leaves the cockpit and I grab a rope from the helm window. I always choose a starboard tie, regardless of wind or current, so I can reach the engine controls without ‘running out of rope’ to hang onto, for just the kind of situation Colby describes.
We had an eerily similar episode in the St Lucie lock. We already had permission to enter as soon as the green light came on. A 45 foot power cat pulled up behind us and was also told ‘lifejackets required, select and hold a bow and stern line.’ We pulled forward as far as practical on the stbd wall so the fat cat wouldn’t have to be beside us (we were first, so we got to choose). We knew it was a 13 foot lift and that there would be turbulence when the gate was opened 6 inches, but we didn’t want to be beside the fat cat with limited options. The fat cat entered and cleated off a bow and midboat rope with their stern up against the rear gate and meandered about their boat without PFD’s on. Eileen called out several times to them, ‘Don’t you want to move forward a little bit so the gates can close?’ but they didn’t seem to know what a gate is or that their boat was on one. Eventually the lockmaster radioed them in very terse and explicit terms to move forward. So they moved fully beside us. The torrential surge when the forward gate was cracked was worse than expected. Eileen had no problem with a single turn under the lower end of her vertical 8” cleat, but the boat veered into the current and I simply couldn’t hold onto the 1” thick rope without it slipping through both hands despite dimpled roughneck gloves. I got a 2 inch gash on my arm from the pressure on the window frame despite both feet against the boat. The bow kept closing with the fat cat so I let go with one hand to push the Start button on the port engine, turned the wheel toward the wall and throttled up to 1000 RPM. Unlike the 2018 Incident, the engine never hit the wall because we now use bigger fenders and place them closer to the engine bracket. Eventually we settled close to the wall with engine and steering power. At times the current seemed over 5-6 MPH, and this boat doesn’t like to get sideways to that. The fat cat was cleated off and didn’t seem to have any issues.
I’m 70, 145 pounds who does 110 pound arm pulls on the gym machine 3 times a week. I think it was ver 150-200 pounds of force on that rope before I started the engine. The fat cat didn’t seem prone to wander in the current, thank goodness, or it could have crushed us. Or maybe having cleats at both ends kept it in control. Now I’m determined to place a locking cleat by the helm window sosmehow. I don’t know if a snatch block could hold a rope over an inch thick but perhaps an option.
Eileen is a retired Surgery and Wound RN. After we got safely out of the lock, she glanced at my cut arm and said:
“How the HELL are we going to get all that blood off the mouse fur? Do you think the Folex carpet stain remover will do it?”
I said: “Yes, Dear”. If you’ve been happily married for over 40 years, then you know that is always the correct response, even when it isn’t your initial thought. The Folex worked.
Now we like Polyform F3 fenders, which were on clearance at West Marine for $17 each with free shipping, so I bought eight hoping it is a lifetime supply.
https://www.westmarine.com/polyform-f-3-series-fender-for-boats-20--30--8.2inch-x-30inch-white-20288072.html?utm_medium=cpc&utm_source=bing&utm_campaign=%5BADL%5D%5BPLA%5D%20Anchor%20%26%20Docking&utm_campaignid=458271174&utm_adgroup=Boat%20Docking&msclkid=4571c3ef4c57182ae590a47b4fd61f7e&utm_term=4577473073282190&utm_content=Boat%20Docking
The F3 fender cover is $43 each. We never had good results with the garbage bag trick or cutting the legs off old Goodwill jeans etc etc and now just replace them every 50 locks or 5 years. A Mister Eraser will sometimes work.
Bob, if you send me that video clip I’ll post it to our OWW blog (up to 120 seconds allowed) for others to learn from. Too bad I didn’t think about turning on the port engine at the Joe Wheeler Incident.
https://findpenguins.com/ancient-isles/trip/okeechobee-pink-shell-hontoon
For solo locking at ‘dangling rope’ locks, I’d consider bigger fenders as far forward and aft as possible and be prepared to start the outer engine. IIRC many of the Canadian locks require a crew of two.
Cheers!
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150 |
Posted: Fri Jan 24, 2025 10:51 pm Post subject: |
John I have had snatch blocks up to 2"--but normally 1" wide sheve wil do. BIGGER BOATS, BIGGER SNATCH BLOCKS. |
