No house electronics--weird problem
Goto page Previous  1, 2, 3
PostPosted: Mon Jul 10, 2017 1:09 pm    Post subject: Reply with quote
Pretty good chance you can just top the fluid off at the helm pump. I do this as inspection at least once a month. Mine had been leaking at the helm pump for some time. The seal kit is not that expensive, and resolves any leaking there. Back aft, isa bit more to replace the seals, but a DIY project. Fine grit/sand and dog hair can slowly damage the seals. Inspection of the rod, at each outing is a good idea--both to wipe clean, and look for any leak. Takes a second--make it part of checking the oil in the engines routine.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Tue Jul 11, 2017 3:10 pm    Post subject: Reply with quote
bmacpiper wrote:
smckean (Tosca) wrote:
bmacpiper,
All lugs and cables are clean and installed with dielectric grease.
Was the grease put on before the connections were established, or after?
Both! Smile
Obviously dielectric grease was NOT your problem, nor do I think that grease would ever cause such problems, but I've often wondered how exactly to use this grease.
Dielectric grease is JUST that: a dielectric....which means it does not conduct electricity, but is instead, it is an insulator. So it has puzzled me why I would put it on before I made a connection. I've done some research on this, and sure enough the "experts" seem to say to put it on after the connection has been made (which makes sense). The dielectric grease is there to stop any spurious or accidental electric flows and to protect against corrosion.
Even though dielectric grease could increase the resistance of a connection, I've read that the pressure of the nut on the post and connectors squeezes out the grease between the metal connectors, and does not harm the conductivity of the connection, but I have no proof of that.
I try to put on the grease after I make the tight connection since I want the best connection possible, but it sure is easier to put the grease on first. I continue to wonder if it matters???????
Page 3 of 3
Page generation time: 0.0254s (PHP: 61% - SQL: 39%) - SQL queries: 19 - GZIP disabled - Debug on
