PROJECT-A-PALOOZA!! - V-Berth Access and Mods
Goto page Previous  1, 2, 3
PostPosted: Wed Jun 26, 2019 4:11 pm    Post subject: Reply with quote
Pat Anderson wrote:
The only thing I don't know is whether the 2005 CD25 has foam down there or air...hoping for air but betting on foam.
Pat, our 2007 had no foam.
Pat Anderson wrote:
I love the plywood covers instead of Bomar hatches (which I was planning on). Your plywood covers will be flat, not like "The Princess and the Pea" that we would get with Bomar hatches!
We have hatches. With the factory foam and a 3” memory foam topper, you cannot feel the hatches at all.
PostPosted: Wed Jun 26, 2019 4:23 pm    Post subject: Reply with quote
My 08 had factory hatches and no foam. They are low profile hatches. I replaced them with larger ones, the factory hatches are way too small compared to the size of the compartment. We sleep on the factory berth cushion and a sleeping bag. Never felt the hatches.
If you put too much padding in the berth you are going to reduce the already limited headroom.
PostPosted: Thu Jun 27, 2019 12:01 am    Post subject: Reply with quote
We have 3" memory foam over the factory cushions on our 25--and it makes for a great nights sleep. We had 2" memory foam on our 22. We read lying down, with head proped up, for us larger folks, there is just not enough "head room" to really sit uo anyway.
Doug & Fran
City/Region: Calgary,
State or Province: AB
Vessel Name: Squirt Two
PostPosted: Wed Jul 26, 2023 5:59 pm    Post subject: Reply with quote
We have a 2007 25', which has been stored for the last 2 years or so on its trailer.
I just crawled into the v-berth and pulled out the cushions. We have a 5" (?) round inspection access towards the bow - I pulled it and there are several inches of water inside. (no foam).
We also have damage to the fibreglas in the ?? funny-little-space-at-cabin-end-of-vberth-where-put-our-shoes-etc.-when-sleeping ??.
I think it's because water was high enough in the space under the v-berth that when it froze during the last couple of winters, it expanded and pushed the 'floor' of the 'funny-little-space' upwards, causing some cracking.
I've sent a note to C-Dory regards installing the additional storage access hatches, and am planning on putting in the same round inspection access as shown in the first item of this thread. And having a fibreglas knowledgeable buddy come over and advise as to the damage.
If you live in similar refreshingly cool climes, considering adding that inspection access.
Doug & Fran
Squirt Two
PostPosted: Wed Jul 26, 2023 7:12 pm    Post subject: Reply with quote
Doug and Fran, do you have the fiberglass interior or wooden interior? My last C Dory was "Seaweed" as mentioned in the first post of this thread. I had the impression that there may have been foam in the area under the bunk at one time. However I am not certain.
I suspect it was the first or one of the first several boats with fiberglass "furniture". I think I documented that the boat finished prior to that boat had the wooden interior. However the boats were not always "finished" in the numerical order that they were tagged with. (Some dealers ordered several boats, so the numbers got out of order.). This was the end of the time when the C Dory factory was prolific, selling many boats a year.
Where did the water you found there come from? Brass strip, anchor locker not properly drained, or running forward and some how getting under the tabbing for the forward V berth platform.
In any case, that bow storage is great. We put a spare anchor, anchor rode forward. Two 100 amp hour liFePO4 batteries, and a Victron Multiplus 2000/80/50 inverter charger in the closer areas on each side.
I would be concerned with freeze thaw cycles that there could be some delimitation and water intrusion into the core, if there was water, unsealed core (such as screws to hold cabinets--thus the question about wood vs fiberglass interior). If you can check the tabbing and see if it is holding water back on each side of the fuel tank (access thru the steps on each side of the cockpit.). Also check the core where water pump, bilge pump and hydraulic pump and reservoir for the trim tabs are screwed into the bottom of the boat. There may also be cleats for holding the water tank in place.
Page 3 of 3
Page generation time: 0.0813s (PHP: 51% - SQL: 49%) - SQL queries: 18 - GZIP disabled - Debug on
