KEEP BUMPING HEAD
Goto page Previous  1, 2, 3
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Jul 12, 2014 11:13 am    Post subject: Reply with quote
Get shorter friends
Joel
SEA3PO
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sat Jul 12, 2014 12:09 pm    Post subject: Reply with quote
ghone wrote:
This is how we do it. Caps off before entering cabin. George
Or. we could keep the cap on and glue (4200 or 5200?) pipe insulation to the cap with, of course, a stenciled C-Brat logo on it.
MartyP
hambone
PostPosted: Sat Jul 12, 2014 2:51 pm    Post subject: Reply with quote
AstoriaDave wrote:
hambone wrote:
So many ideas I don't know where to start. I really like the last one about buying me a beer.
Gonna look at getting some flat foam pad I believe. Glue it on with some 4200. That way there is less to hang on to and yank off. Gonna be first on my winter list of MUST DOS. THANKS EVERYONE for the great ideas.
One more idea. Get some red can Weldwood contact cement and use that to adhere the foam. Don't use a water based contact cement. They do not work well on foam. Roughen both surfaces with 80 grit sandpaper before gluing. 4200 will slide around before curing. The contact cement is good to go within minutes, full strength in 24 hours. And, if you want to remove the foam, the glue will come off with some elbow grease and lacquer thinner. Removing cured 4200? Ugh!
I've never tried the WELDWOOD. I will give it a look see. You are right with 4200. Great big UGH getting it off. Thanks.
Hawg Hunter Productions.
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Sat Jul 12, 2014 3:21 pm    Post subject: Reply with quote
And why is it if you wear a billed hat that you always hit right on that little button on the cap ,driving it into your head . That really hurts.
Richard
PostPosted: Sat Jul 12, 2014 3:50 pm    Post subject: Reply with quote
Shorter friends? Wink
hambone
PostPosted: Sat Jul 12, 2014 6:57 pm    Post subject: Reply with quote
Most of my friends seem to be over six feet tall. I'm five foot ten and fishing the Pacific Ocean out of Brookings Oregon the sea gets a bit testy most of the time and when the bite is on you seem to forget to duck going in the cab. Or at least I do. Confused
I found a piece of pipe foam in the garage and gave the old WELDWOOD contact a go. By George I think it's the answer. My thanks to Astoria Dave for the suggestion. Pretty clean application and really holds on. I cut a two inch piece of pipe foam in half which gave me a flat surface to work with. Glued it to a piece of wood. That baby is flat on there let me tell you. OK, that's enough R&D for this old boy. Next trip back to Brookings I will add the foam to SEA WOLF.
At least now I'm not going to have to look for shorter friends. Again thanks Dave for the suggestion.
hambone
PostPosted: Tue Jul 29, 2014 12:13 pm    Post subject: Reply with quote
WELL IT'S DONE. I really liked the idea of using weldwood cement on pipe insulation and it came out just AWESOME. I sanded down the area to give the glue a good surface to adhere to. Applied glue to both insulation and door frame. Let me tell you they are there for the long haul now.
PostPosted: Tue Jul 29, 2014 12:26 pm    Post subject: Reply with quote
So I guess my suggestion of the board with the nails was completely rejected. Laughing
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Jul 29, 2014 1:20 pm    Post subject: Reply with quote
Richard
That would be Parsons' Postulate to Murphy's Law...
And it is, "Murphy is an optomist."
I've only hit my gourd once this morning. Right on the cap button.
hambone
PostPosted: Tue Jul 29, 2014 1:47 pm    Post subject: Reply with quote
Sorry Roger, a good idea but one that would invoke violence from time to time. Crook
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Tue Jul 29, 2014 4:54 pm    Post subject: Reply with quote
Nice neat job on the installation, well done.
I'm a tad confused. The protection looks good as you exit the cabin, but as you enter the cabin it looks like you can still scalp yourself? Or am I missing something? Confused
Martin.
hambone
PostPosted: Wed Jul 30, 2014 6:48 pm    Post subject: Reply with quote
Yep, it will still get you if your not careful. No way to cover that part of the door as it would impede the door closing. Good eye. Wink
At least my tall friends should be able to get in and out of the cab without to many headaches. I'm hoping anyway. Crook
Page 3 of 3
Page generation time: 0.0419s (PHP: 65% - SQL: 35%) - SQL queries: 25 - GZIP disabled - Debug on
