Kicker?
Goto page Previous  1, 2, 3
C-Puffin
City/Region: Issaquah
Vessel Name: C-Puffin
Photos: C-Puffin
PostPosted: Sat Apr 23, 2005 12:39 am    Post subject: Reply with quote
Just a quick note to clarify your choices. With the size trim tabs that your boat is going to have you will have to use a bracket. Your choices are a fixed bracket which you will have to use a extra long 25" shaft or an up and down bracket with at least 10" of movement which you would use a long 20" shaft. Garelick makes an excellent up and down bracket that has been used on a number of boats. Your choice for horsepower would be either a 9.9 or 15 depending on which bracket you use since not all engines are available in the 25" shaft size.
PostPosted: Sat Apr 23, 2005 10:44 am    Post subject: Reply with quote
Thanks, Scott - will probably get the Garelick bracket then, have Les mount it, and go with the Tohatsu 15 hp four stroke with 20" shaft...
Sawdust
City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
PostPosted: Sat Apr 23, 2005 11:11 am    Post subject: Reply with quote
Before you decide, Pat, look at the fixed bracket on Lyle's 25.
Duster
1984 22 Classic
Page 3 of 3
Page generation time: 0.0346s (PHP: 56% - SQL: 44%) - SQL queries: 20 - GZIP disabled - Debug on
