best fuel economy
Goto page Previous  1, 2, 3
Saxe Point
City/Region: Sooke
PostPosted: Mon Apr 23, 2018 12:08 am    Post subject: Reply with quote
http://www.interactio.co/?gclid=EAIaIQobChMIiZHZq8DP2gIVE6vsCh1kGgg4EAAYBCAAEgKQ1vD_BwE
This is made and sold in Victoria, BC, just a short drive from my place. And cheaper for American buyers!
Does anyone have any experience with one?
Looks impressive in terms of the information it offers and the ease of installation.
PostPosted: Mon Apr 23, 2018 11:41 am    Post subject: Reply with quote
That looks like a great app--the fuel flow meter is about $300 US (shipping?). It can be done for less, if you have a system, such as Lowrance or Garmin which has the Transducers, which typically go for $150 to $200, but if you don't have the NMEA 2000 backbone, then it would bring it up to the $300 level. Nice to not have to run wires, and for older boats without a modern MFD which will show fuel flow and calculate the MPG etc. If I had a boat without a fuel flow system, I would certainly consider this one. Thanks.
Colby, I don't know what year Mercury integrated smart craft into the outboards. Suzuki did by 2007. But a Mercury manual from 2001 addresses the fuel use from the engine computer via Smart Craft Gauges--so your motor should just require the proper cable and adaptor from the computer and integration into the Garmin. Or for about $200 you can get the cable and a dash gauge which will show the information directly--for a little more you can get an android app. with wireless transmission..
PostPosted: Mon Apr 23, 2018 12:58 pm    Post subject: Reply with quote
And that is where I got hung up on stuff. Trying to find that adaptor. Wasn't getting much information from the shops I was talking to back when... Perhaps I just need to get a hold of Merc and find out what's needed and the cost. I already have a network hooked up to the Garmin, which has the gauge page. (However, it's not the Garmin network, but rather the one RayMarine required for their autopilot. Another PITA regarding installing the lowcost RayMarine autopilot with everything else Garmin.) It would be nice to change all that stuff out and go strictly Garmin. But it's an added cost I'm not willing to pay! Colby
PostPosted: Mon Apr 23, 2018 7:33 pm    Post subject: Reply with quote
Something to keep in mind; Miles per gallon if you are on salt water is a variable. That is due to the ever moving tidal currents. If you are doing cross tide runs just for the numbers it is possible to get repeatable numbers, but for practical purposes miles per gallon on boats is going to have to be approximations. And hours per gallon (or more realistically gallons per hour) will be more useful for repeatability, not so much for fuel use planning.
PostPosted: Mon Apr 23, 2018 7:40 pm    Post subject: Reply with quote
Harvey,
Although there are always some tidal and current influences, many parts of the world in the oceans these are minimal--and can be from any direction. Some places they vary in speed, but usually consistent in direction--then occasionally they will change with no reason for a brief period of time.
That there are currents (not all tidal) is all the more reason to have a fuel flow device and know amount of fuel used, unless you have huge tankage. Many of the ocean crossing trawlers and large yachts have "day tanks" so there is a very accurate recording of fuel used, as well as the flow meters.
NewMoon
City/Region: Holladay
C-Dory Year: 1991
Vessel Name: Cindy Sea
Photos: Cindy Sea
PostPosted: Mon Apr 23, 2018 9:34 pm    Post subject: Reply with quote
FWIW, I've kept records of every refuel, and every mile traveled over ground (via GPS) for the entire 18 years and 39,000 nautical miles I cruised with New Moon. 95% of this was on the Inside Passage, with tides and currents aplenty.
My mileage would vary considerably at first, when I spent some time at 18 knots and some at 6, with the proportion being pretty variable.
But after I settled down to traveling mostly at 6 knots, NMPG figures from tank to tank became remarkably consistent. I guess if I log a bunch of miles, the currents average out reasonably well.
For the last four years and more than 9,000 NM, averages by year were 3.84 NMPG, 4.18 NMPG, 4.27 NMPG, and 4.25 NMPG.
So I planned my fuel range based on 4 NMPG.
Remarkably enough, I get almost the same NMPG with the 37 Nordic Tug at 7 knots.
Richard Cook
"Cruising in a Big Way"
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Tue Apr 24, 2018 10:43 am    Post subject: Reply with quote
I kept our log book from our Monk designed cruiser. No gauges on the tanks, so we kept track of fuel usage primarily by engine hours. It was an odd feeling at first, but after a hundred hours of keeping track, it seemed fine to simply check the log book and calculate that we had plenty of fuel to go from Ballard to Friday Harbor and back.
I get a little nostalgic looking at the efficiency. Plus, diesel was 64 cents a gallon. I should have done more cruising. Words to live by.
Mark
Page 3 of 3
Page generation time: 0.0417s (PHP: 63% - SQL: 37%) - SQL queries: 20 - GZIP disabled - Debug on
