Trim Selection-Does size matter??
Goto page Previous  1, 2, 3
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Tue Feb 08, 2011 12:11 pm    Post subject: Reply with quote
Can I point out here what a great company Bennett is?
WHen I moderated the Powerboat Forum for Sea Magazine Tom would stop by and answer trim tab questions, and even helped answer questions for posters with competing products.
Is Bennett the best tab out there? I don't know. But their customer service is superb, and the reason that I recomend their product.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Jazzmanic
Photos: C-Dancer
PostPosted: Tue Feb 08, 2011 12:29 pm    Post subject: Reply with quote
Tabman, great to have you onboard. I'm going to start mooring our boat in a saltwater marina for the first time and just purchased trim tab zinc anodes. Where's the best place to mount them on our M-120's?
Peter
C-Dancer
Tabman
City/Region: Mount Pleasant
State or Province: SC
PostPosted: Tue Feb 08, 2011 12:44 pm    Post subject: Reply with quote
Matt,
Thanks for the kind words, they are appreciated!
Tom
Bennett Marine
Tabman
PostPosted: Tue Feb 08, 2011 12:49 pm    Post subject: Reply with quote
Peter
C-Dancer
Peter,
Did you buy the disk type?
The best way to install these is to mount one half of them on the top of the Trim Tab (no need to put half on the bottom, and it will just cause drag).
Put it between where the actuator (ram) is attached to the Trim Tab and the hinge on the transom pretty much right in the middle. Remember not to paint or prime underneath the zinc so good electrical contact is maintained with the Trim Tab.
Tom
Bennett Marine
Peter_BDA
City/Region: Bermuda
C-Dory Model: 22 Classic
Photos: Luna-Sea
PostPosted: Tue Feb 08, 2011 2:02 pm    Post subject: Reply with quote
Hey Tom, I haven't yet but I will. I hadn't even thought about the zinc issue. M120s are in my West Marine "cart" waiting for a few more bits and pieces.
Thanks for all your help-it is much appreciated!!
Peter
Bermuda
Peter Aldrich
Bermuda
Jazzmanic
Photos: C-Dancer
PostPosted: Tue Feb 08, 2011 2:04 pm    Post subject: Reply with quote
Tabman,
Actually, I bought these ones. I guess they're made to screw onto the actuator screws. However, the M-120's have the actuator on the top middle of the tab.
Will these work?
Peter
Tabman
PostPosted: Tue Feb 08, 2011 3:00 pm    Post subject: Reply with quote
Peter
The actuator on the M120 attaches to an angle in the middle of the Trim Tab.
You should be able to install it against the angle in the same way it's attached to the "lip" on the Trim Tab shown in your picture. If the ends of the zinc hit the part of the M120 that angles upwards you could cut them a little to fit.
I do prefer the round zincs mounted on top of the Trim Tab even though you have to drill a hole in the Trim Tab the first time you install them.
They have a large contact surface, can be purchased just about anywhere, are inexpensive. Also they do not use the actuator mounting screws to hold the zinc in place. Even though the one you show has stainless inserts to keep the mounting screws from becoming loose as the zinc dissolves there is still a chance that the actuator screws can become loose so keep an eye on them.
Tom
Bennett Marine
Jazzmanic
Photos: C-Dancer
PostPosted: Tue Feb 08, 2011 4:22 pm    Post subject: Reply with quote
Thanks Tabman.
Peter
Mighty Bite
Vessel Name: Mighty Bite
Photos: Mighty Bite
PostPosted: Wed Feb 09, 2011 12:12 am    Post subject: Lenco Trim Tab Upgrade Reply with quote
Size definitely matters. I would go with the Bennett's M120's if I were doing again......probably, but I chose the Lenco's primarily due to the simplicity of install with the electric and not having to deal with the hydraulic lines, etc. (fewer hole syndrome)
I like many others found the performance inadequate. Lenco didn't do themselves or users any favor by tapering the tabs, thereby cutting the surface area. I made a cardboard mockup of what I wanted to do and had the local sheet metal fabricators make some stainless steel wings for the tabs. I designed a turndown on the wings to channel the water a bit which clearly improves tight handling around the dock & slip area. This design changed the effective surface area of each tab from 108" factory to 144" which like a difference of night and day. They are extremely effective now and I am really happy with them. It was a pretty simple and economical solution. Biggest hassle I had was the slow going drilling stainless.
I just put some pics on "3rd Bytes" album (bottom of page 4) if anyone wants to check it out.
You all have a super day!
Mark on Mighty Bite
Page 3 of 3
Page generation time: 0.0603s (PHP: 42% - SQL: 58%) - SQL queries: 22 - GZIP disabled - Debug on
