V-Berth Storage
Goto page Previous  1, 2, 3
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Tue Feb 23, 2016 3:59 pm    Post subject: Reply with quote
Here is a small screw hatch example: I have added a roll of clear duct tape down there as well now.
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Tue Feb 23, 2016 4:06 pm    Post subject: Reply with quote
I don't have a depth measurement for you, but what I would/will do is use 3/4" cleat stock (epoxied to the underside) and then re-use the cutout for the hatch, as I did on the V-berth flats (sitting on the cleat). On the other hand, if depth is an issue (and why not save any room possible), perhaps one could use stout aluminum bar stock or something along those lines for the "cleats," which would take up very minimal room (1/8" or 3/16"). Also the hatch would be flush just as it is without a hatch. Hmm, there went my 3/4" cleat stock Very Happy
Just another idea. I can see that people have used the surface mount hatches and been happy with them (and, like your boat, mine has a ~6" round deck-plate under the Porta Pottie area).
One note is that - at least on my boat - there is some "structural" foam that holds up the footwell (it's much harder than the typical open celled pour in foam, but is some type of pour in foam). That may not run aft into this compartment anyway, but just thought I'd mention it. Some support is good, but of course there are many ways to provide it.
Aurelia
Photos: Aurelia
PostPosted: Tue Feb 23, 2016 4:24 pm    Post subject: Reply with quote
The foam in ours was less than supportive in that space:)
I would guess about3.5 inches of depth at center and tapering to 1.5 at edges.
Greg
PostPosted: Tue Feb 23, 2016 4:40 pm    Post subject: Reply with quote
Indeed. As I think back on it, I am vaguely remembering that the foam under the main v-berth footwell is "hard" (more like surfboard foam), whereas the foam under the little round hatch (under the PP) is the more typical "soft" spray in foam. Some of this was used around the edges of the hard foam (and some boats have this latter type of foam throughout under the v-berth).
I guess it's just a matter of checking it out as you go along, and being aware that you don't want to develop a "floppy" section in the molded sole there. May not be an issue anyway, but just something I'd keep in mind if I were (and I likely will) cutting a big square out of the middle of the cored "sole" section. Shouldn't be too hard to make it as good or better than original just by thinking it over and providing any necessary support in some way.
One reason I'd like to keep it flush (presuming I put a hatch here) is that I have seen a mod wherein folks move the Porta Potti aft to that area, then use the original PP area for stowage. I don't know if I'd ever do that, but with a "flat" sole it would make the option easy (PP wouldn't "rock" on something raised).
Aurelia
Photos: Aurelia
PostPosted: Wed Feb 24, 2016 9:19 am    Post subject: Reply with quote
Greg
I was able to measure last night and those numbers were pretty close with nearly 4 inches of space in the center. Also, the recessed bottom design of our portapotty fits over the 8inch round hatch so I think some potty and surface mount hatch combos would work together just fine.
Greg
Finally2
City/Region: Los Osos
Vessel Name: Badfish
Photos: Finally2
PostPosted: Sat Jun 08, 2024 6:33 pm    Post subject: Reply with quote
Any of you guys remove the foam and have the most incredibly sticky resin/glue smeared all over the place?
If so how do you get it off? Putty knife is no match. I thought the play would be to remove it and paint in there with some gloss paint but getting it off is worse than getting the foam out
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
PostPosted: Sat Jun 08, 2024 9:22 pm    Post subject: Reply with quote
I did not have that problem on mine. Just a guess but I think it is pour foam that didnt set up, probably because it wasn't mixed thoroughly. Not sure what to do about it. Maybe try acetone?
Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser
Finally2
Photos: Finally2
PostPosted: Sat Jun 08, 2024 9:31 pm    Post subject: Reply with quote
I was curious about acetone but wasn’t sure if it was a bad idea. It’s INCREDIBLY TOUGH to get out. A heat gun has helped but still it’s 10x harder than removing the spray in foam which was not easy. I don’t know what to do. It’s incredibly sticky. It’s incredibly awful
clayhubler
PostPosted: Sat Jun 08, 2024 9:40 pm    Post subject: Reply with quote
You will not harm the fiberglass with acetone. Just be careful about the fumes and such as I could see where it might take a fair amount.
PostPosted: Sat Jun 08, 2024 9:56 pm    Post subject: Reply with quote
Be really careful of long time or high concentration of Acetone fumes. Mostly irritating, but can have some adverse health issues. Also it is very inflammable I know of one case where it was being used in a garage where there was an open flame water heater, and caused an explosion/fire.
I have not dealt with this residue, but I would try heat and a sharp putty knife to start with. Acetone does soften gel coat, especially if allowed to pool on it.
Finally2
Photos: Finally2
PostPosted: Sun Jun 09, 2024 12:04 pm    Post subject: Reply with quote
So acetone is not doing much. Even with wire brush scrub with it. Had some success with drill bit wire brush and acetone but it loosened up/cleaned about 2in and the whole wire brush is now just thickly caked with the resin. I’d have to buy like 200 of these wire brush bits to do this…
I don’t need it smooth in here. I need it not a sticky mess. How awful would it be to paint right over this residual sticky mess, or even gel coat over it
Finally2
Photos: Finally2
PostPosted: Sun Jun 09, 2024 12:18 pm    Post subject: Reply with quote
I posted some pics in my album if it helps to visualize
PostPosted: Sun Jun 09, 2024 12:19 pm    Post subject: Reply with quote
My '08 CD22 did not have foam in the v-berth compartments. However, the gelcoat or whatever the factory used on the inside never fully cured. Putting things in the interior cabinets usually resulted in the sticking to the walls. I just ended up painting the inside of the compartments with exterior latex house paint (it's what I had on hand). This worked out fine.
You could also try applying some catalyst to the uncured resin and see if you can get it to set up hard, then sand it smooth.
Finally2
Photos: Finally2
PostPosted: Sun Jun 09, 2024 12:22 pm    Post subject: Reply with quote
Oh man I needed to hear that. I think this is an impossible task getting this out
clayhubler
PostPosted: Sun Jun 09, 2024 12:40 pm    Post subject: Reply with quote
Yeah, after looking at those pics I would just try to get as smooth as possible and then paint really good. I think its pour foam that wasn't mixed good enough before they poured it in.
Page 3 of 3
Page generation time: 0.0556s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
