Need plotter recommendation
Zelpha
Guest
PostPosted: Sat Jul 26, 2008 10:49 am    Post subject: Reply with quote
Thanks Cmiii,
I bought the GPS 18 to feed my laptop directly thru a USB connector which leaves no accessibility to wires between the Sensor and USB male end. Plug it into the computer with "Inland Lakes" Garmin software and all works great on the laptop screen. My problem is how to get from the computer to the S1000 input wires. Wonder about coming out the 2nd USB port with another UBS connector with wires. Maybe it cannot be done. Thanks for your help. Zelpha
flrockytop
Photos: C-LOVER
PostPosted: Sat Jul 26, 2008 11:52 am    Post subject: Reply with quote
Zelpha wrote:
Thanks Cmiii,
The problem, I think, is going to be that the data coming out of the usb is not going to be rs232. I've got a GPS 18 but it is not the usb version. I'll have to look up the data sheet and see just what your dealing with. Do you have a serial port the computer? If so then the GPSGATE program can take the data coming in the usb port and turn around and send it out the serial port. The other option is, assuming that you have two usb ports is to get one of the usb to serial dongle to put in the second usb port. This will give a place for GPSGATE to send the data. You would then just go from the dongle to the S1000. The next problem would be if all this converting would slow the data rate down to where it was not fast enough for the S1000. This "cleanest" thing might be to just get a $50 dedicated GPS for the S1000. I think thats what I'm going to do on mine.
I just looked at the specs for the USB GPS 18. As I thought, you are not going to be able to directly get the data that you need from the USB GPS18. You would have no problem with the GPS18 PC or GPS 18 LVC.
2007 22 Cruiser
Track Me HERE
NA4RR
Roger Rockwell
Pensacola, Fl
Zelpha
Guest
PostPosted: Sat Jul 26, 2008 1:34 pm    Post subject: Reply with quote
Thanks Roger, I think you are right. I do have a second USB port and a RS232 dongel but from what I also read on the Garmin site I think the protocol is different from that the S1000 requires. Oh well, I guess I will have to use an old, old Garmin 176C. Has a very small screen but still works well and has a cable with the required NEMA output wires. We are so spoiled; once they only had a sextant. Thanks for your help The S1000 is worth the hassle. Zelpha
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Sat Jul 26, 2008 5:53 pm    Post subject: Reply with quote
now i'm really confused by all the different software options. Zelpha, does Garmin Inland lakes include navigation software? Because I really like the depth of the lake charts it provides. If I can just keep my existing gps for the ocean/bay and use a laptop for lakes, that may be the best of all worlds.
Chris
Zelpha
Guest
PostPosted: Sat Jul 26, 2008 7:01 pm    Post subject: Reply with quote
Hi Chris, I have an older Garmin 2006C Chartplotter on another boat and I run Inland Lakes on a chip in it (which I dowloaded using a USB chip programmer from a Windows computer programed with Inland Lakes but I think you can buy the chip already programmed). It functions a a good big screen plotter with Inland Lakes (and you can buy or download other Garmin programs and also feeds my S1000 via wires and has a 12 volt set of input wires. You can set waypoint etc on the system. I think this is common with Garmin programs if you have a way to send the correct NEMA signals to the S1000. I believe most of their chartlplotters do. My problem is I have no RS232 port on my laptop so I can only receive USB to the computer but then cannot resend to the S1000. The Garmin Software (Inland Lakes etc is not the problem I do not think). The Garmin USB Data Card Programmer is great in that you can choose the smaller map areas you want to use and later go back and reprogram the same chip to a different area for your next trip. I guess I can always move the Chartplotter from boat to boat but it does not have all the capabilities of a laptop. Least I seem biased to Garmin, the S1000 is Raymarine. As is usual, I guess I can buy another set of cables from my GPS18 that have a RS232 output and then buy a RS232/USB adapter. Perhaps cheaper to buy another Chartplotter and carry both the laptop and new Chartplatter on the boat at the same time. Whatever works if you have the money. Best to you, Zelpha
Zelpha
Guest
PostPosted: Sat Jul 26, 2008 7:13 pm    Post subject: Reply with quote
Chris, above rather longwinded. Inland lakes works great on only a Windows computer if you have the puck/sensor to feed it. Zelpha
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Sat Jul 26, 2008 8:02 pm    Post subject: Reply with quote
flrockytop,
I would check out NewEgg.com before buying from TigerDirect. It looks like they have several of the Asus Eee notebooks with the SSD HDD and their prices are better. Plus NewEgg has always had good customer service.
Gary Johnson
KB7NFG
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Jul 27, 2008 2:37 am    Post subject: Reply with quote
WHHHHEEEEEUU................you guys are typing in English aren't you???? Obviously technology has passed me by.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
RJD Wannabe
City/Region: Elk Grove
PostPosted: Sun Jul 27, 2008 3:14 am    Post subject: Reply with quote
ahhhhhhhh, the days of "plug and pay" or KISS
Soon to join C-Dory owners
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sun Jul 27, 2008 9:03 am    Post subject: Reply with quote
Not a real fan of laptops for navigation in our small boats.... Leave the top off the blender one time and oh it ain't nice... but...if yall are headed that way...and it looks that many are interested or have started the journey...... I would have to look in the photo album of C-Eagle in AL on Richard and Cheryle's boat, and they have a neat set up on a swing table for the laptop .....using the aft wall of the V-Berth it seems. It has been a bit over a year since I saw it at one of the Cumberland River gatherings....but, I do recall it was set up to be very flexible...with...or without a laptop on the table.
Worked real good for wine and cheese!! Thumbs Up
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sun Jul 27, 2008 9:54 am    Post subject: Reply with quote
Thanks Jack-I thought it was just me....
MartyP
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Sun Jul 27, 2008 10:08 am    Post subject: Re: Need plotter recommendation Reply with quote
cemiii wrote:
Important
NMEA 0183 output for A/P (is new 2000 protocol backward compatible?)
Sub $1k
Chris
Way back at the beginning of this post Chris asked the above question. I assume you can't get a 0183 signal from a NMEA 2000 GPS?
marvin
cemiii
City/Region: Alamo
PostPosted: Sun Jul 27, 2008 12:38 pm    Post subject: Reply with quote
yes, it would be just like me to go out and buy the newest greatest gps, from someplace that i couldn't return it, and then find out it couldn't communicate with my auto-pilot. some day i'm gonna learn.
chris
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Sun Jul 27, 2008 2:31 pm    Post subject: Reply with quote
Check with Maretron. They have several different items for the NMEA2000 bus. Especially interesting for this topic is the USB100 that converst NMEA 2000 to 0183.
cemiii
City/Region: Alamo
PostPosted: Sun Jul 27, 2008 3:03 pm    Post subject: Reply with quote
found this in the albums on pc use
http://www.c-brats.com/modules.php?set_albumName=2ndByte&id=Computer_Mount_up_and_running&op=modload&name=gallery&file=index&include=view_photo.php
toggle to his next photo and see the swivel mount. As well, I love the clean look of the snap on wiring cover in the berth. Mine looks like a birds nest.
Wow tons of other great mod ideas and some phenominal pics. Thanks 3rd Byte. If you're out there where did you find the great swivel setup?
chris
Page 2 of 3
Page generation time: 0.0502s (PHP: 65% - SQL: 35%) - SQL queries: 24 - GZIP disabled - Debug on
