AirX Wind Generator
PostPosted: Sat Jun 21, 2008 3:27 pm    Post subject: Reply with quote
Not only noise, but vibration from the blade type of wind generators.
We use a 30 amp multip stage charger with the honda generator for battery charging--not as pointed out the 8 amp output.
There are way too many practical considerations (such as mounting and limited output at low speeds) to make the wind generators paractical in a C Dory.
There are some cruising boats which have two wind generators and a number of solar cells, in the caribbean--were the wind is nearly constant in the 20 knot range, plus high sunlight capacity and these are barely supplying enough power to have full maintance.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Jun 22, 2008 12:35 am    Post subject: Reply with quote
OK, thanks Bob. Sounds like the benefits of a solar array and/or a wind generator are very minimal, and that running the Honda 2000i for a couple of hours in the morning is the most practical solution.
Doryman
M/V Lori Ann
Anacortes, WA
Page generation time: 0.0267s (PHP: 55% - SQL: 45%) - SQL queries: 19 - GZIP disabled - Debug on
