E20 Fuel
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Wed Jun 04, 2008 1:37 am    Post subject: Reply with quote
hardee wrote:
Gary Johnson said:
After 2 weeks the inside of the carb would look like it had been sitting for several years there was so much aluminum corrosion in the float bowl.
Gary, would this aluminum corrosion look like white-ish crystally plaque? that is what I had in my carbs, (3 of six) on a set of twin 40 Yami's. I have been using Stabil, but not the new Marine version, and have been buying automotive fuel (E-10). And it didn't take me 15 min to clean those Carbs Cry but after the mechanics were through the pair purred like a couple of kittens. Me and the wife however, ate beans and rice for the next month Thumbs Down
Yup, that is exactly what it looks like.
Gary Johnson
KB7NFG
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Wed Jun 04, 2008 9:52 pm    Post subject: Reply with quote
This thread got me to looking at fuel-treatments and I found Review of Gas Treatment & Fuel Additive Products
Pete
PostPosted: Wed Jun 04, 2008 11:59 pm    Post subject: Reply with quote
Pete-
Great source!
I would particularly like to recommend that everyone read this addition to the report you listed:
Ethanol Fuel Use in Marine - Boat - Outboard Engines
because it deals directly with the use of ethyl alcohol in outbards, the central topic of this discussion!
PostPosted: Tue Jun 10, 2008 12:08 pm    Post subject: Reply with quote
I'm beginning to think that in boats using E-10, E-20, or E-85, one should once a year take a siphon hose down the fuel intake hose (or remove it at the top of the tank if necessary) and siphon out the bottom inch or two of the fuel mixture to remove any phase-separated fuel, water, or any other crud to keep it from cycling through the fuel intake system towards the motor.
Too bad there's not a drain fitting on the bottom of the gas tank like a radiator or a compressor tank.
Same idea might just apply to infrequently used cars, trucks, and motorhomes.
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Tue Jun 10, 2008 12:28 pm    Post subject: Reply with quote
Joe,
On my tanks (2002- 22 cruiser) the pickup tube was right on the bottom of the tank and would pick up the crud fuel first. I am in the process of installing new fuel tanks since one of my old ones cracked. On the new tanks I can't tell where the fuel pick-up tubes terminate-but I would guess that it would be very near the bottom to avoid too much unusable fuel. I do intend to make the tanks easily removable so that I can totally empty them and clean them out every couple of years.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
Page generation time: 0.0313s (PHP: 66% - SQL: 34%) - SQL queries: 18 - GZIP disabled - Debug on
